The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > MHD "take a look at my log" thread
      06-17-2016, 09:25 PM   #45
eagleye
Drives: 2009 335i 6MT
Ok gents, I just went FBO last weekend and have been running the E40 map for a couple days. I have this nagging suspicion I'm dealing with a boost leak, so here are a couple very short logs through the meat of 3rd gear in case that sheds any light on the situation. My HPFP is also dipping toward 1500 psi at peak torque, so hopefully that's not a problem in the making; LPFP is good, however, thanks to Stage 1 inline pump.
Hope the logs aren't too short to be of use...
http://www.datazap.me/u/lichides/log...=2&data=4-6-23
http://www.datazap.me/u/lichides/log...=0&data=4-6-23
      06-18-2016, 02:27 AM   #46
hellokitty
hellokitty's Avatar
2900
Drives: '17 M3 ZCP DCT
Check vacuum lines, boost solenoids, etc. You are definitely leaking boost.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race
      06-18-2016, 12:43 PM   #47
wren57
Roll Tide
wren57's Avatar
591
Drives: 335i
Please someone take a look at my log:
http://datazap.me/u/wren57/log-14662...78&tmax=605.07
Standard IC, DP, CP/BOV, intake mods
New VCG, PCV valve, vent hose, 1/4" BOV hose to intake manifold, vacuum lines
Car has 112k miles, on original turbos, boost solenoids, and LPFP. HPFP replaced 50k miles ago.
      06-18-2016, 12:49 PM   #48
eagleye
Thanks!
Vac lines look good, and I cranked down all the hose clamps I touched during the FMIC and CP install last week. A couple were definitely looser than I'd like. Can't say the new log looks much if any better, though. I'm 1-2 psi below target for the whole run, but based on the low WGDC it looks to me like the ECU isn't trying very hard to get it back on target.
What seems weird is that there is no taper to the target boost like I would expect. The actual load is tracking the slope of the requested load with a smallish offset, but due to the totally flat target boost curve the actual boost is falling way short as revs increase. Sooooo....
Does that mean no boost leak, but maybe tired, stock turbos?
http://datazap.me/u/lichides/log-146...=0&data=4-6-23
Here's a log from a few months ago for comparison, Stage 1+ v5.3:
http://datazap.me/u/lichides/log-145...6-21&zoom=9-74
      06-18-2016, 12:51 PM   #49
krukedking
Drives: 2007 335 xi
ok my story hoping someone can chime in.
i had a bunch of work done on my car, kittyless dp's, all new index 12 injectors(all coded) walnut blast, new plugs, new pre-cat o2's. all done at the same time.
so here is my issue, car ran great, no smoke or anything. i load up v6 93 tune with no intercooler. when i come to a stop but only sometimes, the car will puff out some smoke, I am going to order the rb pcv. well besides that the car does not hold boost very well. and i get codes
2c7e lambda probe behind catalytic converter trimming control
2c6a oxygen sensore after catalytic converter mixed up
2ded power management standby current control
30ff turbocharger, charge air presure too low
sometimes i get a vanos code but i forgot to write it down.
at high rpm is the only time this happens, i can sometimes clear the code via mhd, but sometimes have to shut the car off and it will clear.
im not sure where to start looking. any help is much appreciated!
http://datazap.me/u/krukedking/half-...og=0&data=4-23
      06-19-2016, 08:43 AM   #50
EscapeYourMind
Drives: 08 BMW 135i
Would appreciate some further insight into this log: http://datazap.me/u/escapeyourmind/n...12-13-14-24-27
Fueling looks good, and no throttle closures (used to have a problem with this). However, boost doesn't seem to be reaching target, and there are some corrections across all cylinders.
Spark plugs could use a changing, not sure if that would help clear up some of the corrections. A bit concerned with the boost though. No codes. Any thoughts?
      06-21-2016, 12:58 AM   #51
MannySingh
MannySingh's Avatar
40
Drives: 335is
http://datazap.me/u/manveer/335is-st...og=1&data=4-21
Thank you!
      06-21-2016, 12:11 PM   #52
Banana Clipper
Jewel Runner
Banana Clipper's Avatar
332
Drives: G01///G20///I20
Please and thank you!
http://datazap.me/u/banana-clipper/l...15-16-17-22-23
www.BHANANA.com
2009 335i - SOLD
2021 M340i - GONE
2024 iX - Yea, she fast
      06-21-2016, 12:27 PM   #53
hellokitty
hellokitty's Avatar
2900
Originally Posted by Manveer View Post
Overall looks good but your turbos look tired... how many miles on them? Also do you have a FMIC? I know its been quite hot in Cali...
      06-21-2016, 12:31 PM   #54
Banana Clipper
Jewel Runner
332
Stock turbos replaced under warranty. Turbos have less than 5k miles on them. Yes, I've added a FMIC and the air temps were about 80* outside during this run.
www.BHANANA.com
2009 335i - SOLD
2021 M340i - GONE
      06-21-2016, 12:32 PM   #55
hellokitty
hellokitty's Avatar
2900
Originally Posted by Banana Clipper View Post
Looks pretty clean to me!
      06-21-2016, 12:36 PM   #56
hellokitty
hellokitty's Avatar
2900
I was referring to Manveer... your log looks spot on for new turbos
      06-21-2016, 12:41 PM   #57
Banana Clipper
Jewel Runner
332
Haha, I missed that part. Appreciate it
www.BHANANA.com
2009 335i - SOLD
2021 M340i - GONE
      06-22-2016, 11:39 AM   #58
Msport335
Msport335's Avatar
97
Drives: 2009 335i m-sport e90
log check...
MHD Wedge tuned e60 FBO+ stock turbo. i'd still like to turn it up a bit more midrange/top end but don't know why i cant make more boost up top....turbos have 70k on them....is it just worn turbos? might be time for new hybrids next season anyway
http://datazap.me/u/msport335/mhd-e6...og=0&data=3-22
will be hitting the track friday night .....curious to know if its safe for me to choose the "desensitize knock sensor" option when flashing
E90 LCI M-sport/ 6AT/ LSD/ FBO+
      06-22-2016, 03:19 PM   #59
MannySingh
MannySingh's Avatar
40
Drives: 335is
83k miles
no FMIC
      06-22-2016, 08:40 PM   #60
d8rknight
d8rknight's Avatar
39
Drives: 2010 335i
2005 Yamaha R1  [0.00]
2011 Infinity G37x  [0.00]
2010 335i  [0.00]
Okay as some of you may have seen previously I was having issues (e40 ots map)with hpfp with to much e85. I've since burned off the tank and filled with 93 fuel. Little did I know I would walk into misfire central on st2 MHD ots 93 tune. I had issues on v5 and v6 93 maps. I decided to run the 95 octane map out of curiosity and got no misfires but fueling looks like a concern. Got an appointment with dealer in am to address hpfp issue so hope that goes well. Mean while can someone check these 93 logs 😕 . plugs were changed 2k ago FBO minus fmic (on the way) http://datazap.me/u/d8rknight/93-and-95?log=0&data=4-22
Keep in mind I've been running Cobb e30 and st aggressive map the past year no issues
      06-22-2016, 09:01 PM   #61
hellokitty
hellokitty's Avatar
2900
83k miles
no FMIC
Sounds like its time to start having some fun with new turbos and FBO/inlets
      06-22-2016, 09:09 PM   #62
hellokitty
hellokitty's Avatar
2900
What codes are you getting? Misfire on the same cyl? Could be a bad coil or coils. This log looks much better and it doesn't appear your HPFP or LPFP is struggling at all.
Next time you log, you should go WOT for the entire gear if it is safe to do so. Ideally WOT 3rd and into 4th and hold it for 2s.
      06-22-2016, 09:11 PM   #63
hellokitty
hellokitty's Avatar
2900
Originally Posted by Msport335 View Post
log check...
I personally wouldn't enable that option. Your map is already aggressive enough as is - especially on worn turbos.
I'd also watch out for Cyl 1... have a spark plug & coil pack handy
      06-22-2016, 09:29 PM   #64
Supra2k6
132
Drives: 335i
heard mixed o2s will throw a bunch on codes 2c6a
      06-22-2016, 09:29 PM   #65
d8rknight
d8rknight's Avatar
39
Drives: 2010 335i
2010 335i  [0.00]
Cyl 2 misfire 29CE. I can never go WOT cause I'll get a misfire. will pull plug and see if it follows plug, followed by coil
2010 335i Coupe / 6MT / MHD | FBO+ MMP S3 /AUBURN WDE / PATRIOTS / CELTICS / REDSOX
      06-22-2016, 09:42 PM   #66
d8rknight
d8rknight's Avatar
39
Drives: 2010 335i
2010 335i  [0.00]
Guys I might have just effed up. Car wasn't in accessory mode after i closed door to flash back to stock... I hit cancel cause it didn't start writing yet.. Now the hw says ffffff instead of IJEOUS ......
Update... Flashed just fine in 42min
