MHD "take a look at my log" thread
04-23-2024, 02:22 PM | #5963 | |
1698
Rep 3,670
Eriksson04288718.00 |
04-23-2024, 02:24 PM | #5964 | |
Rep 66
Drives: 335i n54
04-30-2024, 03:32 PM | #5965 |
Rep 17
Hey guys its me again!
After the experience i have since changed the LPFP , did walnut blasting , changed the chain guide rails (aparently afew pieces of the plastic broke due to high milleage). Have currently flashed stage 1+ 93 oct will attach the log below , still has some timing pulls but nothing above 3 on average , need more experienced guidance if the tune is fine! Turned off burbles too Ps: i did get a 2D2E throttle valve angle-intake manifold vacuum corelation code, searched online and alot are pointing towards it being a false alarm, but some advice on this will be greatly appreciated too Edit: from my logs it seemed the 2D2E came when i temporarily went over boost target so dme tried to compensate by closing throttle? I think that is normal yes as long as it doesnt happen too often? vadonchez hey bro greatly appreciate your advice too if you are free could you take a look at this log stg1+ 93oct |
05-02-2024, 11:02 PM | #5966 |
Rep 3
https://datazap.me/u/bluemeover/log-...og=0&data=3-20
91 oct 6466 port injection how’s she look |
05-03-2024, 09:40 AM | #5967 | |
35
Rep 97
Your log is ok to me everything looks good on fuel side.Everything looks good on boost side too. But timing corrections on all cylinders as if you are using bad fuel. Did you try to run 91 octane map with 93 octane fuel? And again, try V7 2+ map as they are demanding less timing @low rpm than V10 wich can help in your case. |
05-03-2024, 10:10 AM | #5968 | |
Rep 17
As for the 2D2E code , i cleared it that day and it didnt came up ever again, think it was just a freak accident or something , anyways what is VC? |
05-03-2024, 10:32 AM | #5970 |
Rep 17
05-03-2024, 11:08 AM | #5971 | |
475
Rep 1,544
05-03-2024, 12:02 PM | #5972 | |
Rep 17
stage2+ v7.1 91oct |
05-03-2024, 12:11 PM | #5974 | |
35
Rep 97
I think je just not wot totaly but if you look at his other logs that's better. |
05-04-2024, 12:32 PM | #5977 |
Rep 17
Hey man did another log for you! Gear 4 WOT now! I would suggest showing throttle position too , a short while after WOT timing pulls all dropped to 0 , im assuming thats a good sign and timing pulls just normally cruising before wot is normal , think the massive timing pull could be due to fake noise as i downgeared with burbles before pulling so that section can be ignored? If im wrong could correct me too! Lmk!
stg 2+ v7.1 |
05-05-2024, 02:06 PM | #5979 |
Rep 17
05-08-2024, 08:35 AM | #5980 |
Rep 1
N54 wgdc not at requested Level
Hello fellow car friends.
I just replaced my turbos with bigger twins, installed a 3.5 tmap sensor and deleted the vac. canisters. I test drove the car after the install and at wot the boost solenoid doesnt want to close the wastegate. The only codes I have right now is that my Fan is not connected to my car because its currently not installed. I hope yall can help me with this problem... PS(no timing corrections, hpfp value is at 1850 on wot, lpfp always at 80, throttle body also doesnt really want to open at 99% pedal position) I hope yall have a great day. |
05-08-2024, 01:25 PM | #5981 | |
475
Rep 1,544
05-10-2024, 02:20 PM | #5982 |
Rep 6
https://datazap.me/u/ashaw87/log-171...=0&data=3-4-20
Help with this log please. New boost solenoids fitted and now the car is surging. |
05-10-2024, 11:38 PM | #5983 | |
153
Rep 439
How was it acting before? |
05-11-2024, 01:33 AM | #5984 | |
Rep 6
I got the maxgear solenoids from Autodoc. I'll put it on the stock map and see if that changes anything. |
