Go Back   6Post.com | BMW 6-Series Forum > BMW 6 Series Forum > General 6-Series Coupe, Convertible, and Gran Coupe Forum
      04-21-2013, 05:54 AM   #45
Bönz
Bönz's Avatar
184
Drives: 2018 M5
I doubt it. The M6 rotors have a larger diameter. You caliper won't fit. You would have to swap over the entire system, but the wheel carrier is different. I'm not sure if the M6 caliper will bolt on. I have no idea if the rest of the hydraulic and electrical systems are compatible either.
      04-21-2013, 09:30 AM   #46
andreo
BMW Enthusiast
andreo's Avatar
Macao
21
Drives: Citrin Black 650i Coupé (F13)
Sounds complicated and not at all what I was hoping for. Thanks for the advice. Will look for alternatives.
      04-21-2013, 09:59 AM   #47
JNoSol
JNoSol's Avatar
1386
Drives: 750 MSPORT & E90M3
Originally Posted by andreo View Post
Thanks. Sounds like I won't go wrong with black.
Go with G2 Black Caliper paint, can't go wrong.
      04-21-2013, 10:46 AM   #48
andreo
BMW Enthusiast
andreo's Avatar
Macao
21
Thanks. I will be bringing her to my workshop for the paint job next week.
      04-22-2013, 11:52 AM   #49
BMWMilan
37
Drives: BMW
Andreo,
Just my 0.02.
But if you are going to be actually changing brake parts, I suggest you do it with one manufacturer -- either OEM BMW, Stoptech, Brembo, or whatever.
Unless you know exactly what you are doing, and have a tech handy to do any clean up work, you really don't want to be mixing and matching. Even assuming everything fits and works fine when you install them, you don't want to have to face the situation down the road when something does happen and you want it repaired under warranty and then have to hunt down 3 or 4 different manufacturers who are all going to be pointing the finger at the other guy.
Anyhow, good luck.
      04-22-2013, 06:08 PM   #50
andreo
BMW Enthusiast
andreo's Avatar
Macao
21
Thanks for the advice ipsedixit.
I started off wanting to just paint the calipers black and one thing led to another. No work have been done to the OEM brake system yet. The replacement of the OEM rotors with drilled rotors is not as simple as I imagined. Obviously, more research is needed.
I will just get the calipers painted this week and go from there. Thanks again.
6post.com
