Guide to Sockets 335i build thread
05-24-2020, 10:10 AM | #1 |
4545
Rep 11,903
Build thread is a little overgrown
Hope this helps locate posts relating to specific mods and topics of interest LINK https://www.e90post.com/forums/showthread.php?t=1080234 KEY P = Page Number # = Post LAST UPDATED 20 AUG 2021 P221 Last edited by Socket; 08-20-2021 at 06:50 AM.. |
05-24-2020, 10:11 AM | #2 |
4545
Rep 11,903
CURRENT MODS
Exterior M3 bonnet (P74+P77) with M3 vents (P154) (P191) M3 front bumper with fog light delete and M3 air ducts (P3+P21) (P191) M3 side skirts (P3) M3 fenders (P114) (P191) CSL CF Boot (P74+ P77) Mtech rear bumper (P3) EuroDivision CF dual diffuser (P5) (P206) Maxton Design front lip (P115) (P152) (P208) M3 side skirt extensions (P115) Black Kidney grills (P1) Blacked out window trim (P17) Black window tint (P84) M3 mirrors (P165) M3 CF mirror caps (P177) CF roof spoiler wing (P91) Custom headlights (P9) (P29) (P81) (P160) (P194 to P200) RGB demon eyes (P210) Bavgruppe LED indicators (P198) Depot LCI tail lights (P27) Lux LED reversing lights (P44) Custom plates SPCGRY (P1) Lankin plate frames (P1) Interior Two tone custom interior (P39+P41+P42+P43+P45+P50+P52) CF interior trim (P74) Black M3 Novillo leather seats (P194) M3 front and rear consoles (P194) M3 DCT instrument cluster (P17) M3 Mirror Door Control Panel (P172) CIC controller (P80) Center Console Tray (P101) CF performance gear knob (P185) BMW performance handbrake (P91) Custom stitched floor mats (P56) Alcantara BMWP flat bottom steering wheel (P209) Brodit phone holders (P210) Ziza LED interior lighting (P56) M door sills (P197) Red Start Button (P171) Audio / Electronics Android 10 HU Clarion HXD2 Helix M One Subwoofer amp (P188) Helix V Eight amp with integrated DSP (P188) Audiotech Fischer HEC/MEC BT module (P188) Audiotech Fischer Director control module (P188) Focal Utopia Be No7 (P178) (P201) Focal TBe tweaters (P178) (P201) Focal W2Be Mid-range (P178) (P201) Focal 6 W3Be Woofers (P178) (P201) Focal 33KX 13" K2 sub woofer (P185) (P201) Critical Mass Speakers & Custom Tweeter Pods (P100 & P212) Visual Ice custom E92 sub box (P111) (P201) Blackvue front and rear dash cam (P56) CCD HD reversing camera (P92) P3 vent boost gauge (P105) Icar GPS Tracker (P200) Engine / Driveline /Exhaust TFT charge pipe (P149) GFB SV50 BOV (P53) PSP 900ic 7" FMIC (P183) PSP Front Mounted Oil Cooler (P198) Mosselman OFH thermostat (P212) CFS 7045 radiator (P119+P182) Borg Warner EFR 7670 ST (P119) (P132) Custom Wastegate Actuator and Shaft (P156) (P201) EFR Turbo Beanie (P155) Simply Tuning ST Exhaust Manifold (P175) Fuel it Stage 3 LPFP Spool Performance Helix HPFP overdrive unit (P205) Motiv flex fuel (P205) MSD81 DME (P205) Index 12 fuel injectors (P96) Bimmerlife ignition coils (P155) (P180) 3.5 T map boost sensor (P10) Brake booster vac line delete (P102) Custom ST air intake (P167) M3 Cowl (P59) M3 strut brace (P137) Tuned By Tim 98 (P162) Tuned By Tim E85 flex fuel tune (P205 & 211) Vac Motorsports Harmonic Damper (P200) Auto to Manual conversion (P179) BMW Performance Short Shifter Kit (P213) Spec stage 2+ clutch and Single Mass Flywheel (P180) 1M Diff, prop shaft and axles (P197) (P199) Vanguard SS performance exhaust (P5) Custom Cold Side CP (P202) Vac Motorsport Oil Pan Baffle (P215) Suspension / Steering / Brakes KW3 coilovers (P148) Dinan camber plates (P65) Front and rear M3 sway bars (P93) M3 front and rear control arms (P65) German Auto Solutions monoball joints for M3 front control arms (P200) Lemforder monoball joints for M3 rear control arms (P202) M3 diff bushings (P197) Precision Works solid billet aluminum rear sub-frame bushings (P206) Megan Racing rear toe arms (P150) M3 steering rack (P200) AP racing Big Brake Kit (P133) and Rotors (P202) M3 brake master cylinder (P217) Turner Motorsports Engine Mounts (P215) Servotronic Steering Assist (P215) ADV O2 sensors Wheels 19" GTC AFF01 hyper silver rims wrapped in Yokohama Advans 235 front and 265 rear (P15) (P82) 19" GT-CS matte black rims wrapped in Yokohama AD08R 235 front and 265 rear (P106) 19" 230 style OEM rims wrapped in Yokohama AE50s 235 front and 265 rear (P1) BMS wheel spacers - 10mm front, 5mm rear (P66) Motorsports Hardware black 82 mm wheel studs (P70) (P154) (P190) Kics Leggdura Racing CL53 black 2 piece shell race nuts (P207) BMW black air valve caps (P110) BMW CF wheel caps (P111) Rolled rear guards (P102) Last edited by Socket; 08-20-2021 at 06:52 AM.. |
05-24-2020, 10:12 AM | #3 |
4545
Rep 11,903
REMOVED MODS
Exterior BMR Angel Eye Bulbs (P1) CF mirror caps for E92 mirrors (P2) High Kick Rear Spoiler (P4) M3 Rear Boot Lip (P4) CF M3 Lip (P7) Plastidip Vents (P8) Roof Wrap (P13) (P82) CF M3 bonnet (P48) Black E92 bonnet (P186) CF M3 bonnet Vents (P94) Ikon CF Lip (P104) Interior BMWP Flat Bottom Steering Wheel (P18) M3 Steering wheel (P188) BMWP pedals (P43) Msport Handbrake Boot (P43) BMWP Auto Gear Shift and Gaiter (P89) E92 Black Front and Rear Seats (P144) E92 Black Front and Rear Consoles (P144) CF Wrapped Trim (P37) Audio/Electronics IFBMW Speaker Kit (P100) NBT retrofit (P87) Audioson Prima AP8.9 eight channel amp (P100) Alpine pdx 1.6 amp (P105) Alpine type R 10 sub woofer (P105) Engine / Driveline / Exhaust JB4 (P1) MHD Tunes Trebila Tune (P38) Alpina Flash (P1) Alpina Flash V2 (P34) ER Charge Pipe (P1) VRSF catless DPs (P1) Tial BOV (P1) OFH thermostat delete plate (P198) Dual Cone Intakes (P1) Dinan Air Intake (P57) (P98) Stett Vac Canisters (P9) Fuel It Stage 2 LPFP (P11) ATM FMIC (P12) RB Turbos (P13) Pure Stage 2 Turbos (P62) EOS intake manifold and port injection kit (P136) Cyba Air Scoops (P18) RB PCV (P30) VTT Inlets (P30) Compressor Discharge Pipe mod (P30) AD Engineering Low Oil Temp Thermostat (P55) Mfactory LSD (P67) (P71) ER Sports Oil Cooler (P67) CF Engine Cover (P70) Diff Lock Down Kit (P70) Suspension / Steering / Brakes H&R Sport Springs (P1) Koni Yellow Shocks (P7) Drilled & Slotted Rotors (P2) Akebono Ceramic Brake Pads (P11) Painted Brake Callipers (P2) Brake Calliper Decals (P23) Nolathane Bushings (P40) Wheels BMS wheel spacers - (P5) (P21) Motorsports Hardware black 74 mm wheel studs and gunmetal race nuts (P23) M5 Rims (P92) Work Meister Rims (P172) 18" Volk Racing TE37 SL pressed graphite rims with Michelin PSS4 235 front 265 rear (P181) Last edited by Socket; 08-20-2021 at 06:52 AM.. |
05-24-2020, 10:13 AM | #4 |
4545
Rep 11,903
PHOTOS
Stock vs M3 Kit (#60) 12mm and 15mm spacer fitted (#174) SPCGRY on AFF1 rims (#310) Night Photos (#438) Alignment Diagram (#557) (#1381) Light painting (#644) Beach Pics (#769) Springy Dyno 280 kw (#945) NizoPro Dyno 307 kw (#2046) RevSpeed Dyno 280 Kw (#3634) Eastern BM Dyno Day 324 Kw (#4422) Eastern BM Dyno Flex Fuel Tune 373 kw (#4494) Night Pics (#1134) Finished Two Tone Interior (#1181) Boot Fade Pics (#1706) Beach Promo Pics (#1808) MotoEx (#1858) Mr Detail (#1869) Professional Photo Shoot Cardinia Dam (#1873 - #1893 + #1944) Critical Mass Speakers (#2099) Tassie Cruise 1 (#2207) Tassie Cruise 2 (#3311) Tassie Cruise 3 (#4476) Sydney Cruise (#2362) Beach Car Park Pics (#3146) SPCGRY Merch (#3523) SPCGRY with Volk Racing TE37 SL rims (#4208) 320D (#4555) VIDEOS Vanguard exhaust sound clip (#106) Walnut Blast Time Lapse vid (#2351) Celebrating 100 mods vid (#2375) ST install No1 Vids of Start Up (#3074) ST Install drive to check boost (#3119) KW3 Coilover Test drive (#3246) Engine Bay Clean Instructional Vid (#3730) Manual Conversion test drive vid (#4053) Drive By Vids (#4118) Bavgruppe AE vid (#4290) and amber turn signal (#4387) Pete Y taking SPCGRY for drive (#4329) SMFW clutch rattle vid (#4397) Test Drive in the wet (#4405) Eastern BM Dyno day (#4423) SPCGRY Walkaround Feb 21 (#4795) DISCUSSIONS Drone in cabin fix (#548) Wheel Offset (#626) Warble sounds after installing VTT inlets (#681) sound clip (#705) Vac Ref Line Mod Instructions (#732) Tial BOV springs (#801) Spark Plugs (#862) CF M3 Hood Fitment issues (#1038) Surging Boost Problem Fix (#1112) M3 Cowl Parts List (#1269) Diff Build Disaster (#1487) (#1587) Brake Booster Pipe Delete (#1527) The Problem with Clutch Pack LSDs (#1568) Roof Wrap (#1596) E92 Audio Upgrade (#2133) Single Turbo Build No 1 (P117 – P143) • Pulling car out of syd shop (#2705) • Car arrives in Melb (#2730) • Prep engine bay (#2774) • ST kit from Qld (#2837) • ST manifold (#2812) • Test fitting (#2824) • Heat shielding (#2915) • Fitting 7670 (#2916) • Tow to VTL motorsports (#2960) • Custom DPs (#2997) • ST Install (#3008 + #3032+ #3035+#3044+#3058) • ST install finished (#3074) • ST logs (#3124) (#3417) Brake Rattle fix (#3272) Wastegate and BoostBox Issues (#3321) When Oil Lines Rupture (#3422+#3429) When the Turbo Housing Rubs on the Bonnet (#3454+#3519) ST built is it worth it? (#3593 onwards) Serpentine belts just keep on breaking (#3631) (#3702) Gary II (#3679) MFactory LSD failure (#3755) Auto to Manual Conversion – Winter Build (P179 onwards) Painting Rusty Hubs (#3998) Aircon failure (#4241) Bushing removal tool (#4358) Vac pump failure (#4516 + #4527) Turbosmart eWG project (#4593) Guide for new buyers by Vtl (#4596) Page 209 Last edited by Socket; 02-16-2021 at 02:34 AM.. |
05-24-2020, 10:41 PM | #6 |
374
Rep 1,392
Excellent work Phil. You have made so many modifications and changes to your car, it would be a shame if members could not access the information because of the difficulty of finding it within the 210 pages of your thread. I have experienced this myself in the past. This thread will allow all members to easily access the information now. Well done.
05-24-2020, 10:59 PM | #7 | |
4545
Rep 11,903
I have wasted so much time and money on this build it is ridiculous, so if this thread helps new owners avoid the mistakes I have made along the way, then pulling this guide together has been worth it lol Truth be known, lots of inspiration has come from your build, which is one of best N54s in the country #much respect |
05-25-2020, 12:18 AM | #8 |
Slowpoke
245
Rep 291
Thanks so much for this thread Socket. Your contributions to the Aussie e9x/n54 communities are invaluable.
build thread - OEM+ WIDEBODY | Factory Individual Audio, Active Steering, Comfort Access & M-Sport optioned
6MT swapped | Xtreme twin disk & SMF | Advan RSII | ST XTA | F82 M4 heated front seats | BMW Individual interior trims | CIC/Combox retrofits | Custom headlights | 1M/M3 mirrors | 335is auxiliary radiator | LCI tails |
Socket4544.50 |
05-25-2020, 02:29 AM | #9 |
4545
Rep 11,903
05-25-2020, 07:54 PM | #14 | |
374
Rep 1,392
05-27-2020, 02:57 AM | #15 |
4545
Rep 11,903
You are too modest Coupes, you have been around the scene and modding for as long as I can remember.... ur car rips mate, doubt Shane or I would even get close
05-27-2020, 02:58 AM | #16 |
4545
Rep 11,903
Most welcome guys
06-12-2020, 05:33 AM | #17 |
4545
Rep 11,903
bump
06-13-2020, 06:42 AM | #18 |
650
Rep 2,139
Drives: 2009 e92 335i MSport DCT
There's an old saying "he's forgotten more than most men remember" lol
Socket has removed more mods than most people have done
When you doppelkaplung you doppel your fun.
06-14-2020, 08:30 AM | #19 |
4545
Rep 11,903
07-22-2020, 05:43 AM | #20 |
4545
Rep 11,903
Updated
07-23-2020, 05:09 PM | #22 |
4545
Rep 11,903
