F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Log Review Thread
GetBMWParts
      04-21-2024, 04:25 PM   #4137
Dantesboyz
recovering e36er
Dantesboyz's Avatar
68
Drives: 2017 M240i Xdrive
https://datazap.me/u/dantesboyz/yes?...46-47-48-49-63
MHD E40 dorch stage 2 hpfp map
E49 ethanol mix, sheetz E + Shell 93
I forget what stoich I'm looking for, but timing seems ti be happy
2017 F22 M240i, Xdrive, M Performance Package
Active Autowerke Downpipe, Dinan Carbon Fiber Intake, Dinan Carbon Fiber Turbo Inlet, Dinan Mid-pipe, xHP Flashtool, MHD Stage 2
To do next list- #1- Wheel Spacers & Tires, #2- B58 TU Pump, #3- Flex Fuel Kit
      04-25-2024, 11:39 AM   #4138
Krisztian93
Drives: Bmw 540i g30
Hi Guys I have a b58 , and my logs are okay im on stg2 Mgflasher 98 ron- but my Boost The map asks for 16-17psi and mine starts dropping after 5700 rpm 15.5 and then comes back slowly can you guys check my log
This was 3-4th gear i believe
https://logs.mgflasher.com/log/14cbb...0=&wide=1&vt=2
Second one in 3rd gear
https://logs.mgflasher.com/log/14cbb...0=&wide=1&vt=1
Third one 3-4th i believe
https://logs.mgflasher.com/log/14cbb...19&wide=1&vt=0
      04-25-2024, 10:06 PM   #4139
kmac1980
36
Drives: '19 540xi
Hi Everyone,
Would love to hear your thoughts on my logs. Pulling from just below 3k to redline in 4th AT. Stage 2 custom bm3 tune , running 93oct pump.
https://bootmod3.net/log?id=662af34bd1802534db82f7c8
https://bootmod3.net/log?id=662af2e5f7be906545ff058e
Thanks in advance…
      04-25-2024, 11:18 PM   #4140
WrxToBeamerGuy
WrxToBeamerGuy's Avatar
500
Drives: BMW 340i xDrive
Originally Posted by kmac1980 View Post
Hi Everyone,
Thanks in advance…
Your tuner is trying to give you a nice spool but then has to dramatically drop the load to be able to keep the hpfp from crashing. Its already dipping a lot. The throttle angle is pretty bad but if you cant feel it feeling sluggish while driving then its fine. Other than that it looks fine. Timing is safe no major corrections.
Dustin Braun @ Braun Performance Tuning
      04-25-2024, 11:19 PM   #4141
WrxToBeamerGuy
500
I'm unable to view the link. If you can download the logs as a .csv and then upload them to datazap and repost ill look at them.
      04-25-2024, 11:23 PM   #4142
WrxToBeamerGuy
500
Perfectly fine you're at 0.87 afr at redline which is what MHD tuned it to be at. You said E49 but the sensor shows E40.
      04-25-2024, 11:26 PM   #4143
kmac1980
36
Drives: '19 540xi
Thank you kindly for the feedback. The car drives great and is goes like mad, but I don’t have a lot of frame of reference. I’m just on the first version of the tune which was done on a dyno, but they did say they would look at logs and fine tune it. Glad to know it’s safe as least I’m more worried about not doing anything too crazy to the motor for longevity sake.
Sounds like a TU fuel pump might help with the issues you’re pointing out though, which is tempting
Originally Posted by WrxToBeamerGuy View Post
Your tuner is trying to give you a nice spool but then has to dramatically drop the load to be able to keep the hpfp from crashing. It’s already dipping a lot. The throttle angle is pretty bad but if you cant feel it feeling sluggish while driving then it’s fine. Other than that it looks fine. Timing is safe no major corrections.
      04-26-2024, 12:11 AM   #4144
WrxToBeamerGuy
500
These work so disregard my other message about not being able to open the logs. Stock turbo is always going drop off in the top end. You have one knock event in one of the logs. They're targeting pretty high timing for just 98 ron. Id prefer they drop the timing by one degree but its an ots map.
      04-26-2024, 12:14 AM   #4145
WrxToBeamerGuy
500
For a base map its already basically maxing out your hpfp. But for a base map this looks great. Yes a TU pump is something that you should get its great bang for your buck but talk with your tuner. Switching pumps mid tune will change how he wants to tune it.
      04-26-2024, 04:34 AM   #4146
Dantesboyz
recovering e36er
Dantesboyz's Avatar
68
I'm not running the ECA sensor back to OBD, just BT for live monitoring.
Log defaults to 40 per map selection
Thank you for the feedback 😊
      04-26-2024, 12:52 PM   #4147
Krisztian93
I appreciate your time
https://datazap.me/u/krisztian93/stg2-ots-mg-flasher?log=0&data=4
I think i was in 3rd -4th-5th
Thanks in advance , i have smoke tester i plug the cone in the air filters intake pipe, the smoke machine has built in pump 23 psi and i had no smoke leak, but I didn’t hold done the cone and after 40-50 sec it blown out because pressure had no place to escape, i don’t know if i should have hold it down?
      04-26-2024, 12:57 PM   #4148
Krisztian93
So its normal then , and the knock i often have is my engine at risk with this tune?
      04-26-2024, 01:24 PM   #4149
Krisztian93
Originally Posted by DieselDuck View Post
You don't have knock ?
You got a few timing corrections but it isn't too bad.
Log looks quite okay.
Yes i have almost every logs
      04-26-2024, 10:29 PM   #4150
WrxToBeamerGuy
500
I saw your question you posted on my wall. I personally would not drive the car on this tune. Its not even that warm out yet so later in the year it will be worse. If I was tuning this car I would reduce the timing a little bit in order to remove the knock events.
      04-27-2024, 12:15 AM   #4151
Krisztian93
Thanks 🙏
And are you a tuner? You can make custom tune for me? With mgflasher?
      04-27-2024, 12:56 AM   #4152
WrxToBeamerGuy
500
Thanks 🙏
I am a tuner but I have only specialized in gen1 b58s
      04-27-2024, 01:10 AM   #4153
Krisztian93
Mine is Gen1… can i get contact mail or insta so we can discuss further?
      04-27-2024, 01:42 AM   #4154
WrxToBeamerGuy
500
I sent you a message regarding custom tuning with mgflasher and why it can be hard to find a tuner.
      04-27-2024, 02:48 AM   #4155
Krisztian93
I have sent the log files where i have two knock same time, they said its throttle knock not engine knock, and he said Ignition timing 8.25 even on WOT.. should be 17 ish he said its bad tuning but no knock ??
      04-27-2024, 12:58 PM   #4156
AlexHM
Drives: BMW B58
Hi guys,
I wan't to custom tune my B58 1st gen and I have a friend who tunes motorcycles and he made some points which I'm not sure that apply to turbo cars.
Can you tell me why are 90% of the maps running too lean below 6000 RMP, even the custom ones ?
Isn't the most performance and reliability achieved between 12.0 and 12.7,
I can't manage to make a relation between PSI & AFR from the uploaded logs.
Thank you for the info!
      04-27-2024, 06:12 PM   #4157
robbievo
Drives: 135
Could someone take a look and advise if anything looks off? New to this, but running MHD, downpipe, intake, ECA and full E.
https://datazap.me/u/robbievo/2017-g...-19&zoom=24-86
      04-28-2024, 06:47 PM   #4158
WrxToBeamerGuy
500
Why are you running full E? Its causing you to run less boost than the stock 91 octane map.
f30post
