08-03-2022, 12:17 AM | #23 | ||
Derbo Tuning
3613
Rep 3,030
Edit: Quick look into TIS has zero reference of resetting anything in diagnostic software when replacing dampers.
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
wyatth3551.50 TractionControlDelete4602.50 |
08-03-2022, 10:30 AM | #24 | |
564
Rep 465
08-03-2022, 10:46 AM | #25 |
Derbo Tuning
3613
Rep 3,030
I think I Just found the service functions for EDC. It says Shock Adjustment, and pre-adjustment. I don't have my M3 with me so I cannot confirm the functions. Nice Tommysalami !
IG:ruhrohz_m3
08-03-2022, 10:57 AM | #26 |
564
Rep 465
Yup, shock adjustment. I reset my rear axle, where I replaced my shocks, so I'll report back in a few days if it feels different. Drove around a little today and couldn't tell if it was a bit softer or just placebo. We'll see for real after this weekend's autocross event.
08-04-2022, 11:08 AM | #28 |
564
Rep 465
I replaced with Bilstein B6 damptronics in the rears. Had them in the front briefly but didn't like them so kept the OE EDC fronts while waiting on a totally different setup to show up. Prior to resetting, the Bilsteins felt very harsh in the rear, skipping and losing traction over bumps, etc.
So far it does seem to feel more compliant. I reset the front axle too despite being on 90k mile original shocks, and they also don't feel as harsh. |
TractionControlDelete4602.50 DrFerry6731.50 |
08-04-2022, 01:25 PM | #29 |
1890
Rep 5,508
With a faster rebound (at the expense of comfort) you get much better road traction and a faster reacting suspension to multiple bumps and rough surfaces. That's why newer systems such as Chervolet's Magride is better. The suspension can be adjusted much faster with electronic signals than physically turning a knob as EDC does. I ran a few track events with EDC when I purchased the M3. Even on mountain twisty roads, it is way too comfort oriented in any setting. I replaced it ASAP.
Auto Detailing Enthusiast!
08-04-2022, 08:15 PM | #31 |
207
Rep 242
What scan tool are you using? I just checked this with my Foxwell and there's no option to select an axle. Only one option to "Reset Control Unit" under the EDC menu, which I assume is for both axles.
08-04-2022, 11:13 PM | #32 |
564
Rep 465
Foxwell nt510. It was under service/chassis/electronic damping control K.
08-05-2022, 08:46 AM | #33 | |
84
Rep 459
Are we talking about the same system? As for the rest…..you clearly have not read the extracts from the BMW documentation.
08-05-2022, 01:15 PM | #34 | |
207
Rep 242
Replaced all 4 OEM shocks with Bilstein EDC last year, about 9k miles ago. Hopefully I'm not too late for the reset. Good thread with valuable info. Thanks fellas! |
08-05-2022, 04:50 PM | #35 |
1890
Rep 5,508
A signal is sent to the shock that turns the dampening up and down. This is a physical shock valve adjustment so it is akin to turning a knob if you did it manually. All the sensors and other stuff just tell the system how to turn said knob. None of the documents provided so far has said otherwise.
08-06-2022, 03:17 AM | #36 | |
84
Rep 459
08-07-2022, 07:29 PM | #37 |
564
Rep 465
Can confirm doing the reset after 90k miles makes the shocks noticeably less harsh. No more hopping and losing traction over small bumps.
08-09-2022, 05:30 PM | #38 |
1890
Rep 5,508
The wear compensation is a mileage counter that is maintained by the system. It doesn't read wear from the shock itself.
Most likely it turns the dampening higher the higher the mileage until it is reset.
DrFerry6731.50 |
08-09-2022, 08:30 PM | #39 | |
Derbo Tuning
3613
Rep 3,030
That's exactly what it does. Damper wear is extrapolated as a function over time. While this doesn't provide any objective test for the original dampers, it does provide context and reason to reset the EDC damper running time memory when the dampers are replaced.
IG:ruhrohz_m3
08-10-2022, 12:09 PM | #40 | |
1890
Rep 5,508
My point is that EDC is very primitive compared to newer systems on cars. Trying to get a test so he can get new shocks from a dealer? I have no idea how that would work. Short of putting the shocks on a shock dyno and comparing dyno charts to the original specs (something no BMW service center would have), I don't know how that would be compared.
08-10-2022, 03:01 PM | #41 | |
Derbo Tuning
3613
Rep 3,030
One benefit of this thread was that we found reason to reset the memory timer for each damper axle when replacing a EDC damper. It's probably as advanced as a normal oil hydrualic suspension can get without getting into magnetic valves/fluid.
IG:ruhrohz_m3
08-10-2022, 03:49 PM | #42 |
564
Rep 465
I should note that my fronts are still the original 90k-mile EDC shocks and they feel better after resetting. I think in my case the car over-compensated for the estimated amount of wear. They felt great at autocross on the stiffest setting and also are smoother on the street.
08-24-2022, 05:53 AM | #43 | |
4489
Rep 7,134
I had no idea wear was compensated for over time, and that this is possible to reset. Been looking into the EDC system now and then since behaviour have changed over the years (less differens between settings). As mine is daily/calm driven, maybe it has "over compensated" in my case as well. What if it goes too soft after reset, not possiblet to go back I guess? Only have Carly myself but will check with a mate regarding tool/EDC coverage. Thanks again, Nik Last edited by Helmsman; 08-25-2022 at 02:34 PM.. |
DrFerry6731.50 |
08-26-2022, 02:04 PM | #44 | |
84
Rep 459
The differences between the settings seem very small now, so maybe everything has been over-compensated assuming more wear than has actually taken place.
