Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > x-drive tire difference
      03-30-2024, 08:41 PM   #1
will_e92
Drives: e92 335i
is a 3.64 difference ok for xdrive? i’m running 45/18 on rear and 40/18 on front
      03-31-2024, 12:06 AM   #2
spazzz
spazzz's Avatar
122
Drives: 2008 535xi MHD&XHP,2013 X1 35i
One percent or lower is what you want. Just run a square setup.
If the 245/45/18 doesn't rub in the front use that size for both, front and rear.
Something tells me it will so use the 245/40
I think the standard go to is 235/40/18 and 265/35/18.
A couple Googles will tell you what's up.
      04-01-2024, 03:21 PM   #3
vester86
95
Drives: BMW 330D '08
No, that difference is to big
      04-01-2024, 03:47 PM   #4
AWD Addict
Chief Executive
AWD Addict's Avatar
303
Drives: 2008 335xi 6spd Coupe
2008 335xi  [0.00]
Gotta get below 1%. And the closer the better.
You'll wreck a transfer case. So don't screw around with it.
