08-16-2017, 09:28 AM | #1 |
Rep 19
Tunes . Best Bang for Buck?
Sooo basically what is the best bang for buck ? i get the more expensive ones are better like the Elite but is there a noticeable difference between a Jb4? Is it worth all the extra money. Thanks!
08-16-2017, 10:04 AM | #2 |
64
Rep 107
I could be wrong, but I believe part of the difference in price relates to warranty coverage (which in of itself is a relatively contentious point of debate in other threads)
08-16-2017, 10:24 AM | #4 |
120
Rep 410
Warranty is a non given .....
JB+ and Dinan Sport are the best bang for the back JB4 adds more connections and adds possible smoother delivery and more options for added DP etc. (but for a stock car not much different hp figures) Dinan Elite adds better drive ability and a warranty but not a real change in hp compared to Sport |
08-16-2017, 12:57 PM | #6 |
583
Rep 1,117
Drives: 2015 BMW M235i
Flash or piggyback?
08-16-2017, 01:34 PM | #7 |
140
Rep 381
There are no flash tunes available as of yet for the B58 on the m240, only piggyback.
Current: 2019 640i GT, 2019 MX-5 GT-S, 2015 X1 xDrive35i
Gone, but not forgotten: 2017 m240i, 2016 GTI PP, 2013 Camaro SS, 2009 G8 GXP, 2008 G8 GT, 2007 335i, 2003 530i |
08-16-2017, 01:53 PM | #8 |
120
Rep 410
Just got myself a JB4 on ebay but as I have no Windows Laptop I would need to get a Bluetooth kit too ..... guess I just get a Dinan Sport as it includes BT and get rid of the JB4 again ... live and learn
08-16-2017, 02:10 PM | #9 |
140
Rep 381
There is also the Active Autowerke Active 8.
See this thread for tune comparison (doesn't include Dinan Elite): http://www.2addicts.com/forums/showthread.php?t=1384817 Regarding Dinan Elite, it connects to 4 sensors: Map, Tmap, intake cam position sensor, and fuel pressure sensor. - It seems that out of these, the JB4 is most advanced because it has access to the Canbus via ODB, can modify timing, etc., but install takes the longest due to ODB connection. They also update the firmware quite often so you keep having to screw with it if you want the latest and greatest firmware/maps. - Dinan Elite is probably the most advanced out of the rest as it connects to the most sensors, is RPM based, and can correct fuel trims. It does cost the most though and carries matching factory warranty. - Active Autowerke seems like a pretty solid compromise since it's a set it and forget it kind of tune and is RPM based so should be smoother than the two cheap options while cost 1/2 of what the Dinan Elite costs. The downside is that it cost more than the JB4 while seemingly less advanced. - Out of the two cheap options, JB+ and Dinan Sport, take your pick. Both have have concerns about drivability documented on this board, but Dinan Sport connects to both the Map and Tmap sensors (vs JB+ that just connects to Tmap) and boost can be adjusted through Bluetooth.
DailySleeper63.50 |
08-16-2017, 03:49 PM | #10 | |
4517
Rep 8,942
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
08-16-2017, 04:27 PM | #11 |
Joint Chiefs of Staff
24201
Rep 190,807
Depends on your mod goals
If you are keeping your car stock, JB+ /Dinan sport If you are modding in the future JB4
08-16-2017, 10:02 PM | #12 | |
809
Rep 1,369
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
08-17-2017, 08:53 AM | #13 | |
140
Rep 381
Don't get me wrong, I think the JB4 is still the best option around at the moment, it's just the other options are simpler when it comes to installing as I mentioned in my post above. Just trying to give the OP a good break-down of what's available.
08-17-2017, 11:45 AM | #14 |
Rep 23
Overall the jb4 install is very easy, including the Bluetooth add-on. However, be warned if you have a manual the install is a real pain since a thick clutch cable runs through the the engine compartment that one if the wires needs to be fed through. It requires carefully cutting the rubber around and using a coat hanger to fish it through.
