01-30-2024, 11:11 AM | #23 | |
Rep 7
There is no such thing in BMW headlights; instead, BMW made a smooth (but fast) flare-up and fade-out (imitation of a regular lamp) |
01-30-2024, 12:36 PM | #24 |
5506
Rep 8,835
I like the "running" turn signal. I just don't like the pulsing on and off for the rest of the brake light because it looks like you have a weak incandescent bulb in there. BMW really needs to take a good look at Audi when it comes to lighting design.
01-30-2024, 02:28 PM | #25 |
29
Rep 26
If you are in the Los Angeles / Irvine California area, Bimmer Plug can order them and can install as well. I called them and confirmed that these are LCI taillights made for Pre-LCI BMW X5 G05. It's made to order though and can take a couple weeks to be ready for install. At least this is a local shop for some folks and can get some help if anything goes wrong.
https://bimmerplug.com/products/lci-...f95-x5m-g05-x5 |
ipayincash44.50 |
01-30-2024, 04:49 PM | #26 | |
Rep 7
A running turn signal is unlikely to appear in a BMW because: 1) this is a patented technology of Audi 2) and most importantly, because BMW never follows other companies (despite the fact that BMW is the engine of progress) |
01-31-2024, 07:09 AM | #27 |
Ultimate Driving Machine E92ESS625 M3/G05 X5 Msport 40i Individual
464
Rep 2,007
Drives: 2011 E92 M3 DCT/ESS 625 kit
Has anyone tried these. They look great. Plug n play
Just found this amazing item on AliExpress. Check it out! C$1,154.38 20%OFF | Car Lights for BMW X5 G05 2019-2023 LED Auto Taillights Assembly Upgrade 2023 The Newest Style Design Dynamic Lamp Accessories https://a.aliexpress.com/_mMI5vJU
"The Ultimate Driving Machine"
2011 E92 M3 supercharged ESS 625 2016 F15 X5 Msport 35i |
01-31-2024, 07:57 PM | #28 | |
43
Rep 42
02-01-2024, 11:09 AM | #29 | |
Rep 7
This copy of the lights was made for Europe, where the turn signal is a separate light and has an orange (or yellow) color. |
02-01-2024, 11:13 AM | #30 |
43
Rep 42
But that’s the problem, will the wiring work with NAM?
02-01-2024, 11:25 AM | #31 |
Rep 7
In an American car there will not be a turn signal wire (the wire itself may be there, but it is used for the brake light), and it is possible that these lights in turn mode (when the brake light blinks) may not work correctly. More precisely, the seller or manufacturer of these flashlights will tell you.
02-01-2024, 11:32 AM | #32 | |
43
Rep 42
02-01-2024, 11:36 AM | #33 | |
Rep 7
1) It is necessary to recode BDC to Europe (only rear lights) 2) It is possible to lay (if indeed not) a wire for the turn 3) Is it legal in the USA to drive a car with European turns? |
02-01-2024, 12:00 PM | #34 | |
43
Rep 42
2. I think the 3 series did require to feed a separate wire to get the LCI taillights working, maybe the same for X5. 3. It is legal in the US to drive with Amber or Red turn signals based on DOT document. |
02-01-2024, 12:10 PM | #35 | |
Rep 7
If there is no wire, then this channel will be completely disabled in the BDC, and it will have to be turned on using coding. |
02-01-2024, 03:24 PM | #36 |
464
Rep 2,007
They actually will work in the US a Member ordered these from the same link I provided I ordered them as well. He sent me some pictures and videos.
02-01-2024, 03:34 PM | #37 |
464
Rep 2,007
Follow his instagram account “Dubsesd”
For 1000 Canadian $ it’s worth a try.
Jszlaga480.50 |
02-01-2024, 05:00 PM | #38 |
43
Rep 42
Is it the yellow signal one? Can you share the link again? Did dubsesd confirm plug and play, any coding needed?
02-01-2024, 06:17 PM | #39 |
464
Rep 2,007
No it’s like U.S taillights Yes plug n play.
Just found this amazing item on AliExpress. Check it out! C$1,156.38 20% Off | Car Lights for BMW X5 G05 2019-2023 LED Auto Taillights Assembly Upgrade 2023 The Newest Style Design Dynamic Lamp Accessories https://a.aliexpress.com/_mKCnBym
ultragamma43.00 |
02-01-2024, 06:19 PM | #40 |
464
Rep 2,007
No coding required. He also did confirm that it’s plug-in play. I have a video but I can’t post it if you want you could hit me up on Instagram and I can forward it to you Installsplus flooring.
ultragamma43.00 |
02-01-2024, 09:38 PM | #41 | |
43
Rep 42
https://www.instagram.com/reel/C2xBI...N3Y2Y2dXEyeQ== |
02-02-2024, 05:35 AM | #42 | |
464
Rep 2,007
ultragamma43.00 |
02-02-2024, 10:59 AM | #43 |
43
Rep 42
It will be great if you can video of emergency lights flashing off the taillights so we can see the functions. I also shot you a message in instagram.
02-02-2024, 01:45 PM | #44 | |
2031
Rep 3,042
Drives: 2022 BMW X5
I ordered a set from AOKEDING Official Store back in August but as I mentioned before they couldn't deliver. I will probably try to contact them again and see if something has been changed but maybe little closer to the spring time. still subscribed
Installsplus464.00 |
