04-17-2023, 08:09 PM | #2 |
44
Rep 113
04-17-2023, 08:15 PM | #3 |
165
Rep 762
04-17-2023, 08:23 PM | #4 |
44
Rep 113
My bad! Posted then realized that! Whoops! Makes me REALLY curious what BM3 stage 1 with xHP does… just loaded xHP on my 20 with a JB4 on map 1. It is QUICKK!
04-17-2023, 08:31 PM | #5 | |
165
Rep 762
The ECUMAP seems to offer OTS tunes which is "650hp" but they say "700hp" in the video so I suspect it's a custom tune. Who knows what it's making at the wheels but this seems about as fast you are going on stage 1 custom tune + XHP. Next step would be downpipes which I gather is another +50hp or more. |
04-17-2023, 08:34 PM | #6 | |
44
Rep 113
04-17-2023, 08:53 PM | #7 | |
165
Rep 762
If I can get 10.6 or so then that will be a good result in my opinion. A full second quicker than I've done stock and those pesky Teslas will eat dust. I would also assume that these guys will need an unlocked ECU. My car is June 2020 so fingers crossed it's a simple bench unlock as we are before the theoretical July build cutoff when they started locking everything down. Last edited by choppedliver; 04-17-2023 at 08:58 PM.. |
04-17-2023, 09:30 PM | #8 | |
44
Rep 113
04-17-2023, 09:33 PM | #9 | ||
53
Rep 238
04-17-2023, 09:41 PM | #10 |
44
Rep 113
04-17-2023, 09:43 PM | #11 |
53
Rep 238
04-17-2023, 09:48 PM | #12 |
53
Rep 238
04-17-2023, 09:51 PM | #13 | |
165
Rep 762
Boosted8 (boostedsix on Dragy) did 10.9 with secondary cat delete and 4 psi of extra boost from JB4. Similar DA and temps. I know he had issues with torque limits in 1st gear IIRC. It seems plausible to be 0.3 faster with a proper tune and XHP stage 3. |
04-18-2023, 07:27 AM | #14 |
47
Rep 78
A little bit of a disconnect somewhere.
The ECUMAP website shows stage one tune as 650 HP. The video says stage one tune is 700 HP. https://www.ecumap.com/page/vehicle-...83-m550i-530hp |
04-18-2023, 09:25 AM | #15 | |
53
Rep 238
Anybody running a stage 2 should be running, hopefully, high 9's low 10's. I'm going to keep my eye on the draggy leaderboard to start seeing all the high 9's/ mid 10's. It's going to be exciting. |
04-18-2023, 04:34 PM | #16 | |
209
Rep 495
Having said that, I'd love to be proven wrong by somebody here. |
04-18-2023, 04:43 PM | #17 | |
165
Rep 762
I guess it depends how much XHP is worth in the quarter. I've seen estimates that it can reduce 0-60 by about 0.2. I'd like to see what improvements stock cars are getting as that may be an indication of what stage 1 could improve by. |
04-18-2023, 04:45 PM | #18 | |
165
Rep 762
What is 700hp at the wheels, who knows! I'd be guessing 600ish, which kinda matches to various comments about downpipes giving you another 40-50whp. Which is what the RKtunes car did with downpipes and tune. Unless its wheel horsepower who knows really how much power the car is making. |
04-18-2023, 09:47 PM | #19 | |
44
Rep 113
I do know on this specific vehicle the torque limiting is quite dramatic. Even when reading logs of my runs. You can see the dips. I wonder if the M550 was setup that way so it was such a competitor with the M5. Having them both sharing quite a bit now in the motor department. Like, was that the key to really unlocking the vehicles potential? Have the 20+ been limited in that sense. Now we have removed that we are barking at the heels of an M5. I could be completely wrong- it certainly woke the car up. |
04-18-2023, 11:21 PM | #20 | |
165
Rep 762
My benchmark here is the G80 M3. Less power/torque, similar weight, same gearbox. Some of that is more aggressive gearing (lower final gear) but surely the gearbox tune has an impact and I suspect the same in the M5. The M5 has a lower final gear as well I think. Our car is more of GT so it makes sense that BMW would make it slower and more cruisy. We have the same torque as the M5, and whilst our top end power figure is lower there shouldn't be as much of a gap as there is. Edit: checked and M5 has a shorter final drive and different ratios than M550i. M850i has even shorter final drive and similar ratios as M5 (I assume to help with the extra weight). Last edited by choppedliver; 04-19-2023 at 12:49 AM.. |
04-19-2023, 09:47 AM | #21 | |
209
Rep 495
I've never driven an M5 but would love to do an A/B comparison between the M5 and a modded 550 (either JB4 or BM3 Stage 1 plus xHP trans tune.) |
04-19-2023, 03:29 PM | #22 | |
44
Rep 113
This is just one example- https://youtu.be/dEAtW7EdCAU From a dig I’ve seen the same. This was obviously prior to the xHP. |
