      10-30-2023, 09:09 AM   #1
richi-d
Drives: 135i
Coding: Remove Automatic shift down when going in manual drive mode
Hello,
has anyone removed the automatic shift down of one or two gears when switching in to the manual shift mode?
Each time I put the gearshift to the left to drive manually the gearbox shifts one or two gears down.
I have Bimmer code but not found the right setting yet
      11-02-2023, 01:44 AM   #2
Manboy
Manboy's Avatar
Sweden
440
Drives: 2020 M135i Misano Blue
This is a really good question. I never thought about coding it out. I really hate that it drops gear and revs the engine. I usually just pull a paddle then move the shifter.
      11-02-2023, 05:02 AM   #3
cjn
99
Drives: 2021 F40 M135iX
Useful, but is there any verifiable evidence that this can be done?
      11-09-2023, 01:45 AM   #4
Setright
Car Enthusiast
Setright's Avatar
Denmark
20
Drives: 120i M-Sport 2022
Flipping the stick to the left sets the gearbox into Sport mode, that downshift is essentially what you are asking for by moving the stick.
As Manboy said, you just need to reverse the order.
Accelerate and "beat" the 'box to the next upshift by pulling the paddle/stick to +.
That puts the gearbox into manual mode, temporarily. If you then move the stick to the left, you're locked into Manual mode.
Easy, not worth re-coding for.
Also, if you do have the paddles, pulling and holding the Plus will revert from Manual to Sport Mode.
Pulling and holding the Minus will engage the lowest possible gear.
      11-09-2023, 05:34 AM   #5
Erebor
Erebor's Avatar
Switzerland
1130
Drives: M4 Competition (G82)
Jup, basically what Setright said. I just pull on one of the pedals shortly before i switch the gearbox into sport, it locks in manual right away.
2022 G82 M4 Competition xDrive in indiv. Sunset Orange
Incoming: 2023 F40 M135i xDrive in indiv. Tansanite Blue
