Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Wheel Rotation Direction Detection Fault
      10-04-2017, 01:50 PM   #1
chinesedave
Drives: E92 Space Grey
Ive got a very annoying problem with my BMW which is driving me crazy and I have no idea what to do haha!
Car is a BMW e92 325i 2006
Started out when I came to replace the coilovers. Had one set and on had no issues but decided to upgrade them. Changed them all over and lowered the car down and started her up to move it and bang loads of warnings come up on the dash. I scanned it with my bluetooth adapter and it said the ABS sensor had a fault. So I ordered a new one, that came and swapped it out but it didn’t clear all of the the faults. It cleared the speed sensor fault however left a ‘Left Wheel Rotation Detection’ fault. So I then ordered a genuine second hand one with the same part number (just in case it was the third party one) but this still didn’t clear the rotation code.
I have now since replaced the wheel bearing on that side as i thought that it may be that thats gone faulty but the code is still there and will not go. Its been driving me crazy and I’m now left with nothing to do. Ive spoken to various mechanics and have done everything they have suggested but to no avail.
The code that comes up with is: 005D96
Any help on the situation would be great as its driving me mad and i want my cruise control back!
      10-04-2017, 03:57 PM   #2
Chappers 71
Chappers 71's Avatar
5532
Drives: Beige G31 40ix m sport
Have you had a four wheel alignment (geo) done since having the suspension work carried out?
If the suspension settings are a long way out that can cause a lot of warning lights.
I get mine geo'd by STS but any tyre place with a hunter alignment machine would be able to do the job.
Good luck getting it sorted
G31 40ix M Sport
E92 335i. E36 328is coupe
E39 540i V8 6SP manual
E34 3.6 M5. E34 525i sport.
VW Jetta Mk2 GTI 16v. 1679cc 1967 resto-cal beetle
      10-04-2017, 04:20 PM   #3
GATORB8
GATORB8's Avatar
225
Drives: 2011 335is 6MT
2011 BMW 335is  [9.50]
Have you looked at recalibrating the steering angle sensor?
      10-08-2017, 10:21 PM   #4
timshwayze
Drives: 2010 328i
almost the same exact thing is happening to me, installed coilovers on my car, drove for a day then abs brake and the exclamation triangle symbol popped up. shortly after the service engine light soon came on. here are a couple possible solutions i've found after searching the forums for numerous hours.
.clean/replace faulty sensor
.get an alignment
.reset steering angle sensor
.replace hub bearing/reluctor ring
.deep clean hub,sensor hole, and all surrounding areas
.check your battery for correct voltage
.air up tire pressure to specs and reset tpms
.check to see if the wires that the sensor plugs into are in tact
that's basically all i've done, if anyone has any other suggestions i would appreciate it as well! been running with a lit up dash for almost 2 months now. honestly have given up on finding a solution at this point.
      10-08-2017, 10:24 PM   #5
timshwayze
Drives: 2010 328i
also car is 2010 328i and fault codes are 5db6 (wheel direction detection) and 581c (transmission management/dsc)
      10-09-2017, 03:26 AM   #6
AndyVR
12
Drives: E91 320i 2010 MSport
Is it the front or rear wheel?
I've heard cheap sensors have issues and can give wheel direction faults. You say you then replaced it with a genuine second hand one, but how do you know the used part is working perfectly?
      10-19-2017, 01:12 AM   #7
timshwayze
Drives: 2010 328i
did you ever solve your issue with the three lights on???
      12-21-2017, 06:18 AM   #8
chinesedave
FINALLY! I solved the issue this morning. After months of not having time to look more into it I finally set about today to actually solve it. I took the plunge and bought a genuine bmw sensor brand new from the stealers...£95 later and I have a working car with no faults. The second hand genuine one obviously didn’t work so that will be going back. But at the end of the day it pays to buy genuine the first time!!
      04-04-2024, 11:45 AM   #9
mifesto
26
Drives: 2008 335xi
for anyone who cares or for 'chinesedave', you posting my solution saved me ton of my time. i had same situation as you, replaced sensor but DME still complained about it with that same code. returned the chinese junk sensors and bought good quality sensors from FCP euro. error is gone!
Tags
325i, abs sensor, fault, speed sensor
