09-02-2022, 05:20 AM | #23 | |
83
Rep 61
Drives: BMW G30 2018
09-03-2022, 03:06 PM | #24 | |
Rep 11
I have been using it wit the different adapter for over a week and the volume hasn't acted up again at all. |
09-03-2022, 07:57 PM | #25 |
83
Rep 61
Makes sense. I have aux enabled through coding and don't use the cable or adapter. Never faced this problem
09-04-2022, 01:32 AM | #26 | |
Rep 29
12-20-2022, 11:23 PM | #27 | |
Rep 91
Hi, what system do you have? I have Entrynav2 ID6 and use aux/usb. I don't know if this will work for me. |
12-29-2022, 03:02 AM | #28 |
Rep 1
If anyone can post photos of a "glove box install" on a G30/31 it would be greatly appreciated!
Hooked my droiduk box up a few days ago to test then realised I had to code AUX to get everything working properly. Currently awaiting delivery of cables to code AUX before proceeding again with installation. |
02-22-2023, 05:34 AM | #29 |
Rep 91
I have mmi andrem on entrynav2, everything worked fine, but I would like to change the place for mmi.
I would also like to ask for advice on how to place the MMI in the glove box or near it so that I have faster access to it. I know that I need to buy a longer LVDS cable, but I don't know how to get from the HU to the glove box or even under the glove box. I didn't see any hole through which the cables would fit. Maybe you need to disassemble this glove box? |
04-08-2023, 05:15 PM | #30 |
11
Rep 43
hi just reviving this post. did any of you manage to free up LVDS cable?
This has caused A LOT of cursing today after watching an install on youtube which has edited out a mistake of installing LVDS cable! |
05-09-2023, 05:11 AM | #32 |
Rep 8
Hello, I have question about mmi android box, I planned to buy for my bmw g31 2017., id6.
I am curious about listening radio or music from car usb while using android auto? Thanks in advance! |
05-09-2023, 09:25 AM | #33 |
Rep 11
I'm not sure I understand the question, but you can still listen to music from the USB. My car has 2 usb ports, one has the output from the carplay box and the other has a regular USB with music on it.
05-09-2023, 02:01 PM | #34 |
Rep 8
Can you listen radio, or listen music from one of the car usb ports, while your android auto is on screen, waze for example?
07-12-2023, 04:01 AM | #37 | |
17
Rep 40
07-29-2023, 03:00 PM | #38 |
Rep 1
Can anyone confirm this? I know that HID won’t work with CarPlay, but do I lose HUD even when using the built in nav? Just don’t want to impact car value by making HUD no longer work.
09-21-2023, 11:04 AM | #39 |
271
Rep 493
I was under the impression from the Bimmertech guys that you can still change tracks via steering wheel, you just wont see track name on the HUD. Can anyone confirm?
2018 BMW M550i | BM3 stg 1 | Resonator Delete (X-pipe) | Dark Graphite Metallic
09-29-2023, 10:00 AM | #40 |
271
Rep 493
Any info on steering wheel controls? BimmerTech said you can skip tracks, can anyone try this?
Also, how is the sound quality since you are using AUX? juliusedward How does iDrive go into AUX and is the quality of sound as good as BT?
10-14-2023, 05:48 AM | #41 | |
Rep 1
Just installed an MMI in my 2018 G31, on my second attempt. First time I realized that the LCVD cable from headunit to screen could not be removed as it was snugged behind the dashboard.. I then got another LCVD cable and just let the old one be. I was able to route the cables out below the glovebox, and have the MMI just laying on top of the passanger footpanel for easy access.
I also coded the AUX, and it works! However.. It seems the audio volume from fx. playing Spotify is lower than the normal. Like I have to turn the volume all the way up in the MMIs own settings, as well as in ID6, but then trying to use Google assistant almost blasts my eardrums.. Mrdooley, juliusedward any of you guys have issues with the different volume levels? Quote:
10-23-2023, 07:54 AM | #42 | |
83
Rep 61
04-07-2024, 05:35 AM | #43 | |
Rep 2
Did you just order the OEM part (61116832082 or 61116991466) for the cable? Or somewhere else? I got the same problem with my G31 of 2018. What a drama the entire installation. Thanks Last edited by michel2013; 04-08-2024 at 06:49 AM.. |
