      10-25-2021, 05:39 AM   #1
iCARMIX
iCARMIX
iCARMIX's Avatar
Hong Kong
152
Drives: BMW
BMW F40 120i Genuine BMW M Performance Front 4 pot Rear 1 pot brake kit retrofit
Brake kit upgrade for this brand new 1 series F40 120i.
Genuine BMW M Performance Front 4 Pot Rear 1 Pot brake kit was chosen for the upgrade.
Front running 360x30mm slotted disc and rear running 330x20mm slotted disc.
Brake kit only comes in red but it matches with the car quite well.
However a bit more work has to be done when fitting this set of brakes onto the car. The brake servo unit, brake master cylinder and the expansion tank has to be replaced as well, which will be included in the kit.
Another key point to this modification is if you want to fit these brake, with exactly these set of wheels, 12mm spacer on the front, 5mm spacer on the rear has to be added.
Rathian149.00
Tags
118i, 128ti, 218i, 220i, brake upgrade, f44, hong kong, icarmix, m135i, m235i
Search this Thread:
Advanced Search
