08-01-2020, 08:47 AM | #67 | |
405
Rep 333
08-15-2020, 10:06 AM | #68 |
Rep 37
Hello, I have a 118i, the transmission is manual, i was actived the mode sport+ but in the sport customer, we dont change the transmission to sport+, this option not found but i can change the engine to sport+,
does anyone know why? and i am interested to activate the hba, i can buy this packet in the connecte drive but i want coding this. |
08-15-2020, 08:14 PM | #69 | |
405
Rep 333
08-16-2020, 04:57 PM | #70 |
Rep 37
08-21-2020, 07:05 AM | #72 |
102
Rep 94
NEW CODING FOR EXHAUST VALVE PERMANENTLY OPEN
You can have the exhaust valve permanently open, irrespective of whether you're in Sport, Comfort or Eco mode. (You need ASD disabled for the benefit of actually hearing your real exhaust, otherwise ASD drowns the exhaust sound out) Code with Bimmercode Expert mode which will add SPORTY setting to your engine sound menu, which currently has 3 settings: Depending on driving mode Balanced Reduced The Sporty setting will keep the valve open constantly. Switch on Expert mode under HU_MGU. Type in the word sound, you'll then see 2 options, enable both. SOUND KONFIGURABILITY & SOUND KONFIGURATION. Click code and wait for it to complete, then check your engine sound menu settings and you should see the additional Sporty setting👍 |
MrFoxy372.50 |
08-21-2020, 07:54 AM | #74 |
102
Rep 94
08-22-2020, 03:13 AM | #76 |
Rep 37
I have this option activated but I don't really notice any change, could it be because my car is a 118i? ASD I don't know what it is or how it is deactivated
08-22-2020, 03:59 AM | #77 |
102
Rep 94
It's basically an enhanced synthetic/fake engine sound inside the car. Have a read about it. Type Active sound design BMW on Google and there's loads to read about what it does and how it works. It can only be disabled with coding. Reduced setting under Engine sound menu will reduce it significantly. You need an OBD2 adaptor, ideally one the more expensive one's which allow more coding. I have a Unicarscan from Germany, 50 Euros. Plus I paid for Bimmercode full access which was around £30 I think. Considering if you went to a BMW dealer and had one item coded, they would likely charge anything around £40 to £60, I would imagine. So with a good scanner and full Bimmercode app, you can code a lot more for a lot less expenditure.
MrFoxy372.50 |
08-22-2020, 04:14 AM | #78 | |
Rep 37
08-22-2020, 02:26 PM | #79 | |
373
Rep 416
08-23-2020, 02:54 PM | #81 | |
373
Rep 416
08-24-2020, 07:46 AM | #82 |
Car go brum
Rep 5
Like an idiot I bought the Veepeak OBDCheck BLE OBD2 and then checked this thread afterwards. Sent it back now and ordered the ODBLink MX+ although pretty expensive so might just get an ENet cable and Ethernet to Lightning adapter or something.
Did manage to code a couple of things. Really like the M Style Dash but anyone noticed there's no change when you put it in to Eco? Presumably because M cars don't have an Eco mode. |
09-07-2020, 12:34 PM | #83 |
Rep 4
Hiya,
New here and to coding! i am trying to find these settings in bimmercode, i have the full version and a unicarscanner. Bower & Wilkins settings. Enable Colder Air Conditioning enable one touch front window close when when door opened any help will be great, sorry if i am just being blind! Thanks |
09-07-2020, 02:35 PM | #84 | |
186
Rep 498
09-09-2020, 07:59 AM | #85 | |
405
Rep 333
09-09-2020, 08:02 AM | #86 | |
405
Rep 333
09-10-2020, 02:19 AM | #87 |
Car go brum
Rep 5
I ended up going back to standard for the displays. Loads of missing info including your gears in Sport - which I found odd.
09-11-2020, 04:22 AM | #88 |
Rep 37
