10-08-2020, 03:30 PM | #969 | |
10968
Rep 4,821
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
lsturbointeg9152.50 |
10-08-2020, 03:44 PM | #970 |
61
Rep 30
You will need the garage freezer kit probably as well, unless you heat your garage? I had to install one on my beer fridge, very simple install.
https://www.homedepot.com/p/Frigidai...E&gclsrc=aw.ds |
lsturbointeg9152.50 hooligan_G016430.00 |
10-08-2020, 04:29 PM | #971 |
Recovering Perfectionist
15195
Rep 941
Drives: 2015 BMW i3 BEV
Garage List 2014 Mighty Freight ... [0.00]
2015 BMW i3 BEV [0.00] 2000 Audi TT Quattro [0.00] 1967 Formula Vee [0.00] |
It might be worth checking to see if any Columbus Day sales are coming up this weekend.....
2015 BMW i3 BEV, Giga World (Lodge interior), Tech/Driving Assist Packages, 30K miles
10-08-2020, 06:46 PM | #972 | ||
9153
Rep 14,522
i'll keep an eye out!
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
10-09-2020, 12:29 AM | #973 |
207
Rep 307
Last carpet bedroom in the house that needed tile to match the rest of the house, so mark that as done!
10-09-2020, 11:53 AM | #974 |
7431
Rep 11,843
Drives: MY24 G01 AW Msport
sub...
i cant wait to work on my garage! |
10-09-2020, 02:20 PM | #975 |
61
Rep 30
10-10-2020, 03:27 PM | #976 |
9153
Rep 14,522
got the 3rd LED garage light installed by the front of the bay!
also completed the last row of the RacDeck tiles since i had to wait for the wall to finish drying from the new paint! and for the step that goes into the house here's what i was able to do incorporate using the leftover RaceDeck tiles. let me know what you think or what i could've done instead
10-12-2020, 08:49 AM | #977 | |
Space Shuttle Door Gunner
6430
Rep 5,309
There are also "garage" refrigerator/freezers out there. IIRC, the key is that the temp gauge in the freezer is primary or at least separate. The issue with "normal" refrigerators is that the cold air comes from the freezer, but is regulated by the refrigerator sensor, thus if it's say 36* in your garage, the refrigerator will stay cool enough that the compressor won't need to run, so all the stuff in the freezer will/could melt. I might not be remembering that correctly, though. |
10-12-2020, 09:11 AM | #978 | |
13154
Rep 1,965
10-12-2020, 03:39 PM | #979 |
9153
Rep 14,522
i was thinking of putting oh man i forgot what it's called but it's the stuff i use to put on top of my skate board from slipping?
King Rudi13154.00 |
10-12-2020, 04:30 PM | #980 |
2123
Rep 2,758
10-12-2020, 05:13 PM | #981 |
9153
Rep 14,522
lol that's it!
on that note i was able to get the 2nd tire rack installed
IllSic_Design2122.50 King Rudi13154.00 |
10-13-2020, 08:30 AM | #982 | |
13154
Rep 1,965
A. Dirt and mud will get down into the grain. It can be cleaned, but when wet, it renders the kung-fu grip action slick as snot on a door knob until it dries. In the meantime, it looks like shit until you clean it with a brush. B. Socks, if you step on that stuff with socks, its going to shred them. White fuzzies in the grip tape and worn out socks. C. It's agressively....."grippy." It shreds skin if you hit your shin on it. Trust me, your wife will not approve. Also, just to mention; the paint that can be used in this application will have the same features, but to the general consumer trying to apply the non-slip paint, the results are never pretty. However, I've seen your handy work. I think you'd be fine applying it and making it look how it should, but again, it's just another form of the same issues as above. I don't like to shoot down other people's ideas without offering a solution at the same time; so peep these. https://www.etsy.com/listing/6684623...waApagEALw_wcB |
10-13-2020, 11:56 AM | #983 | |
1154
Rep 1,543
The one thing that gets me is how the actual tread appears to overhang the base. It seems a bit too wide for the step itself. Personal thought is to enlarge/box over the small step and make it bigger. Then cover the riser w/ the tiles. That's an answer to a question no one asked, though. Garage is looking sharp!
- Jeff
bosstones' flickr |
lsturbointeg9152.50 Kilabyte3948.00 |
10-13-2020, 11:58 AM | #984 | |
9153
Rep 14,522
10-27-2020, 02:24 PM | #985 |
Guest
Rep n/a
Drives:
hooligan_G016430.00 lsturbointeg9152.50 |
11-02-2020, 07:42 PM | #986 |
4341
Rep 1,913
Drives: Here and There
Been working on the garage. Got the last bigger project done tonight with about 30,000 lumens @5,000K run in series and raceway to tuck the wiring. Not entirely happy with the raceway to pull from the hardwire location of the original single fluorescent, but the rest looks pretty good. May end up rewiring, but I’m happy for now.
Built some overhead shelves and a new workbench. Installed an Air King. Got a new toolbox/workbench along with some new tools. Mounted a 4K TV (looks high, but will be putting pegboard and shelf under). Organized all lawn equipment and ladders (looks better than that picture shows... ). To be done is mounting a light under the shelves over the workbench (LED panel for drop ceilings), build something to mount my spare hoses on the wall, and get a motorcycle lift to get back on my Honda CB project. |
MovingChicane109.50 hooligan_G016430.00 Kilabyte3948.00 Savageenterprise980.50 lsturbointeg9152.50 IllSic_Design2122.50 |
11-04-2020, 10:03 AM | #987 |
675
Rep 474
Drives: F36 440i GC
Stucco scratch coat and stone lath
Scratch coat and TnG installed in the back Fireplace installed and insulation going in The city delayed us about a week for electrical and roofing inspections. I'm hoping they can get moving on drywall installation because the tile/hardwood delivery is already scheduled for next week.
2024 Porsche Taycan 4S
2017 Ducati Monster 821 |
10
hooligan_G016430.00 bosstones1154.00 wrickem2101.00 Savageenterprise980.50 IllSic_Design2122.50 Hawkeye2069.50 spencers199.00 PoorLurker1136.50 pennsiveguy3552.00 |
11-04-2020, 11:05 AM | #988 |
6430
Rep 5,309
Patrick303674.50 |
11-05-2020, 08:39 AM | #989 |
2070
Rep 4,365
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
Just finished a dresser/cabinet for the wife that she designed. Will replace a workbench of similar dimensions she stole from my shop since it was a good size for what she wanted apparently. (and will look much nicer)
In the intended room. I swear everything is not crooked, the fisheye style lens just makes it look that way.
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4 2017 Harley StreetGlide • Denim Black • V&H Tune 2021 BMW x30i • Phytonic Blue Metallic • Fully loaded |
7
spencers199.00 nyalpine907431.00 hooligan_G016430.00 Patrick303674.50 vreihen1615194.50 pennsiveguy3552.00 |
11-05-2020, 01:16 PM | #990 |
3552
Rep 1,062
Drives: F15 xDrive50i M-sport
My latest home project has been a big hardware and network upgrade.
The machine that I've used for several years as a Plex server and a NAS and a media editing workstation was starting to struggle to transcode some of the 4K content I've recently acquired. It's a giant Dell Precision T7500 from about 2009, nicely spec-ed but a little long in the tooth. I decided to build up a new monster workstation, starting with a Dell Precision T7910 chassis that I bought refurbished. Threw in 2 12-core Xeons running at 2.4 GHz and 128 GB of RAM. Added 4 12TB SAS drives for the NAS duties. And an Intel dual-port 10Gb Ethernet HBA. And an Nvidia GTX 1080 video card. Taking advantage of the fact that I have Cat 6e wires in the walls and 10Gbe Ethernet gear is now available used and is somewhat reasonably priced, I upgraded all my Ethernet gear to 10Gbe. A new 8-port switch in my coms closet and a 4-port switch in my AV cabinet. The old NAS server, which has been repurposed as a backup server, and my HTPC both got new Intel 10Gbe HBAs. My WiFi access point had exhibited some flaky behavior lately, so I decided to upgrade that too as long as I was frittering away cash. I went with an Engenius EAP1300. Speeds are really good and it's rock-solid. I'm seeing great throughput on everything. The 10Gbe network runs at its expected nominal speed. The new Plex/NAS box transcodes 70Mb/s 4K content with ease. I can routinely hit 350 Mb/s from my phone on the new WiFi. Coms closet, with my firewall/router PC, the 10Gbe switch, the WiFi access point, and my Hue controller: My AV cabinet:
2017 F15 xDrive50i M Sport | Superformance GT40 Roush 511 IR FE
7
S1nner126.00 vreihen1615194.50 Hawkeye2069.50 Kilabyte3948.00 IllSic_Design2122.50 E92 M Sport286.50 Turkish Pickle3084.00 |
