03-26-2014, 01:28 PM | #1 |
221
Rep 252
Air Intake sensor location? e92 m3
Hi guys
I have a p0111 error code which is the air intake temperature sensor. Does anyone know the location so I can buy the sensor and do the change myself. Appreciate the help Thanks |
03-26-2014, 06:26 PM | #3 |
96
Rep 545
It is in the intake air duct next to the oil filter cover. The code is for Intake-air temperature sensor, plausibility so BEFORE buying a new sensor check the electrical connector and wiring at the sensor.
1. Push the metal clip retainer and unplug. 2. Inspect the connector pins on both sides of the connection. 3. Reconnect and clear codes. 4. Drive the vehicle to see if the code returns or monitor the data for the intake air temp to see if it matches reality. Do the readings seem plausible. You will need a scantool that can read data or just drive it to see if the code returns. Last edited by kenwelch; 03-26-2014 at 06:35 PM.. Reason: check procedure |
03-26-2014, 06:40 PM | #4 | |
221
Rep 252
Thanks dude |
03-27-2014, 04:21 PM | #5 |
11592
Rep 12,736
Someone with greater knowledge may speak up, but it also may be dirty. Try gently cleaning it with a q-tip and some rubbing alcohol.
Instagram; @roastbeefmike
09-14-2017, 11:36 AM | #6 | |
1429
Rep 3,007
DrFerry6731.50 |
09-14-2017, 05:39 PM | #7 |
262
Rep 1,616
If you look at the photo i attached...Push in the silver wire clip and pull off the connector Then look for the plastic clip #12 that is wrapped around the sensor (circled in red). You just need to pull up and wiggle it off. Don't worry about breaking it, it won't really snap or anything and even if it breaks it's literally a 50 cent part. After you get the clip off you can now twist and turn the sensor. Twist and pull the sensor out. You'll have to keep twisting and pulling until you find the correct spot for the sensor to slip out
DrFerry6731.50 |
09-14-2017, 05:50 PM | #8 | |
Stop the hate, get a V8
3853
Rep 8,625
I would try electronics cleaner. You can get it at most auto parts stores.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
10-14-2018, 10:36 AM | #10 | |
Rep 1
photo attached... I understand there's a replacement pigtail, but does anyone here have any info of the connection? If I could find the other 'end' of my cable, I could at least try a short term fix. Thanks for the help guys. |
10-15-2018, 09:44 PM | #11 |
5279
Rep 10,674
It’s part of the harness under the plenum. You should be able to splice in some wire no problem and reattach that connector. Just be patient. Obviously someone yanked on it. The harness is tightly routed.
10-15-2018, 11:03 PM | #12 | |
1429
Rep 3,007
You can splice the wires and solder them back together. If you have trouble, cut off the plastic shielding with some small cutters or with an utility knife. Then before you solder the wires slide in a tube of heat-shield to cover it all after you done repairing the wire. Electrical tape wrapped around it is also fine.
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor DINAN | EVOSPORT | VAC | ARP | RD SPORT | NEEZ | EIBACH | CSF | IND | BILSTEIN | KLASSEN | BREMBO | ENDLESS | BBS | BPM SPORT | PROJECT MU | EVENTURI |
06-06-2019, 03:10 PM | #13 |
865
Rep 765
Thanks to all who contributed to this simple thread! I got a P0111 code last week and when I searched for the location of the air intake temp sensor, I found this thread. After reading through it we decided to start with just cleaning the sensor first before buying a replacement, and it totally worked. Stuff like this is why I love this forum. It's the little things
DrFerry6731.50 |
02-18-2022, 08:39 PM | #14 | |
Rep 31
This thread was very helpful! Just wanted to contribute my bit |
DrFerry6731.50 |
02-02-2024, 07:12 AM | #15 |
Rep 3
Hi guys, have problem on my M3 with 2nd temperature sensor. Buy new one, same problem. Cable is ok. Anyone have experience? Maybe DME?
DrFerry6731.50 RocketyMan232.00 |
02-02-2024, 09:42 AM | #16 |
Field Marshal
6732
Rep 1,829
Drives: '08 E92 M3
Solving the error will probably become a process of elimination and deduction. Check both ends of the sensor cable connectors for oil, dirt and grime. Then wiggle the cable around and see if a voltage signal results. Some have found sensor cables with broken wires inside them - especially in areas of high heat. Example O2 sensors. Consider replacing the sensor cable just to be certain. So #1 = New sensor. #2 = Clean sensor cable connections and check connectors. #3 = Check sensor cable continuity of voltage conduction when removed from the car. #4 = get a new Sensor Cable? This is all I can think of for the moment. It's also possible the new sensor could still be a bad one. Good luck.
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
///M Power-Belgium64298.00 Frostynorth432.50 |
