06-29-2022, 08:52 PM | #89 |
Rep 2
Sorry for the confusion, the car belongs to a friend of mine who told me it has navigation, but it is inactive. Now I also checked the car has no factory navigation. I apologize once again for the stupid situation.
07-09-2022, 08:21 PM | #90 |
Rep 1
I've gone grey too
Hello (Shawn)
And here I was thinking I was doing so well trying to convert an i3 from Japan to NZ. Hmm, I have ended up in what seems to be same situation as some of the guys here, had Navigation, now it has gone grey (and so am I!). I managed to get the maps updated and when the head unit restarted Navigation was there, for about two seconds, then back to grey. To help: --> Read the state from "3" ECU(s) <-- EPS[DiagAddress=48(0x30)] VX61876 RootCertStatus not available SWSigStatus accepted SWTApplications ---------- AppID 189(0xBD) UpgradeIndex 1(0x01) SWTType SWTclassic light FSCStatus not available FSCCertStatus not available HU_NBT[DiagAddress=99(0x63)] VX61876 RootCertStatus accepted SWSigStatus accepted SWTApplications ---------- AppID 158(0x9E) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ---------- AppID 160(0xA0) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus rejected FSCCertStatus accepted ---------- AppID 222(0xDE) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ---------- AppID 111(0x6F) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus not available FSCCertStatus accepted ---------- AppID 159(0x9F) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ---------- AppID 156(0x9C) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ---------- AppID 229(0xE5) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus not available FSCCertStatus accepted ---------- AppID 170(0xAA) UpgradeIndex 94(0x5E) SWTType SWTshort FSCStatus accepted FSCCertStatus not available KAFAS2[DiagAddress=93(0x5D)] VX61876 RootCertStatus not available SWSigStatus accepted SWTApplications ---------- AppID 126(0x7E) UpgradeIndex 1(0x01) SWTType SWTclassic light FSCStatus accepted FSCCertStatus not available ---------- AppID 190(0xBE) UpgradeIndex 1(0x01) SWTType SWTclassic light FSCStatus accepted FSCCertStatus not available ---------- AppID 191(0xBF) UpgradeIndex 1(0x01) SWTType SWTclassic light FSCStatus accepted FSCCertStatus not available |
07-09-2022, 09:40 PM | #91 | |
10489
Rep 40,980
Drives: 2018 Alpina B6 650ix GC
AppID 160(0xA0) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus rejected FSCCertStatus accepted I have no idea why. What was your process to convert it from Japan to NZ?
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
07-28-2022, 06:13 AM | #92 |
Rep 36
Hi shawn i believe is changing that on bimmercode. I did success on few japan import bmw just by changing the code and install latest nz map by usb enter fsc code. Works perfect. Until i met a 2014 116i from japan and i did everything above but after success installed nz map the navi grayed out. And i have a usb fsc retrofit package for this vehicle. Is that gonna work? fsc certifcate generated from it vin. Everything is stock just changed country code.
07-28-2022, 07:15 AM | #93 | |
10489
Rep 40,980
08-04-2022, 05:47 PM | #95 |
10489
Rep 40,980
It should work same as always.
You need to check FSC Codes, and see if you show A0 or A1, and is it and DE FSC Code accepted?
08-31-2022, 02:20 PM | #97 | |
10489
Rep 40,980
Assuming hardware is installed and working, you need to Code NBT to car, and then use either Emulator with NBT Donor FSC Codes or you need NBT Patch and Full Set of VIN Matching FSC Codes.
10-09-2022, 01:33 PM | #98 |
Rep 3
Hi Shawn, my 2018 G30 has started experiencing the same issue with the Navi where it doesn't get past the loading screen. Every minute or two, the whole iDrive system keeps resetting on its own and tries again. Worst part is my warranty expired 2 weeks ago. I haven't made any mods and it is still in original factory state.
Short VIN is WA74917 Please advise. Many thanks! |
10-09-2022, 01:40 PM | #99 | |
10489
Rep 40,980
10-11-2022, 04:08 PM | #100 |
Rep 3
Nothing at all to my knowledge and I'm the only one that touches the vehicle. If BMW pushed an update, I don't know. It first happened about 2 weeks ago but fixed itself on the next startup, but now it's seems permanent, though, on one trip today the navi loaded after some time.
10-11-2022, 04:37 PM | #101 | |
10489
Rep 40,980
10-11-2022, 05:54 PM | #103 |
10489
Rep 40,980
10-30-2022, 07:32 PM | #105 |
10489
Rep 40,980
PM sent.
11-05-2022, 08:42 AM | #106 |
Rep 3
11-05-2022, 11:04 AM | #107 |
10489
Rep 40,980
PM sent.
12-09-2022, 02:39 PM | #108 |
Rep 25
Hello all, I've just finished flashing my NBTevo from _L to _X and lost Nav and speech rec. Carplay is working fine. Did I loose my FSC codes? Could anyone point me in the right direction.
12-09-2022, 05:10 PM | #109 |
10489
Rep 40,980
Seems so. If you had aftermarket FSC Code solution, you need to reinstall it. If it was old .bin file though, you will not be able to reinstall.
Tags |
greyed out, navigation, voice command problem |
