05-01-2024, 05:58 PM | #1 |
87
Rep 113
universal garage door opener
Has anyone had any luck programming these buttons with your garage door opener? I tried the procedure in the manual a few times but it had no effect.
Fixed-code hand-held transmitters 1. The ignition is on. 2. Press both outer buttons, 1 and 3, for approx. 20 seconds until the LED flashes. 3. Hold the hand-held transmitter a distance of approx. 1 to 3 in/2.5 to 8 cm away from the memory buttons. 4. Simultaneously press the transmit button of the hand-held transmitter and the memory button of the Universal Garage Door Opener. 5. Release both buttons when the LED flashes rapidly. |
05-01-2024, 06:56 PM | #2 |
553
Rep 522
Mine won't work with my garage door either. It seems homelink themselves put a memo somewhere on their website that specified that the mirror buttons will not work with certain liftmaster models.
Mods to date: The list grows...
05-01-2024, 09:09 PM | #3 |
1009
Rep 3,898
Drives: 330i, 135i
Both if my cars had no issues programming with my garage door.
05-01-2024, 11:58 PM | #4 | |
157
Rep 121
Good luck. |
mkeiser471.00 |
05-02-2024, 11:40 AM | #5 | |
144
Rep 118
Strange, My Garage door was just replaced in the last year with a new one and home link works fine with it. Have you tried tilting the mirror towards the opener, or even do the learning with the car in the garage? Ive noticed that if my car is in the driveway and at too much of an angle it the homelink wont pick up the garage door unless I reverse to reposition. |
05-02-2024, 09:26 PM | #6 |
405
Rep 470
Drives: 11 128i 6MT Sport
We just got a new garage door opener with the newer security protocol and I had to upgrade the homelink module in my mirror to get it to program.
This thread talks about the module that came in mirrors on newer BMWs. It was a very easy swap, just picked up a used mirror on eBay. https://www.e90post.com/forums/showthread.php?t=1921544 With the new module it programmed to the opener on the first try using the steps in the first post.
11 128i slicktop
13 WK2 19 Alltrack S |
05-07-2024, 12:20 PM | #7 |
1045
Rep 490
I have a newer chamberlain with MYQ wifi.
The homelink module in my 135i mirror is no longer compatible with the newer security (2.0) protocol. I had to purchase a signal repeater designed to link an older homelink signal to the newer security protocol. Worked like a charm. https://www.amazon.ca/LiftMaster-855...15addf338fccf5 |
GoRomeo1008.50 |
05-08-2024, 11:50 AM | #8 |
128
Rep 366
Drives: bmw 135is
It took at least 1/2 dozen tries using the steps in the manual. Later tried to program my father's garage door opener to the 1er, but gave up and bought a second door opener.
05-08-2024, 01:34 PM | #9 | |
725
Rep 331
05-10-2024, 08:32 AM | #10 |
180
Rep 264
For some unknown reason, the #1 button refused to link up. However, it did couple when I tried the #2 (middle) button. On my F10, the #1 button works fine. Go figure.
05-10-2024, 12:26 PM | #11 |
391
Rep 926
Drives: G12 750Li
I actually have a good insight on this!
I recently installed a home link 4 compatible module to my e38 750 which had home link 3. Home link 3 cannot do rolling codes which are a part of the newer security protocols. As far as I’m aware, since our cars last year is 2013, that is the first year of many of the new garage openers having the rolling codes. As a result, I had to pull a mirror from an f01 post 2013 with certain part numbers and then unsolder the old buttons, solder the new buttons and reinstall. Here is the diy from the m5boardsif you’re curious. https://www.m5board.com/threads/home...others.617663/
-2017 G12 750Li "Giulia"
-2014 F32 428i Xdrive "Bella" -2013 E82 128i "Austin" -2000 E38 750iL "Stella" |
05-10-2024, 05:20 PM | #12 | |
725
Rep 331
spidertri405.00 |
