BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F34 3-Series GT (Gran Turismo) Forum > Rear differential fluid change for F34
proTUNING Freaks
      04-21-2024, 02:33 PM   #1
BE55
Drives: 16 335iX GT
Is it doable without removing pull rods?
      04-21-2024, 11:19 PM   #2
Jetnoiz
Drives: BMW 330i GT F34
Interestingly, I was under the rear differential today wondering about this too. I connected the following tools to access the plug:
Extension rod connected to half inch ratchet
Universal joint
14mm allen/hex socket
I stopped because I want to make sure there were no separate drain and fill plugs, correct? Additionally, I want to purchase new plugs with fresh seals before starting the procedure.
I look forward to additional replies.
      04-22-2024, 05:11 AM   #3
Vortex8
Drives: BMW GT 328xi
There is only a fill plug, and it should be refreshed when changing the fluid so good thinking there.
You are lucky that you can access it without removing the rods. I have a vibration damper in the way and in order to get that one out I need to pull the rods, because I can't reach the damper screws otherwise...
      05-01-2024, 11:07 AM   #4
chr15gb
Drives: 2014 F34 335i
How are you guys getting the oil out?
This is a job on my list of things to do.
I have an oil extractor I used to use for oil changes (no use to me now with no dipstick). I'm thinking of getting a small copper pipe I can bend to make a horseshoe shape to get into the bottom on the Diff. Then use the oil d extractor to suck the old oil out.
      05-01-2024, 11:35 AM   #5
Mkesler75
50
Drives: BMW f34
That’s exactly what you do. I did both from and rear of my 2015 GT xdrive. Had no issues w access.
