Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - California > anyone pass smog recently?
      05-01-2023, 04:51 PM   #1
bobbby
Bobbby
32
Drives: 2011 bmw 335i sedan
Need to pass smog soon. My car is tuned with MHD stage 1 and xHP stage 3. Just wondering if anyone with similar mods passed the newish smog test that also checks for ECU tunes.
Can I just run stage 0 mhd or do I have to flash back to stock? Also do I have to flash my transmission back to stock?
TIA
      05-01-2023, 05:41 PM   #2
ghostENVY
Drives: 328i 2011 e90
I'm due for a smog check in the next couple of months in CA.
Honestly just from a programming perspective, I feel the checksum of the original firmware will be checked against, therefore I believe stage 0 should theoretically still fail, but what do I know.
I'm planning going back to the stock firmware and removing my charge pipe/tial and also referring PCV and Oil catch cans.
      05-02-2023, 12:14 PM   #3
R3dLeader
154
Drives: e92 and e93 335i
Flash back to stock with MHD and put your cats back on.
      05-04-2023, 07:00 PM   #4
bobbby
Bobbby
32
As an update here, flashed back to stock completely, removing MHD. Drove around to get the monitors into complete and was able to pass smog today.
Only mods are MHD, xHP (flashed also back to stock, leaving xHP still installed on car), aftermarket chargepipe/fmic
Now back to reinstall MHD! Good til 2025
Appreciate 3
Jeff S30.00
2one3E902422.00
      05-15-2023, 02:27 AM   #5
2one3E90
2one3E90's Avatar
2422
Drives: Bmw 330i and Bmw 328i
2010 BMW 328i  [10.00]
2004 BMW Z4   [9.67]
2006 BMW 330i  [10.00]
stock cats also?
      05-15-2023, 07:07 PM   #6
SAADTHESAV
SAADTHESAV's Avatar
267
Drives: '18 SMB F80 M3 CS
Yeah I'm trying to sell my '09 3 series and it's not registered because I can't pass smog with no secondary cats
So I need to find a cost effective way to restore my secondary cats and pass smog lol
      05-15-2023, 07:30 PM   #7
StradaRedlands
StradaRedlands's Avatar
4966
Drives: 2006 BMW 330i MT
2006 BMW 330i  [8.21]
2009 BMW 328i Touri ...  [7.90]
2013 BMW X5 35i  [7.63]
2011 BMW 528i  [8.75]
2006 Mazda3  [5.50]
Is leaving xHP active/on fine for passing CA smog?
      05-16-2023, 09:55 PM   #8
bobbby
Bobbby
32
Originally Posted by 2one3E90 View Post
stock cats also?
Yes Stock cats
      05-16-2023, 09:57 PM   #9
bobbby
Bobbby
32
I left it on, but put it to stock tune
      05-17-2023, 08:41 AM   #10
Ion619
Ion L.
Ion619's Avatar
29
Drives: 2009 335i & 2018 X1 & 2016 X1
I'm due soon too... been thru this many times with my 09 E90...
Gotta put back stock cats and completely uninstall MHD...
For some reason, flashing back to 0 isn't sufficient enough...
The "monitors" will not "complete" after driving many miles...
Good Luck!
///Minor Mods///
      05-21-2023, 01:18 AM   #11
Mseg
Drives: e90
I went through the same thing earlier this year. To fix it, I bought CARB approved secondary cats for my 325i, Walker Exhaust CalCat Carb 84205 Universal Catalytic Converter, through Amazon. They have an CARB EO stamped on them and they're cheap. I then paid an exhaust shop to add them back. The Smog Tech looked at them and put the EO in his computer and passed me.
      05-21-2023, 01:29 AM   #12
SAADTHESAV
SAADTHESAV's Avatar
267
Wow this is clutch. I'm guessing depending on your exhaust they might have to weld a part on? Or is it usually as simple as cutting the pipes where the catalytic converter is and then installing the Walker exhaust catalytic converter fromm Amazon?
      06-21-2023, 05:16 PM   #13
Mseg
Drives: e90
Sorry for not getting back to you sooner. The exhaust shop had to cut my piping and weld the cats back on. I had changed my exhaust in that area to a single pipe, and they needed to change that section back to double pipe to put the new cats on. It was a little over $400 for install.
      01-19-2024, 09:14 PM   #14
blackx1x35
Drives: 2014 X1 xdrive35i
Hello, just moved to the state and looking to get my car registered. When I originally installed MHD, I had to remove the DME and send it off to a shop to flash on a bench. Did you do the same process? I am wondering if I will have any issue re-installing MHD.
I am aware you no longer have to bench flash to install MHD, but at the time if you removed MHD, you had to redo the bench flash. I am hoping someone can confirm that I will not have to do this if I want to re-install MHD.
Thank you.
      02-11-2024, 02:55 AM   #15
BMWdmk
*Rollin 3rd*
BMWdmk's Avatar
106
Drives: Something fast
Flash to stock (no questions asked you must do this)
Put c. converters on
Don't have codes that trigger check engine
Check Monitors after xx miles to makes sure everything reads complete
(options for monitors is ready, not ready, incomplete)
Everything needs to be complete/not available. Evap monitor can be incomplete
if you get fuel pump plausibility code dont clear. common shadow code is fine.
permanent codes take time to clear dont jump the gun. get mopnitors ready.
follow these parameters and your setup for success except for visual inspection. Google that one if needed
