09-18-2015, 08:53 PM | #1 |
50
Rep 208
Best Headlight bulbs for F30?
Hello,
Im looking for the best lightbulbs for my car because the standard halogen bulbs aren't cutting it. I prefer a white color maybe even a bluish white. Ive been looking around and I found the Sylvania ZXE bulbs and was wondering if anyone else has them and what they think of them. There are also some LED bulbs but they say its a conversion kit. Any help would be appreciated! |
09-19-2015, 08:10 AM | #2 |
Self-Deprecating Narcissist
7266
Rep 6,561
Philips X-Treme Vision.
09-19-2015, 08:11 AM | #3 |
1838
Rep 6,991
Drives: 15 F80 M3, 22 G01 X3 30i
PIAA Super White. You're looking for a Kelvin temp rating of 6000-8500. The higher the "K" rating, the more blue they'll become. 6000-6500K is probably optimal, and I think that's what the PIAAs are rated at.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
09-19-2015, 08:26 AM | #4 |
41
Rep 241
I like my phillips diamond visions - DO NOT buy the ZXE's, I had them originally and they are barely any whiter/bluer than stock. If you want the HID look go with the diamond visions, amazon has them for a decent price. I ended up moving the ZXE's to my high beams.
09-19-2015, 08:29 AM | #5 |
7266
Rep 6,561
Look for Lumens vs kelvin. Kelvin will give you a way to gauge light color but Lumens is actual light output. The Philips X-Treme Vision bulbs are 5000k (4800k Actual) and 3200 Lumens.
09-19-2015, 08:30 AM | #6 |
132
Rep 700
I wouldn't suggest doing the led bulbs either. I ran them for about 2 weeks and ended up taking them out. Output was great on them, just doesn't much care for the beam pattern
09-19-2015, 08:38 AM | #7 |
41
Rep 241
Im pretty sure the x-treme visions are 3700k and the diamond visions are 5000k. I could be wrong though, it happened one other time a long long time ago.
09-19-2015, 09:48 AM | #8 | |
7266
Rep 6,561
6000k is going to be blue... anything over 5000k is going start turning blue anything over 8000k is going to start turning purple and 1200k is basically pink. the higher the temp the lower the lumens. general rule of thumb is higher temp less usable light/lumens.
09-19-2015, 10:10 AM | #9 |
50
Rep 208
Thanks for all the replays I'm going to look at the diamond visions as well as the extreme visions also are bulbs universal or are there certain models for BMWs? If the temp of the bulb is higher does that require a heat shield or anything?
09-19-2015, 10:43 AM | #10 |
7266
Rep 6,561
temperature of the bulb doesn't translate into literal heat of the bulb. wattage does. iirc the f3x platform uses D1S. all D1S are 35w.
09-19-2015, 11:08 AM | #12 | |
8279
Rep 16,143
Standard H7: 55w, 1400 lumens, 500 hours H7 ultra "Plus+50" (any brand): 55w, 1580 lumens, 225 hours H7 Xtreme "Plus+80" (Philips) or "Plus+90" (Osram): 55w, 1620 lumens, 200 hours H7 rallye+65 (Osram only): 65w, 2100 lumens, 500 hours The Osram is the clear winner. Not DOT approved, but that's a strange technicality, as they're no brighter than zenon. They're 65w but won't cause any wiring issues, and are far less expensive than zenon or LED that require a full conversion kit. This is the only US source that I'm aware of: http://store.candlepower.com/osraulhiouh7.html |
09-19-2015, 11:10 AM | #13 | |
7266
Rep 6,561
I forgot that some F3x have standard Halogen bulbs. Do not exceed 65w or you will melt your housings. Most of the cheap ebay/china crap is 80-85w and horrible for your housings. Do not do HID upgrade kits either if you do not have projector headlights. The beam pattern and the way the light is cast with HID bulbs is meant for a projector. If you use this type of bulb in a standard headlight you will get a wide cast of light that doesn't really do anything except blind on coming traffic. IIRC a D2R style headlight bulb is for use in non-projector headlights but double check because I am not sure 100% and never had to do this type of retrofit.
09-19-2015, 11:13 AM | #14 | |
50
Rep 208
09-19-2015, 11:17 AM | #15 | ||
50
Rep 208
09-19-2015, 12:02 PM | #16 | |
7266
Rep 6,561
09-19-2015, 12:20 PM | #17 |
50
Rep 208
These are the xtreme visions you're referring to?
http://www.amazon.com/gp/aw/d/B00QJW...umL&ref=plSrch |
09-19-2015, 02:09 PM | #18 |
16
Rep 190
Don't forget if you get higher temp lights in low beams (whiter). The parking lights will still be yellow so will need to change those to match. I used diamond vision for low beams and LEDs for parking lights.
I tried crystal vision first. They are whiter but barely to stock so moved them to high beams.
Bernina Grey Amber Effect 21 540 Msport
Carbon Black/Cognac 21 X3 x30i M sport Black Sapphire 14 328Xi M sport |
09-19-2015, 02:15 PM | #19 | |
8279
Rep 16,143
09-19-2015, 08:11 PM | #20 | |
41
Rep 241
http://www.amazon.com/gp/product/B00...f_rd_i=desktop |
09-19-2015, 08:22 PM | #21 |
8279
Rep 16,143
09-19-2015, 08:58 PM | #22 |
7266
Rep 6,561
code them to be off like they are in other regions. indicator will still work and you don't have the gross amber lights.
