08-29-2020, 08:56 AM | #1 |
240
Rep 147
Drives: BMW X1 U11 Sdrive 18i
Lower with H&R springs
Hi to all community.It needs a little bit more to make the exterior more aggressive.This time i choosed the H&R spring set with 30mm lowering.The difference was so huge with the oem set both on height and in turning.
Enjoy with photos [IMG]undefined[/IMG] |
08-30-2020, 07:46 AM | #4 | |
427
Rep 348
I would think that the m135i springs would fit the m235i but not certain. |
MrFoxy376.50 |
08-30-2020, 03:54 PM | #5 |
240
Rep 147
Thanks a lot mate.The front lip came from Maxton Design
08-31-2020, 03:11 PM | #6 |
102
Rep 94
You're lucky, you must live in an area with very few or no speed humps, unfortunately I struggled with lowering springs, just too many undercarriage scrapes on too many speed humps which some are quite high, in London where I live, so took them off 😒
Setright20.00 |
09-01-2020, 07:39 AM | #7 |
427
Rep 348
Jeez you would think by now they would be putting lower and longer humps
09-10-2020, 02:11 AM | #8 |
Car go brum
Rep 5
H&R have just released springs for the F44 M235i. However, I asked them about the F40 M135i and they said they currently don't support this model. What springs are you using Spyros E81 ?
Anyone know if the springs specifically need to be made for the XDrive system to cope with extra loads etc or could we use the same springs used for a 118i without issue? |
09-11-2020, 04:45 PM | #9 | |
240
Rep 147
I don't want to make a promotion but from this site you can find your set.https://www.sandtler24.de/#/dfclassi...name=match_and |
09-11-2020, 07:12 PM | #10 |
427
Rep 348
That's really good that you can choose the lowering height. I'm guessing you can choose between 35mm to 30mm total drop height?
I only had one option with eibach.. 40mm drop for Australian cars.. only one opinion |
01-04-2021, 04:18 PM | #11 | |
Rep 7
cacacaren
02-12-2021, 02:28 PM | #12 | |
Rep 14
I am needing a set for an F40 M135iX Springs are 28635-1 OR 28635-2 Also do you know the weight of your front / rear axle? If you use 28635-1 (max. 1050 kg front axle load). If you use 28635-2 (1051kg and heavier). Last edited by 1MFaN; 02-12-2021 at 02:35 PM.. |
02-14-2021, 11:25 AM | #13 | ||
240
Rep 147
03-27-2022, 04:20 AM | #14 |
Rep 1
Hi. Is there any significant difference in stiffness after changing the springs?
11-07-2022, 10:41 PM | #16 |
Rep 15
Camber bolts
Hey guys,
I just bought a set of H&R for my F44. I noticed camber bolts can't be used as the struts are attached from the base. Did anyone add camber adjustable arms, front and rear? Is camber an issue? Drop isn't huge, but want to ensure I have all I need before installing the springs. Any feedback would be great. Thanks. Last edited by hgalanos; 11-07-2022 at 11:59 PM.. |
11-10-2022, 03:07 AM | #17 |
27
Rep 151
11-29-2022, 09:17 PM | #18 |
Rep 6
I just put HR springs on my '22 M235i. Part 28635-2
Ride is not bad but definitely more feel to the road. Love the way the car sits now. Before/After
1998 E39 528i
2003 E46 M3 2004 E46 328cic 2022 F44 M235ix |
Setright20.00 |
05-26-2023, 01:23 PM | #19 |
13
Rep 9
