02-07-2020, 08:48 AM | #1 |
Rep 3
Coding an F40
Hi I need some help coding my F40. I searched around don't seem to find enough information on it so I 'm thinking to follow the G20 walkthroughs I found since both seem to have the same arcitecture. Any ideas?
02-08-2020, 03:10 AM | #3 |
Rep 3
Hi. I just want to know if there is someone that has coded an F40 and what has been done. Or if there are any cheatsheets that I can use to code mine. I tried to use one I found for an F30 but there are many different things.
03-29-2020, 04:39 AM | #4 |
377
Rep 416
03-29-2020, 01:59 PM | #6 |
238
Rep 147
Drives: BMW X1 U11 Sdrive 18i
The solution is the Bimmercode app.Buy a compatible adapter to OBD port ( you will find the right adapter to your car in the app) after download the app and then you can find some codes that you can do.
MrFoxy376.50 |
03-30-2020, 06:41 AM | #7 |
377
Rep 416
03-30-2020, 06:48 AM | #8 | |
377
Rep 416
03-30-2020, 07:10 AM | #9 | |
417
Rep 339
I have used it before on my f30 to code stuff like start-stop off, brake lights flash at slow speeds etc but I don't think it can control the exhaust valve controller. You can code 'sound design' on and off but that's about it. I think for what you're after.. coding 'pops and bangs' you might need a different coding tool. On a separate note. I have disconnected my exhaust valves. It's a simple mode. Takes about 5 minutes to do. |
MrFoxy376.50 |
03-30-2020, 07:14 AM | #10 | ||
377
Rep 416
03-30-2020, 07:26 AM | #11 |
417
Rep 339
You need to have the car running, put it in sport mode, check or listen to hear the exhaust value open,
Under the left side of the exhaust outlet there is a connector that controls the valve. You need to disconnect it and that will keep the valve open always. There are a few YouTube clips that step you through this. |
03-30-2020, 07:37 AM | #12 | |
377
Rep 416
Have you done this on your F40? |
03-30-2020, 10:24 AM | #13 |
951
Rep 1,642
03-30-2020, 11:07 AM | #14 | |
377
Rep 416
Iv just 2mins disconnected my valve actuator lead in sport mode.... sounds way better now |
03-30-2020, 11:26 AM | #15 |
951
Rep 1,642
03-30-2020, 12:04 PM | #16 | |
377
Rep 416
No pops/bangs, but ill not know till I take it out. |
04-04-2020, 03:19 AM | #20 |
General
17483
Rep 25,112
What's easy entry exit sorry?
04-04-2020, 09:24 AM | #21 |
7
Rep 43
If your car has electrical driver seats and memory the function gives you more space to get in-out of the car easier via adjusting the driver seat position back and low, after sitting the driver seat when you push the engine start button it adjusts the seat to your memory position automaticly.
JustChris17483.00 |
04-04-2020, 10:20 AM | #22 | |
General
17483
Rep 25,112
