10-21-2021, 04:33 PM | #1 |
28
Rep 65
Adaptive headlights not turning (no codes)
I just replaced both of the SMC modules (both were corroded and giving error codes) and coded them in with PROTOOL but the lights still wont turn left or right...
I notice when I start the car the lights do move up, adjusting up a bit. I re-coded both the left and right to see if that would fix the issue but no luck. Any ideas? Thank you, Chef |
10-22-2021, 02:57 AM | #2 |
456
Rep 2,749
do you remember that they are turning only when light switch is in auto mode ?
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
10-22-2021, 09:31 PM | #4 | |
28
Rep 65
I could have sworn before when they were working they moved both directions when I turned the wheel left or right, respectively. I do keep my lights in Auto Mode, yes. |
10-22-2021, 10:20 PM | #5 | |
969
Rep 537
That would be totally incorrect. Left and right.
You would be correct. |
tracer bullet2413.00 |
10-28-2021, 08:01 AM | #10 | |
969
Rep 537
Solution - take it to your dealer if they work on older 3-series cars (some don't) or your independent. It probably could have been fixed by now. The #1 rule that works "for me" is - don't try to be a German-car mechanic if you're not a German-car mechanic. There are too many interconnected electronic items on newer cars. #2 is - Don't buy an older German car without setting aside $1,000-$2,000 a year for professional maintenance. Not total - per year. You will eventually need it. Last edited by DenverSteve; 10-28-2021 at 08:06 AM.. |
Pauldunlop13425.00 |
11-03-2021, 12:13 PM | #11 | |
28
Rep 65
Looking for additional input from EXP wrenchers. |
11-03-2021, 12:45 PM | #12 |
969
Rep 537
Yeah. As you've already figured out - being German hasn't helped yet.
11-03-2021, 12:49 PM | #13 |
1243
Rep 1,288
11-05-2021, 02:17 PM | #14 |
28
Rep 65
Neither has these forums, ironically. And I would never pass my car to a 'mechanic', that's insanity. I do ALL my own work, no matter the difficulty level. Funny how refreshing the Transmission is easier than figuring out why my lights wont move.
11-05-2021, 04:59 PM | #16 |
Loves me some MHD!
1858
Rep 1,719
Chef,
Is this correct- -You replaced the smc modules -You coded with protools -You then had no codes, but no l/r movement -You then recoded with protools with no change to the symptoms Presuming still no codes OK then, what else have you tried? Verified mechanical function is correct? Checked the coding with anything else but pt? Located a donor set of lights to test with, to really verify yours aren't borked? Verified wiring is all good? I'm guessing you've actually done all those things already, cause I'm sure a hotshot wrench like yourself isn't asking to be spoonfed. Yes, that was meant to sound bitchy. Hey, I don't know what the heck is up with your lights, and I do my own wrenching too. But if my headlights were doing the same thing I'd be a lot more active to get it fixed than pestering a forum two weeks later. If you are leaning in on coding, why not alter the approach and look into what coding to review, and which tools are best to investigate with? You know, instead of asking what's wrong. I'm not a coding hotshot and have no idea where to look or suggestions to offer, but, again, if it were me that's probably what I'd be doing. And I'm not kidding about a donor set of lights to test with, you'll know instantly which half is borked, hardware or software.
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla . . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg |
