BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding Emergency call battery fault. DIY?
      12-10-2022, 01:57 PM   #23
Hansie530
Drives: BMW 530i
I just replaced it yesterday in my 2017 530i G31, without removing the headliner. Just trough the speaker hole. It is small but with some long screwdrivers and the batery taped to one of the screwdriver I replaced it in about 10 to 15 minutes.
      12-11-2022, 06:34 AM   #24
Gee44
Drives: Bmw 520d Msport
I’ve had the same message and if I remove my battery and warm it up it clears for a while so pretty sure it’s the battery. Bought a new one and replaced but this doesn’t clear the message. Had it in the car for a week to see if it needed charging or something but message there permanently. Just warmed my old battery up and swapped and message cleared straightaway.
The part numbers are different on the new battery but they said this was the replacement. Is it possible the new battery is faulty, or as it’s a new battery would the fault need resetting through a computer.
      12-11-2022, 07:29 AM   #25
Hansie530
Drives: BMW 530i
I did a reset. My number is also different. After installing the new one the message was still there. Only after a reset it was gone. But I did the reset shortly after the installation. I didn't wait if it disappears automatically.
If I measure the old one it still had 8V. The new one, probably not completely full had a lower voltage.
      12-11-2022, 07:54 AM   #26
666dam0
Drives: BMW G31
Hi,
My G31 started with this a few days ago, I did the same as you to get the battery out via the roof mounted speakers... I also unclipped the roof lining right at the back to help with access. Having no luck finding one online with the part number on my battery 9 361 678 03. Where did you get your replacement from and if you don't mind me asking how much was it?
      12-11-2022, 10:14 AM   #27
Gee44
That’s the same number as on my original battery. The replacement is 84102447710. Bought from Bmw and it was £62.
      12-11-2022, 10:16 AM   #28
Gee44
How did you do do the reset?
      12-11-2022, 10:17 AM   #29
Gee44
Seems strange that my original battery will clear the message if warmed up to rejuvenate it a little but the new battery doesn’t do anything.
      12-11-2022, 11:15 AM   #30
Gee44
Update on this puzzle. Went out to the car to remove the original battery and warm it up again to sort of determine it’s the battery, removed the battery and then opened drivers door and no error message appeared even without the battery installed. Fitted the new battery and no error messages.
See what happens in the morning. I thought without the battery installed it should show the error.
Love these cars but these little issues try me ��
      12-11-2022, 01:10 PM   #31
Hansie530
Drives: BMW 530i
Originally Posted by 666dam0 View Post
Hi,
The replacement was 84102447710. I ordered online at a Dutch dealership.
https://bmwshop.ekris.nl/nl/zoeken-o...ch=84102447710
I paid 63.66 Euro. Free delivery in my country.
If you search on 84102447710 you will find several hits.
(BTW. The number you mentioned is the same as the one I removed.)
      12-11-2022, 01:13 PM   #32
Hansie530
Drives: BMW 530i
I have a simple Carly adapter. But I will not advise you to buy this. You will pay anualy a supscription. I found out to late I had to pay anualy so I paid already twice
      12-12-2022, 09:42 AM   #33
666dam0
Drives: BMW G31
Perfect, thank you... I've found this one on eBay
https://www.ebay.co.uk/itm/194908006...mis&media=COPY
It's from a BMW garage in Paignton I think, they've confirmed it fits my model. Funnily enough the error was on my car this morning when it was -7 its now gone at -0.5.
      12-12-2022, 04:20 PM   #34
Dephead2004
180
Drives: G30 520i
Or this one a bit cheaper
https://www.ebay.co.uk/itm/Genuine-BMW-Telecommunication-TCB-Battery-84102447710-F20-F21-F30-F311-F32-F33/284793206733?hash=item424eff77cd:g:i7gAAOSwCWJibVM O&pageci=f3e1da89-b299-45a3-8ef9-0ca56f4ab831&redirect=mobile
      12-12-2022, 06:11 PM   #35
Maxx Power
Member
Australia
54
Drives: 2019 BMW 530d g30
I too am trying to replace the battery from my g30.
The number on my old battery is also 9-361-678-03, however, it seems all the batteries you guys are linking to only have a 330mAh / 2,64Wh capacity, where my old battery was 450mAh / 3,6Wh...?
There also seems to be a few with a production date from 2016..?
      12-13-2022, 01:28 AM   #36
Dephead2004
180
Drives: G30 520i
Looks like a downgrade but probably isn't. I checked with listers and vines ( bmw dealers) and they confirmed that my vin matched the part number posted.
      12-13-2022, 01:30 AM   #37
Dephead2004
180
Drives: G30 520i
I'm on 5 years and 30k miles but I do think the cold (-5 degs) pushed it over the edge
      12-13-2022, 02:34 AM   #38
Maxx Power
Member
Australia
54
I am on 158K km, and we currently have 37 degs C so I'm not sure it is the cold weather..
      12-13-2022, 04:42 AM   #39
McBride
McBride's Avatar
131
Drives: G31 M Sport +
Since I posted, my error message has come and gone every few days so I’ve not done anything about it yet. Probably a job to tackle over Christmas.
Called at Sandal and got a quote for the part to make sure I order the correct one. It was 84102447710, as said by someone else it’s £52.09 +vat.
For the cost difference I’m not going to shop around and just get it direct from them, that way if there’s any issues with compatibility I can blame them for giving me the wrong part.
I have read on other forums about people having the error message coded out as it wouldn’t clear on its own. Maybe find a BMW specialist and give them a few quid to clear the codes?
Is it wise to order a trim removal tool for the speaker covers or will a screwdriver suffice?
      12-13-2022, 11:09 AM   #40
Gee44
If it’s a saloon then a screwdriver will suffice. Pull down the panel at the rear of the headlining, pull either side of the headlining down ,at the exposed area, clip either side, and if you put your head right back you can see the module. Small terminal screwdriver to unclip the battery which is on the right hand side. Job done.
      12-13-2022, 10:50 PM   #41
Maxx Power
Member
Australia
54
Called my local dealer here in Oz and they also confirmed that BM-84102447710 is the correct part. However, as they are short on stock they are charging A$240 (132 pounds / US$164).
Does anyone know if the ones they sell on AliExpress are any good..?
Eg: https://www.aliexpress.com/item/1005004948959056.html
      12-14-2022, 01:41 AM   #42
Dephead2004
180
Drives: G30 520i
Avoid for the same price as uk. No comeback. Anyone can open an old box and put Li batteries in. Not worth risking a car for that. Try shipping from uk. One dealer said they always keep stock. Must be a problem part
      12-14-2022, 01:59 AM   #43
Hansie530
Drives: BMW 530i
I used a plastic tool that I also used for opening a phone. For a G31 open the speaker cover from the car front side, not the back side.
      12-19-2022, 03:19 PM   #44
Dephead2004
180
Drives: G30 520i
Originally Posted by elvir79 View Post
just buy a new one
Did that. Now it's warmer (+20 degs C in a day) the warning has gone. Spare battery, anyone?
5post
