10-11-2012, 07:45 AM | #2 |
501
Rep 1,399
A half inch more of width should not be a problem, the more important question is the offset of the wheel you're looking at. You would want at least the same offset as the stock wheels, if not less if you plan to go with a wider wheel. Here's a good website for calculating how different widths and offsets will affect clearances:
http://www.1010tires.com/WheelOffsetCalculator.asp
Current: 2022 Donnington Grey M5 Competition, 2014 Anvil WW Jeep Wrangler
Previous: 2019 Donnington Grey M5 Competition, 2016 Silverstone M5 CP, 2013 Monte Carlo Blue M5 CP (ED on 9/1/12), 2009 Carbon Black M5, 2006 Silverstone M5, 2003 Sterling Grey M5, 2000 Anthracite 540i6, 1998 Jeep Grand Cherokee 5.9Ltd, 1990 Eagle Talon TSi AWD, 1978 Mazda RX-7 Last edited by AGS; 10-11-2012 at 03:01 PM.. |
10-11-2012, 09:32 AM | #4 |
501
Rep 1,399
Here is the description of offset from the glossary on the website I linked above:
"The offset of a wheel is the distance from the mounting surface of the wheel to the true centerline of the rim. A positive offset means the mounting surface of the wheel is positioned in front of the true centerline of the rim / tire assembly. This in effect brings the tire in to the fender well more. Conversely, a negative offset means the mounting surface of the wheel is behind the true centerline of the rim / tire assembly. This will cause the tire to stick out away from the vehicle." I think the words make more sense when you look at the diagram from the website (see below). So a positive offset means the mounting surface of the wheel is father towards the outside of the wheel well than the center line of the wheel. The larger the number for a given wheel, the more the wheel will move inwards towards the body of the car. The front offset on the stock wheels is 32 for the 19" wheels and 34 for the 20" wheels. So for the 20" wheels, to have the same inner clearance as stock you will need a 9.5 wheel with an offset of 28.
10-11-2012, 03:01 PM | #5 |
BMW obsessed
9596
Rep 10,888
We have used a 9.5" wide wheel in the front of the car, with good results. We used a 265/35-20 tire as our client chose to maintain the original tire sizes, but a 275 is possible as well. Our 9.5" wide wheel has a +24 offset, and fits nicely as shown in the photo below:
10-12-2012, 12:42 PM | #6 |
19561
Rep 10,192
ILIA anymore pics of that AW F10 M5?
Or a link?
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
10-16-2012, 01:30 PM | #7 |
2872
Rep 11,374
10-20-2012, 01:10 AM | #8 |
72
Rep 354
The higher the offset the more the wheel sits inside the fender
The lower the offset the more agressive the wheel sits out
10-28-2012, 12:42 PM | #9 |
338
Rep 2,940
You know more than you think. Higher number means that the mounting face of the wheel is a greater distance away from the centerline of the wheel. You are absolutely correct !!!
Audi S6 * Audi S3 * Porsche Cayman GTS
--Former BMW M3 owner |
11-13-2012, 11:54 PM | #10 | |
Rep 43
Any info on the rear width and offset used? |
11-14-2012, 08:19 AM | #11 |
BMW obsessed
9596
Rep 10,888
We used a 20" wheel, 10.5" wide, with a +30 offset in the rear. This was a good "reasonable" fitment, in that it was a good balance in terms of proximity to the quarter panel- not too close, but close enough to give an aggressive look.
