03-03-2020, 06:22 AM | #89 |
1542
Rep 3,332
Has anyone crashed a GTS or CS yet? I recall people saying you couldn't order the hood directly unless you had a CS Vin (maybe a nearby forum member can be your proxy)
03-03-2020, 11:05 AM | #90 |
Rep 4
Once the CS came out the hood was no longer restricted to GTS owners. I've had one on my M3 for over 2 years now. Its almost 10 lbs lighter, can't comment on if it helps cooling any.
243Racing1447.50 Corsa Motorsport179.50 |
03-03-2020, 12:00 PM | #92 |
705
Rep 870
Not sure if this helps or not but last time out a chuckwalla with high 60/ low 70 ambient temps my GTS didn't see inlet temps over 86 degrees(according to an awron gauge via the obd2 port). Albeit I'm sure your car (and you) are much much quicker and pushing a lot harder but I haven't seen much conclusive data that larger heat exchangers/intercoolers help that much with thermal management. I think retrofitting water/meth injection in some form (oe or aftermarket) is the best bet for how hard you push your car.
I also think, as you mentioned, better heat extraction out of the engine bay would definitely improve overall cooling. As always, sweet build and even better write ups detailing your experiences. |
03-03-2020, 12:06 PM | #93 | ||
180
Rep 71
03-03-2020, 12:07 PM | #94 |
180
Rep 71
Haha, what's his name? I've been deep in the S2K community for several years now coming from a previous S2K shop.
03-03-2020, 01:16 PM | #95 | |
180
Rep 71
MSteve5036124.50 |
03-03-2020, 01:17 PM | #96 | ||
705
Rep 870
03-03-2020, 09:16 PM | #97 | |
125
Rep 713
03-03-2020, 09:40 PM | #98 | ||
180
Rep 71
MSteve5036124.50 |
03-04-2020, 12:40 AM | #99 | |
1019
Rep 859
243Racing1447.50 |
03-04-2020, 10:16 AM | #101 |
125
Rep 713
Yup. He has been trying to convince me to get to a track day out there. Hopefully someday, but it is a bit of a trek!
03-04-2020, 04:05 PM | #103 |
180
Rep 71
03-04-2020, 04:45 PM | #104 |
705
Rep 870
Awesome. Thanks for the data.
03-04-2020, 08:33 PM | #105 |
180
Rep 71
Post Buttonwillow
I had the cooling system pressure tested to ensure everything was working properly with no issues. It checked out fine, and I proceeded to have the coolant flushed and bled while I was at it. The CSF product is installed well and no issues there. Upon further contemplation and discussions with my good friends Reggy, of Irvine BMW, and Dom, of GMG Racing: They suggested the plugs could be the issue. I had swapped the plugs to NGK 97506 one step colder gapped to .20 when upgrading downpipes and installing the tune. With the engine back to stock, I will experiment by reverting to the factory BMW plugs part number: 12-12-0-037-607 and see if that alleviates the random drivetrain malf. The plugs are ordered and we will install them here first thing tomorrow. OH, and I was glad to find (not really) that I had bent two of my TE37s. Luckily they can be repaired to balance out perfectly, but I suppose the car isn't liking my abuse very much. Photos of the scraped differential cooling fins, after it along with the exhaust made contact with the tarmac after jumping a kerb. |
03-04-2020, 11:47 PM | #106 |
Destroys tires
Rep 20
A+ thread. I knew you weren't playing when I saw the knipex pliers
03-06-2020, 03:02 AM | #107 |
Rep 13
What a fantastic thread, thank you for sharing it all in such a professional fashion!!
The limp mode drivetrain malfunction: How much fuel are you running? I always keep mine above half a tank as it suffers from fuel surge and also gives the same errors and limp mode. You can monitor all temps by simply using the BMW Mperformance drive analyser. About £100 here in UK. IAT: Apparently at 80-85c the car will go into limp mode so unlikely this is the issue. With a stage 1 tune on track mine will creep to just under 60c, an M2. Comp with csf coolers just under 70c under race conditions and hot weather, an M4 with a lot of power and Mishimoto coolers hits 50c running up to 200 mph. I really feel your frustration as I’m certain that if you’d left the car stock you wouldn’t be having these issues. Or, it’s fuel surge. Fingers crossed going back to the stock plugs could solve it too. If you’re really desperate just put it all back to stock then start from there. |
03-06-2020, 12:42 PM | #108 | |
180
Rep 71
sly1types431.50 |
03-06-2020, 03:29 PM | #109 | |
///M Powered for Life
11500
Rep 10,333
It's a ridiculous problem to have. Hopefully someone brings up a solution to this before long |
