BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 Marketplace > SPONSORS Classifieds/Groupbuys/Specials Area > Suspension | Brakes | Chassis | Handling
      08-26-2015, 10:33 AM   #1
IND-Distribution
BimmerPost Supporting Vendor
IND-Distribution's Avatar
9591
Drives: G82 M4 / G87 M2
IND | Fall Line Motorsports E9X M3 Rear Camber Shim Kit
When setting an M3 for high performance driving, properly setting the rear camber and toe will yield significant results. The factory eccentric suspension bolts have a reasonable amount of adjustment range for a variety of ride heights and possible alignment settings, but are not a perfect solution.
Eccentric bolts are adjusted by rotating the bolt within the suspension arm, which causes two major issues:
The first is that tightening the bolt into place will inevitably change the alignment. As you turn the nut to clamp the bolt into position, alignment will change slightly from the intended setting, losing precision.
The second issue is that as high loads are applied, the bolt will tend to slip from its pre-set position, creating alignment changes while the car is being driven around the race track which are frustrating at best, and unpredictable and dangerous at worst. Such movement of the factory eccentric bolt has been documented by Fall Line Motorsports in their many years of professional racing.
The rigid camber shims will allow a technician to precisely set camber by choosing one of 5 shim offsets to install in the rear suspension. The shims can be used in either the normal orientation, or flipped, resulting in 9 different positions, divided into 1mm increments. This will give an exact camber setting, and ensures absolutely no change in alignment even in the harshest driving conditions.
Fall Line Motorsports E9X M3 Rear Camber Shim Kit $165
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | info@ind-distribution.com
The Fall Line Motorsports E9X M3 Rear Camber Shim Kit may be viewed here in our online store: https://ind-distribution.com/product?sku=FLM-E9X-1BSHM
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      06-23-2017, 04:50 PM   #2
IND-Distribution
9591
In stock and ready to go.
      06-26-2017, 02:11 PM   #3
macdude357
macdude357's Avatar
467
Drives: IB E90 M3
Do you have install instructions so I can see if this is something I could do myself?
      06-26-2017, 02:44 PM   #4
IND-Distribution
9591
You can download a PDF with instructions here: https://api.ind-distribution.com/med...tall_Guide.pdf
      10-11-2018, 10:05 AM   #5
Ryan@IND
Ryan@IND's Avatar
1770
Drives: ACR
Shim kits in stock, ready to ship!
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMFACEBOOKFLICKR
      10-26-2021, 02:42 PM   #6
rwemersonrw
rwemersonrw's Avatar
535
Drives: BMW M2 Competition, Acura TSX
Originally Posted by Cat@IND View Post
[img]https://farm1.staticflickr.com/530/1...ac75cb9f_b.jpg[/img]
[img]https://farm1.staticflickr.com/374/1...703e0f48_b.jpg[/img]
Very excited! Just ordered it for M2C.
      11-15-2021, 05:40 PM   #7
Whit45
38
Drives: '08 E90 335i/'10 E92 M3/'13 Is
Are you able to achieve more camber than with the factory eccentric bolts?
Thanks
      01-11-2022, 03:19 PM   #8
IND-Distribution
9591
Thanks
The slot for the factory eccentric bolt is a fixed size, so theoretically the range should be the same; however it's easier to be more precise using the shim kit and as mentioned, the goal is to eliminate any alignment changes.
m3post
