TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > X6 Engine / Exhaust / Drivetrain Modification
      09-09-2023, 10:40 PM   #23
TTV8M
TTV8M's Avatar
124
Drives: '23 AMG GLE53, '10 X6M
2023 AMG GLE53  [0.00]
2010 BMW X6M  [0.00]
2008 Mini Cooper S  [0.00]
Originally Posted by 0-60Motorsports View Post
This is real BS, the prices of these injectors are so NOT justified....
Good luck with the Build.
Pulled the trigger.... 8 on order @ $365 from bmwpartsnow.com
Very strange, when they arrived, were barely any packing material.... just air bags that were flat..... And the outer plastic container part number ended in in 079 but the injectors were actually printed with the old 261 part number.
On the flip side, the lot number showed they were made in January of this year and from Italy.... If it wasn't from a BMW dealer , I'd really be concerned.
'10 X6M
'08 Cooper S
      09-09-2023, 10:41 PM   #24
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
Originally Posted by TTV8M View Post
Rebuild is underway. Had to go 1size thicker on main bearing cap 1. Went with a violet cap as it got us in range better. Used both the dial bore gauge and plastigauge brand name (red). Crank is in , main caps in, 3 sets of bolts in and torqued and stretched. Always missing pieces need to order.
I have the new oil pump but forgot to order the 3 o rings for the oil tubes (large and skinny). Got those flying in from FCP auto.
Prob won't continue again til weekend after next. More images to follow
Got the rods notched for oil to sling up to the wrist pin and piston...... rods in.... pistons in..... Some accomplishment so far.......
'10 X6M
'08 Cooper S
      09-10-2023, 12:08 AM   #25
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
I wonder when BMW is going to lower prices on the injectors as this is just getting ridiculous. I really pray someone starts rebuilding these and charging a fraction of the price LOL.
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
2011 VW Golf R DSG White/Black
IG: @060Motorsports
      09-10-2023, 10:29 PM   #26
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
theres a local guy for me in South NJ, website is:
https://injector-rehab.com/product/b...-flow-testing/
i sent my stock injectors there. had all the service done. provides a nice test report/etc. and i wound up selling them on ebay. i think i still have 3 left out of the 8.
i figured i spent insane money on the rebuild, and i really wanted new injectors.
'10 X6M
'08 Cooper S
      09-10-2023, 10:57 PM   #27
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
List of performance parts, so far:
VAC did the sleeve work
https://store.vacmotorsports.com/vac...s63-p4102.aspx
https://store.vacmotorsports.com/vac...s63-p4799.aspx
Cylinder heads....walnut blasting.....installing new valve seals.
https://store.vacmotorsports.com/vac...s63-p4770.aspx
CP Carillo Forged Pistons (kept the bore at 89mm, and comp ratio 10:1
https://store.vacmotorsports.com/cp-...s63-p4322.aspx
+heavy duty pins, +dome coating, +skirt coating
Arrow forged rods, ARP rod bolts
https://store.vacmotorsports.com/vac...s63-p5016.aspx
VAC Coated main bearings & rod bearings
Pure Turbos - Stage 2
from x-ph.com on black friday sale
upgraded torque converter from levelten.com
active autowerks catless downpipes
autotalent.com
'10 X6M
'08 Cooper S
      09-12-2023, 08:53 PM   #28
x800pro6
ZEE DEE
Australia
15
Drives: 335i
Can you show me some pictures what you did for the oiling squirters? I'm going to do the same build. Thank you regards Zee
      09-12-2023, 08:55 PM   #29
x800pro6
ZEE DEE
Australia
15
Drives: 335i
Also what tune did you get for increase compression ratio?
      09-17-2023, 07:51 PM   #30
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
I have not tuned it yet.
I simply put higher compression pistons. Stock for my 2011 x5m engine is 9.3:1
I basically have my pistons installed now which are 10:1 ratio
'10 X6M
'08 Cooper S
      09-17-2023, 07:56 PM   #31
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
can you show me some pictures what you did for the oiling squirters? I'm going to do the same build. Thank you regards zee
'10 X6M
'08 Cooper S
      09-17-2023, 08:02 PM   #32
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
But you'd only need these if you have the single squirter, have curved rods, and want to upgrade to straight rods
'10 X6M
'08 Cooper S
      09-18-2023, 07:08 PM   #33
x800pro6
ZEE DEE
Australia
15
Drives: 335i
Looks good. How are you going to get oil to squirt up to cool the pistons ? . I have the same engine. Seems this platform is really limited. By the way are the arrows rods heavier than OEM and do you need a rebalance? Regards Zee
TTV8M123.50
      09-20-2023, 09:58 PM   #34
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
I grinded in some notches at 12 oclock on the rods. Both sides
Yeh they feel heavier.
Yep, the crank was polished and rebalanced at the machine shop factoring in the rods n pistons
Yep we're limited but not too terrible
I am concerned with when it comes down to finding a good tuner.......
'10 X6M
'08 Cooper S
      09-20-2023, 10:03 PM   #35
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
The notches are better in the sense that:
-they will always be flinging oil up
-doesnt take oil pressure from the system
Factory squirters only spray at certain oil pressure
'10 X6M
'08 Cooper S
      09-22-2023, 08:07 PM   #36
x800pro6
ZEE DEE
Australia
15
Drives: 335i
Can you show me a picture of the notch in the rods . Thank you as far as a a tuner. Go to active Autowerks. They recently did a custom tune for someone in Canada. He has 10:1 compression ratio. Forged rods and pistons m5 manifold and turbos 28psi according to him.
TTV8M123.50
      10-01-2023, 09:19 PM   #37
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
'10 X6M
'08 Cooper S
      10-02-2023, 09:57 PM   #38
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
Finally getting this badboy assembled. Images from this past weekend. Next weekend, timing and install the valve covers.
'10 X6M
'08 Cooper S
      10-06-2023, 09:07 PM   #39
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
I would think yes the arrow rods are heavier. Especially since they are rated for 2000hp.
I did give that crank to the same machine shop and they polished it and rebalanced
'10 X6M
'08 Cooper S
      10-08-2023, 10:53 PM   #40
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
updates
Got some hours in on the motor this weekend.
Finally got the timing done...................
and the harmonic balancer (vibration damper). Wow was that a nightmare........... 100nm starting torque no prob..........then the 60 degrees x3.......... sheesh........needed to be superman for that........
So if you can visualize............a 3/4 inch drive, 40 inch breaker bar......with a 3/4 to 1/2 inch adapter (note...the weakest link)......then a snapon torque angle gauge.......then the 27mm socket........
1st 60 degree, no prob..........
2nd 60 degree.........halfway, the 3/4 to 1/2 adapter shatters dead center......... broke off in the snapon torque angle gauge........find another 3/4to1/2....... finish that 2nd 60 degree............
now the final 60 degree.............. just at the finishing point, the welds started breaking off at the same point at the center of the 3/4to1/2 inch adapter.........wow...........how much torque was that?Name:  1000033534.jpg
'10 X6M
'08 Cooper S
      10-15-2023, 11:40 AM   #41
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
Got some more of the engine assembled. Worked on the heat shielding as previously mentioned from Sophisticated Redneck
Dont mind our messy wrap, first time heat wrapping a spider looking exhaust manifold.
'10 X6M
'08 Cooper S
      10-15-2023, 11:42 AM   #42
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
'10 X6M
'08 Cooper S
      10-15-2023, 11:43 AM   #43
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
gonna need some ideas on blocking the intake manifold ports that were for the PCV/EGR. dont want any of that garbage getting fed back in.
'10 X6M
'08 Cooper S
      10-19-2023, 08:11 PM   #44
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
Re: turbo blankets. I purchased 2 different ones. Today, I received two turbo jackets from Funk Motorsport in the UK. I like how they are form fitting over the exhaust part of the turbos.
I also have PTP turbo blanket , once piece, which I consider a "throw" blanket as it's one piece and throws/lays over the hot side of the turbos and back to the O2 sensors in the DP/cat
Of course I am going to try and use both. Will report my findings this weekend
'10 X6M
'08 Cooper S
xbimmers
