04-20-2024, 04:17 PM | #815 |
21
Rep 51
VMR 710 19”
Front 8.5” et 25 + 12mm spacer 245/40/19 Rear 9.5” et 33 + 5mm spacer 275/35/19 Update: Just a hair of poke and rubbing when reverse turning, i decided to do only 5mm spacer front + no spacer rear for a flush fit. Lowered on eibach springs Last edited by slm266; 04-21-2024 at 10:50 PM.. |
04-22-2024, 12:14 PM | #816 |
18
Rep 19
Looks great, I have them on a LeMans Blue 135i in Hyper Silver. Are yours Gunmetal?
04-22-2024, 12:22 PM | #817 |
21
Rep 51
04-22-2024, 01:24 PM | #818 |
18
Rep 19
Yes, the center caps were a direct fit on the V710, but on a 135i. VMR can't confirm that the same thing with happen on their 5/112, 66.6 wheels, as I'm planning on getting V802 wheels for a black M340i. And, they only offer Gunmetal on the V710, and not the V802. I'm afraid the Anthracite may be too dark, that's why I asked if yours were gunmetal... but I already have that wheel on another car. Decisions!
04-22-2024, 08:09 PM | #819 | |
21
Rep 51
04-23-2024, 02:30 AM | #820 | |
Rep 7
If the calipers are too big, you can only put 1-piece 19" or 2-piece 20" on the front wheels. Feel free to contact RVRN Wheels for any specific requests or questions you may have. Our engineer will check for you. Check out custom wheels project for BMW M3 Competition, Front: 1pc 19" Rear: 2pc 20" |
04-25-2024, 03:03 AM | #822 |
Rep 23
04-25-2024, 02:23 PM | #823 | |
64
Rep 22
I honestly couldn't give any advice. I'm not nearly well enough versed. The shop I went to was highly recommended in my area and they knew the size to use. |
04-30-2024, 09:47 PM | #826 |
Rep 5
Hey Everyone,
I’m planning on going staggered on my aftermarket wheel setup in my 21 m340 xdrive. Has anyone had any issues with staggered wheels on xdrive drive train? Let me know! Thanks |
05-01-2024, 07:38 AM | #827 | |
21
Rep 51
225/40 + 255/35, 235+265, 245+275 I’m running 245/40/19 on 8.5J+25 front (5mm spacer) + 275/35/19 on 9.5J+33 rear (no spacer) xdrive adaptive suspension eibach springs Pay attention to maximum tire width for wheel size |
05-01-2024, 08:58 AM | #828 | |
Rep 5
I used a online calculator and for the front circumference is -0.4% and the rear is -1.5% with the specs I mentioned. Would that be considered safe since it’s within 1%? |
05-01-2024, 09:02 AM | #829 | |
21
Rep 51
You compare front to back, that’s a 1.2% change |
05-01-2024, 09:44 AM | #830 |
Rep 5
slm266
Kindly take a look at the percentage I got for the circumference difference. Is that too much of a difference? Oem tires on my vehicle are 225:40/19 square |
05-01-2024, 10:28 AM | #831 |
21
Rep 51
Matt, the 1% refers the new front compared to the new back, not the old front to new front, or old rear to new rear.
05-03-2024, 04:31 PM | #833 |
Rep 2
2020 BMW M340i xDrive on stock suspension
Brada CX2's in Satin Bronze Front: 20x9 +25 with 245/35/20 Rear: 20x10 +40 with 285/30/20 I did end up running 3mm spacers in the front for that *little* bit of extra clearance. May not have needed it, but went with them anyway. No issues with rubbing. Attached one picture dead on from the back so you can see how they sit. The Satin Bronze color is amazing, and changes a little bit depending on the light it's in. Figured it was a good compliment to the Cognac interior. Very happy with the quality and finish on the wheels. HUGE shout out to Vibe Motorsports for helping me through this entire process. Vahan, you're the man. I've purchased a lot of wheels over the years and this has been the best experience I've had, hands down. They know their stuff and will follow through to make sure you are satisfied.
2020 BMW M340i / Alpine White / Cognac / Brada CX2's
VIBE Motorsports2175.00 |
05-03-2024, 06:04 PM | #834 | |
General
2175
Rep 34,590
Looks amazing!! It was a pleasure working with you! Thank you!
Have questions? Contact us below bmw@vibemotorsports.com. 800-814-8423 Ext 107 Ask for Tom https://www.vibemotorsports.com/wheels |
05-05-2024, 06:29 PM | #835 |
Zach
562
Rep 30
Drives: 2019 330i xDrive
KONIG Neoform’s on stock ride height G20 330i
Yesterday, 05:40 PM | #836 |
10
Rep 17
Drives: 2007 BMW X5
Went up by one inch foe my summer shoes 👞
