My CIC Combox 6FL retrofit log (and DIY focused on coding)
06-18-2021, 02:47 AM | #112 |
Rep 2
Worth it
First of all, Thank you for this detailed DIY. Managed to successfully make the retrofit from M-ASKII to CIC Professional with all functions working including the navigation. The difference is indescribable.
The trickiest part was the FSC coding, and to write the new VIN to all modules. I found a different version of FSTool2 with preset files, and step by step guide and worked like a charm. It can do the 17, 19, 1b certificates. The next problem was that if I entered the activated navigation menu, it immidiately asked me the activation code, but I couldn't check the actual version of the navi, so I didn't know which version I should use to update and to generate the activation code. Found this exact problem on a different thread, Tool32 can do the job to check which version has it. If someone would ask which part was the most difficult, I would say get the tools for FSC Certification. I saved all the working stuffs in one place. So If anyone need, I can send it. The next thing I would like to accomplish is the Hungarian Language. But as I read in other threads the coding with NCS is not enough, you need to update the firmware versions in a correct order and with an appropriate tool which is an ICOM interface. At first when you read the DIY it seems difficult and complex. When you finally spent $500 or more to the stuffs (I managed to do for $350) and start to disassembly the old and assembly the new CIC, it seems less difficult, and when you reach to the coding you get excited not to mess up something. My goal is to encourage everybody who thinking about this retrofit, because If I would do this again it probably would only took half of the time or less than for the first time and furthermore your car looks many years younger than before. Anyway anybody is interested in a working M-ASKII navi? Ohh and be careful with the postal services because it can be tricky... Last edited by Emil98; 06-18-2021 at 02:49 AM.. Reason: Too long lines |
07-23-2021, 03:40 PM | #113 | |
Rep 5
I need help. My car initially came with the M-askII system, I replaced the radio and the screen with a professional CIC already in CIC.C1A version. To activate the navigation I bought an emulator, however, this only works with the radio with the VIN of the donor car. What bothers me is that this causes an incorrect vin error on the radio and I believe it is causing the car to run out of battery. I removed the emulator, changed the VIN for my vehicle, generated the certificates and the FSC, however, in 00190001 I can only generate one certificate, the FSC is in red. I do all the steps correctly in FStools and CHECK_FSC from 00190001 gives an error. Would you have the walkthrough to activate navigation? |
08-01-2021, 04:24 AM | #114 | |
Rep 2
There is a step by step guide. Open TOOL32 and find this 3 modules: CICR_GW.PRG, CICR.PRG, CICR_HD.PRG. You will need to do the same thing in all modules. So first select one of these and in Tool32 on the Jobs list select "aif_lesen" => you will read infos with it. On the right list "results" tab select these options together: aif_fg_nr, aif_fg_nr_lang Will pop up a new result window where you will see the last 7 characters of the VIN coded to the CIC. We only need to modify this VIN to yours. So on the jobs list you select "aif_schreiben" => this job will write the parameters to the CIC, and on the arguments field you need to write the arguments in the correct order with the ";" separator. It will wait 9 arguments and you need to change the first argument to your VIN(the last 7 character of your VIN) and copy the remaining arguments from the info which you've read before. I don't remember the args order but it will tell you exactly what parameters it waits and in what order. Example: lets assume your VIN is: A123456 Then the args which you need to set is looks like this: A123456;13.11.2013;9284329;0000000;0000000;011111; 12345;61200;020260F80AA I copied the reamining 8 args from my CIC. And you need to do this same steps on all the 3 modules mentioned below. After you done with it, you can do the FSC coding. I would recommend you to use FSTOOL_v20211. I used it and worked like a charm. Hope it helps, Cheers |
Mr-Toast0013.00 |
09-23-2021, 05:08 PM | #115 |
22
Rep 60
Drives: F30 330e & E92 335i
Hi All,
Does anyone have a new link for the 6FL cable ~3 metres from usb plug to combox? The one linked by the OP is no longer valid. Preferably one in europe. |
11-26-2021, 02:15 PM | #116 |
45
Rep 157
Drives: 2011 328i
I'm about to do the combox retrofit to my new-to-me E93 and was wondering if there was any PNP kits for the retrofit anymore? It seems the only people who made them are no longer stocking them, and/or their email is down (CICretrofit@gmail.com gets returned undeliverable).
11-09-2022, 08:47 PM | #119 |
295
Rep 2,203
Years later this DIY is still of great help. I've gone through so many emulators; the last being the most expensive and it still got wrecked. If you are still on here, I Just want to say thank you.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
02-19-2023, 04:27 PM | #120 |
2443
Rep 4,330
just checking back in.
hosed my retrofit coding trying to track down a comfort access problem, came back here, followed the vehicle order coding bit and now I'm back to working bluetooth on my combox. |
02-02-2024, 12:07 PM | #121 |
Rep 12
Hello, Recently, I retrofitted CIC in a BMW E92, and the donor CIC is C1A. However, currently, my navigation appears to be gray. When I retrieved data from "aif_schreiben" using Tool32, I obtained the following information: "P075502,09.08.2011,9273158,9273161,0000000,000000 ,00000,0,0202JP0F78RA". It seems like there are too many zeros in some parameters. Additionally, when I try to execute STORE_SIG_CERT and CHECK_SIG_CERT in "FSTool2," I encounter an error (attached in the appendix).
I have also noticed that some people fetch "FSCS Certificate" from "Configuration" -> "Certificates" -> "FSCS Certificate" by accessing the SWTPatcher-v2 -> 03_FSC_Templates -> 001B0001.fsc folder. However, when I attempt to retrieve these files, I encounter an error (also attached in the appendix). |
03-08-2024, 01:58 AM | #122 |
Rep 3
Hi,
I just came back to this post after following the coding part step-by-step and everything went as smooth as butter, you have perfectly described every step and answered all of the questions that would occasionally pop up into my head. I have made the switch from M-ASKII to CIC Professional with Combox, hands down best upgrade there is. If you are still in here and read these, thank you a lot! |
TiAgAu150.00 |
03-18-2024, 01:36 PM | #124 | |
307
Rep 264
Drives: Green '07 & Arctic '08 335i's
FSTool2 02.02.00
