01-18-2024, 09:28 AM | #1 |
22
Rep 52
Looking for a picture of the motor/gears on the OEM nav unit
Does anyone have a pic of the electric motor that operates the OEM nav screen? I took mine apart in an attempt to fix it and I think I am missing one of the gears - more specifically the one that goes on the shaft of the motor. I'd like to figure out the diameter and the tooth count, so I can order a replacement.
01-28-2024, 09:19 PM | #2 | |
2298
Rep 12,569
Drives: Z4 M, X5, GX460
https://z4-forum.com/forum/viewtopic.php?t=142096 |
01-29-2024, 11:37 AM | #3 | |
22
Rep 52
The only issue I am running into is that the gear on the motor has a crack. This little gear is prone to failure and the guy that did the retrofit in the link you posted didn't check his unfortunately. I'm now trying to source a replacement gear. |
