DIY: Install SSD in CIC
10-16-2020, 10:22 PM | #133 |
20
Rep 57
Drives: 2011 335d
yea so music transfers seem finicky, same as well for map updates
i put my old hdd back, did the update, and wrote that back to the ssd |
10-16-2020, 10:24 PM | #134 |
242
Rep 1,353
10-16-2020, 10:26 PM | #135 |
242
Rep 1,353
10-16-2020, 11:02 PM | #136 |
20
Rep 57
Drives: 2011 335d
11-17-2020, 08:17 AM | #137 |
Rep 1
Trim support of SSD's in CIC
Thanks for the helpful post. I'm retrofitting CIC Professional into my F25 from a CHAMP originally, and this post has at least allowed me to make a backup of the drive on my Mac prior to it going bang!
I just wondered whether people thought of TRIM support in the SSD, do the msata drives do garbage collection automatically or is the SATA>PATA controller doing it without input from the operating system? QNX 6.3 (that CIC is built on) doesnt support Trim and I wondered if compatibility issues ensue because of that? Another option I looked at was the Sandisk Extreme Pro CompactFlash drives that are available in 128Gb format and have a working temperature similar to the original Toshiba drive. |
11-17-2020, 08:53 PM | #138 |
242
Rep 1,353
Given that the OS in the CIC was designed for a hard drive, and there was a need to save flash ram space and the age of the CIC, trim support is not present.
But it isn't really needed anyway... see this. https://www.crucial.com/articles/about-ssd/what-is-trim I've been running mine forever a few years now without a single issue nor hiccup. And it is nice to have the original drive as a backup. Btw: if I remember correctly, the CIC will not work with larger drives, so your choice is important. |
11-17-2020, 08:56 PM | #139 |
242
Rep 1,353
That sounds like a communication problem on USB.
12-13-2020, 10:37 AM | #140 | |
Rep 4
12-13-2020, 10:41 AM | #141 | |
Rep 4
Sorry, I think I was able to answer my own question:
ResinThirteen190.50 |
12-21-2020, 11:50 AM | #142 |
Rep 4
Tips for VMWare Fusion on Mac
As an FYI, if you're trying to resize the partitions on a Mac while running QNX Neutrino in VMWare Fusion, you need to rename the folder your VM is in to have the extension ".vmwarevm". I spent hours trying to get my CIC's drive to show up in QNX and every time I would boot the VM I would get an error that it couldn't get to the disk. I first ensured in System Preferences that VMWare Fusion had full disk access, I ran the tool that creates a .vmdk from an external disk, but it still wouldn't load. Apparently VMWare Fusion wants to see Workstation VM's as "packages" so adding that file extension somehow fixed the problem and I can access all of my partitions in QNX.
12-29-2020, 06:24 PM | #143 |
Rep 1
Yeah, I have the same problem with USB map updates too after upgrading to SSD. Tried multiple USB drives, still have the same problem. Looks like I need to swap back to HDD temporarily if I want to update maps.
12-30-2020, 09:25 PM | #144 |
430
Rep 170
jturn What SSD and drive adapter are you using?
It seems like some SSDs don't play nice with high write, but I haven't really looked into why. I know I had a similar issue with a Samsung EVO, but switched the mSATA to another and I was able to update without issue. Since CF cards have gotten a lot cheaper lately, I was planning on trying a CF->IDE adapter, just to see if it worked. (And if it worked better than the mSATA/IDE) |
12-31-2020, 05:45 PM | #145 |
Rep 4
Thanks Jagaer for putting this post together. Just did this conversion and it worked great. I used the same SATA adapter Jagaer displayed and then a super-cheap mSATA SSD (Dogfish, some cheap brand I found on Amazon). I don't care about the quality of the SSD much since I don't use the built-in navigation or music anyway, I have a wireless CarPlay unit that runs the whole time when I'm driving.
01-03-2021, 03:01 AM | #146 | |
153
Rep 438
02-16-2021, 03:31 PM | #147 |
Rep 59
Hi everyone,
I successfully upgraded my drive to SSD and everything was working great until recently. Now it seem like the music partition crapped out.... and probably cddb partition as well. The system won't read a CD anymore The navi still works which tells me it's not a drive problem or cold temperature... I did take the drive out and mounted it and everything is there ! So if anybody has an idea... I'm all ear ! J |
02-17-2021, 10:43 AM | #148 |
242
Rep 1,353
That does not sound like an issue with the SSD.
It sounds more like a problem with the interface bus the CD reader is plugged into or the CD reader itself grounding out the bus. Fixing that would require a fairly deep dive into the CIC itself. Of course you could always be lucky and merely have a loose or slightly patina covered internal cable end... so pulling it out and reseating cables would be the first thing I would try. |
02-17-2021, 03:51 PM | #149 |
Rep 59
That's what I thought too but then when I put the old drive back in, everything works....! And also, there is no code reported from ISTA
I have been looking into the format of the data on the music partition as well as the size of the drive itself. Next step is trying to just redo the ssd drive with just the original image and nothing else then wait to see if it holds |
02-18-2021, 02:13 PM | #150 | |
242
Rep 1,353
02-20-2021, 01:46 PM | #151 |
Rep 59
Update !
So I decided I would make a new image with the original drive, since everything is fine when I plug it in. Then I transferred the new image to the ssd an reinstalled it... so far so good ! I will leave it as is for a while to rule out an issue with the partition resizing or music file format..idk then transfer my music database onto it |
02-21-2021, 10:36 AM | #152 |
Rep 2
Hi,
My HDD have started to fail (screen keeps rebooting), and after a Google search I found this very interesting thread! I have decided to do the HDD to SSD upgrade, but can I copy the HDD I have, or do I need to copy one that have not started to fail? thanks in advance! Last edited by SimonSJ; 02-21-2021 at 01:08 PM.. |
02-22-2021, 09:50 AM | #153 |
242
Rep 1,353
It depends...
If you are very lucky your old HDD drive may read correctly when pulled from the system and used as a clone source. It could also be suffering striction, which can sometimes be temporarily overcome by rotating the drive quickly in the horizontal plane while it powers up with the cables connected, then you may get a perfect clone. If not you may get most of the drive and partitions copied over with only a few bad sectors. In turn if those sectors occur in an easy to update partition, such as the maps or music partitions, your cloned drive will work. The HDD has FSC codes for your CIC hardware, so if you completely loose the drive you have to deal with that too. |
02-22-2021, 10:45 AM | #154 | |
Rep 2
Thank you for the answer! I will try to clone the HDD, so I don't have to deal with losing/changing the FSC codes. |
