BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Performance Air Filter for F30 328i N20
Studio RSR
      03-14-2012, 08:25 PM   #1
HP Autosport
Supreme Allied Commander
3847
Drives: F80 M3
AFE OE Replacement air filter for the BMW 328i F30 2012 L4-2.0L (t) N20. This filter is available in Pro 5R (P/N: 30-10225) and Pro DRY S (P/N: 31-10225). Constructed with 100% polyurethane, this high flow, OE replacement performance filter outflows the stock paper filter by 28% resulting in improved horsepower and torque.
      03-14-2012, 11:45 PM   #2
clarence
54
Drives: F30 328i M-Sport
Any dyno traces available?
      03-15-2012, 12:16 AM   #3
HP Autosport
3847
Drives: F80 M3
No, not yet.
Just looking at the flow numbers you will pick up some power.
There will be a HPA version of the N20 high flow air fitler very soon as well!
      04-07-2012, 12:14 AM   #4
sleedawg
Drives: 2015 328i & 2011 335i
What's the difference between the "Pro 5R" and "Pro Dry S?"
      04-07-2012, 12:50 AM   #5
HP Autosport
3847
Drives: F80 M3
Pro 5R is an oiled filter and supposed to flow better. Pro Dry S is a dry filter.
      04-16-2012, 10:28 PM   #6
SD_E88
SD_E88's Avatar
19
Drives: 12' 135i E88 Black
Forgive me, I've never used an oiled filter. Does it come oiled? Do I need to re-oil it? Clean it? What's the process for cleaning? or do I just replace it? How often? Again, never used an oiled filter so I'm really curious...
      04-16-2012, 11:00 PM   #7
HP Autosport
3847
Drives: F80 M3
The oiled filter comes pre-oiled, just install it and go. When it is due for cleaning, you will need to clean it, allow it to dry, then apply oil before re-installation.
There is also a dry version that doesn't require any oil.
      06-07-2012, 04:56 PM   #8
dude987
Germany
41
Drives: BMW 335i xDrive M-Sport DHP
Really!!! I have some prime real estate for sale in Florida!
      06-07-2012, 05:10 PM   #9
bcl0328
127
Drives: 2012 328i
how much HP gain?
      06-07-2012, 06:05 PM   #10
Elk
32
Drives: 2012 335i
A few HP over a grubby stock filter.
Many oiled filters actually decrease performance from stock after they have been installed in the car for a while and have gathered some dirt. You are typically better off leaving it stock unless you are going to fastidiously clean and re-oil the filter on a very regular basis.
      06-07-2012, 08:09 PM   #11
darmawaa
Drives: 2017 M2
Also available for F30 335i ?
      06-21-2012, 05:24 PM   #12
HP Autosport
3847
Drives: F80 M3
Yes, it is!
Pro-5R version is ready.
http://www.hpashop.com/aFe-F30-335i-...nel-Filter.htm
      06-21-2012, 07:28 PM   #13
ProbyOne
ProbyOne's Avatar
13
Drives: Acura TL / E93 M3 / 996
I see this "flow" figure thrown out a lot by filter manufacturers.
Does this mean a 28% increase in flowrate at the same pressure drop? What kind of pressure drop across the filter do you get at different air rates?
you are a winner
      06-21-2012, 07:40 PM   #14
HP Autosport
3847
Drives: F80 M3
That is a question for AFE. I don't know how they come up with their numbers.
We measure filters on flow benches and the results are a percentage, see this thread:
http://www.e90post.com/forums/showth...ght=flow+bench
      06-21-2012, 10:38 PM   #15
ProbyOne
ProbyOne's Avatar
13
Based on that thread the filter pressure drop was held constant and you measured the corresponding flowrates (given as a percentage).
That is exactly what I wanted to know... Thanks
you are a winner
