Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > N54 325i 3.0ltr E92 - engine misfire - need new fuel injectors 1 & 3. Can anyone help
      05-04-2024, 11:49 AM   #1
louj91
Drives: bmw 3series 325i 3.0ltr
N54 325i 3.0ltr E92 - engine misfire - need new fuel injectors 1 & 3. Can anyone help with providing which index fuel injector is needed or a link to purchase in the uk ? - currently index 11 since the recall back in 2020, understands these also needs to be coded once fitted but struggling to find which ones to purchase in the UK ? Any help/links massively appreciated.
      05-10-2024, 06:01 AM   #2
Dopeslope
Dopeslope's Avatar
14
Drives: E92 330i
Hi There,
I think you mean 'N53' you ca get new index 11 here:
https://www.merlindiesel.com/product...ol-injector-4/
Some used on ebay:
https://www.ebay.co.uk/itm/326069750...BoCWywQAvD_BwE
BMW part number is: 13537589048
Hope that helps
      05-10-2024, 01:55 PM   #3
Phil325i
Phil325i's Avatar
624
Drives: E92 325i MSport Coupe
You can also successfully run Index 12 injectors from the N54 if that helps. Would need to replace all six if you did though...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
