Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > looking at 335d's...looking for answers to FAQ
      10-25-2018, 01:25 PM   #23
Persian Whisperjet
Kind of a Big Deal
167
Drives: 2011 335d
Recurring glow plug failure is often traced to a faulty thermostat. Easy fix I got an OEM one for $25.
      10-25-2018, 02:06 PM   #24
Persian Whisperjet
Kind of a Big Deal
167
Drives: 2011 335d
At a minimum I would tune out the EGR and SCR systems. Better yet, tune them out and toss the EGR in the trash and replace with an AARodriguez racepipe, which will free up a lot of space. These changes plus a couple of other routine items (principally harmonic balancer, engine mounts, and vacuum hoses) will head off CBU and mitigate probably 75 percent of your reliability problems.
      11-13-2018, 06:12 PM   #25
DougNBodie
DougNBodie's Avatar
27
Drives: BMW 335d M Sport
2011 BMW 335d  [10.00]
2011 335d with 62,000 miles on her.
1) Carbon build-up aka "CBU" - Not Yet
1a) Injectors go bad,-----Not Yet
2) Harmonic balancing pulley - Replaced at 55,000 miles
3) SCR mixer and related codes-----Not Yet
4) driveshaft guibo-------Not Yet
5) Transmission filter and fluid should have been serviced every 50K---Basic car care
6) Vacuum lines need replacing------Not Yet
7) thermostat tends to fail open after 5+ years------Not Yet
8) Urea tank issues-------Not Yet
I have just changed the oil and tried to never push the car to much before driving about 8 miles......Turbo's like to get warmed up before use.
This D has been a great car.
      11-18-2018, 10:32 PM   #26
Pep423
Drives: 2011 335d M-Sport
2011 w 61000
Purchased in Apr 2015 with 23,900 miles
All below replaced by me
TPMS module
Glow plug module
MAF
EGR cooler
Thermostat (because I was already in the area)
Red boost charge pipe
Car is currently at BMW to diagnose a strange noise from engine area for which I couldn't figure out.
Under warranty
NOx sensor (original owner)
Recalls
HVAC blower motor
SCR/UREA
Battery cable
I was expecting it to have issues but not all of these. Luckily I was able to do a lot of the work myself. If I could do it again I likely would not buy this car.
Car has a Renntech tune but all issues except boost pipe occurred before tune.
      12-07-2018, 03:01 PM   #27
fre1102
Drives: Looking - 335D
Originally Posted by Pep423 View Post
2011 w 61000
TPMS module
Glow plug module
MAF
EGR cooler
Under warranty
Recalls
HVAC blower motor
SCR/UREA
Battery cable
I'm looking for a 335D--let me know if you decide to sell it.
      12-07-2018, 03:04 PM   #28
Pep423
2011 w 61000
TPMS module
Glow plug module
MAF
EGR cooler
Under warranty
Recalls
HVAC blower motor
SCR/UREA
Battery cable
Haha, what timing! I'm planning on trading it in as soon as tmrw.
However, I just got it back from the dealer. They think I may have something going on in the crankcase. Either a rod or main bearing but they didn't open up to confirm.
      12-10-2018, 11:05 AM   #29
apexit4
Poland
1231
Drives: 335D M-Sport, X5D
I've been seeing more and more people comment about potential bearing issues. Wonder if its a coincidence or a pattern...
      12-12-2018, 05:37 PM   #30
DougNBodie
DougNBodie's Avatar
27
BMW upped the warranty to 100,000 miles on the Turbo, NOx, injectors (pretty sure), catalytic converter and I think the inter-cooler.
Must do's: Never (try not to) push the Turbo's until you have driven the car for about 7 or 8 miles and either do a JBD or remap.... Dont go over 350 Hp and 500 lbs of torque with out doing brakes and rear differential. Last thing if you can....just a suggestion. Try to get a M Sport, doesn't have a heated steering wheel but there are only about 650 left on the road in America.
      07-14-2021, 01:00 PM   #31
Jujuchua
Drives: 2011 335d
I gotta dbs face star off assist and now a check engine light on. Before that it was amazing
      08-21-2021, 02:58 PM   #32
335d_go_wow
Drives: 2010 335d
2010 335d w/ 137k miles
(purchased from my cousin back in 2019 with 126k miles)
What a pure bliss to drive, best car I've ever owned, so much fun that I don't entirely begrudge spending the money on maintenance because I know how much fun I'll get from it on the other side.
Replaced the front struts (~$700), but my cousin told me that going into it.
It already had a NOx sensor code when I got it from my cousin but I wiped it and did a drive cycle and still passed smog in CA. Over the two years I've owned it the NOx sensor codes worsened. Quote from Indy shop for $1,600 or about $1,000 if I do it myself. At this point it's the right time to sell it because we're ditching the apartment and going to try the vanlife for a year or two and don't want to store the 335d.
Besides that I've really only had to replace the front left wheel speed sensor which was easily done myself for like $40 for the part.
I absolutely recommend the car, just also budget something reasonable for annual maintenance.
