M57 Tuning, Maintenance, Parts and DIY MEGATHREAD
12-15-2016, 10:18 AM | #23 |
765
Rep 3,558
I'm guessing OP was trying to keep list somewhat realistic cost wise for our large in flux of new members. Maybe they have deep pockets, maybe not. The hybrid turbos and tune is a whole another level requiring an upgraded intercooler and likely piping. I've left this thread alone as it's largely a repeat of many other topics earlier discussed. My opinion is the OP's intent was likely below the hybrid level. I've been at this 5 yrs and still hadn't touched the stock turbos (save for the waste gate porting). My take is to wait until my turbos are in need of replacement. Sure, we could all go drop 20 grand in upgrades but I'd rather spend it on the Barracuda and run low 10's. Out
12-15-2016, 10:34 AM | #24 |
Know's a guy that know's a guy...
5637
Rep 1,905
Fair statement/point.
12-15-2016, 10:50 AM | #25 |
213
Rep 2,210
The only way the one from AA rodriguez is a better item is if you need the meth bung in the EGR pipe. However, thats not even a recommended location for meth bung so you might as well get the reasonably priced one and put the bung in the right place. TDIwyse is running the same one I am (or similar) as well as a bunch of the guys from europe, theres plenty of feedback. Its a pretty well made item.
Arben5.50 |
12-15-2016, 06:40 PM | #26 |
321
Rep 1,157
Yeah, I'm trying to keep this in a lower cost range since I know so many new people are coming in, and I know they all have plenty of questions just like I did.
This thread puts you in the more reliable range, with better MPG, and ridiculously good performance. Of course if you have the money replacing the stock turbos and getting a massive tune and upgrading literally everything is good, but most of the newcomers don't really want to go past a stage 2+ with meth. So I've tried to cover just the general stuff. When these newcomers start wondering about hybrid turbos and stage 4, then they will be more able to research these things and ask proper questions. |
Darkswarmer3.50 |
12-15-2016, 08:46 PM | #27 |
NY BRAVEST
47
Rep 231
I had a post, a few post back about my race pipe.. Look at this on
eBay http://www.ebay.co.uk/itm/141129920512. I've had it for almost a year now and I love it. Just an option. Bit I don't use the bung for meth.. both of mine are in the charge pipe This is where I installed my meth upper charge pipe, AEM 2 500 nozzles, as per BPC I have a lot better pics, but resizing them cuts out a lot of detail... Don't know why in 2016-soon 2017 this site just doesn't auto resize. 😡😡😡😡😤😤😤 Last edited by JOHNNYBRAVO1; 12-16-2016 at 10:07 AM.. |
12-15-2016, 08:54 PM | #28 |
5637
Rep 1,905
didn't see larger FMIC - but this is a relative easy mod, and somewhat inexpensive...
12-15-2016, 11:14 PM | #29 | |
50
Rep 347
12-16-2016, 08:22 AM | #30 |
213
Rep 2,210
Chief Orman671.00 |
12-16-2016, 09:24 AM | #31 |
277
Rep 1,576
ASBSECU E935637.00 |
12-16-2016, 09:44 AM | #32 |
5637
Rep 1,905
I think BPC recommends as 335dlci stated. This is where mine is located.
12-16-2016, 10:25 AM | #33 |
213
Rep 2,210
Many are running it before the IAT. Not sure why that wouldnt be recommended unless it just doesnt play well with their tune or there is concern that it will foul the sensor (mine seems fine, after at least 50k miles of having it sprayed on). Either way its before the throttle plate which is the important part.
12-16-2016, 05:36 PM | #34 |
Warrant Officer
375
Rep 1,341
Been running mine before the sensor. I really don't see a drop in intake temperature while spraying like was claimed.
Deleted, ATM I/C and tuned by B.R.R.
12-17-2016, 05:47 PM | #35 |
50
Rep 347
12-17-2016, 06:11 PM | #36 | |
765
Rep 3,558
EDIT: Oops, I spoke too soon, the EGR cooler can attach to the side of the faux EGR valve that Bimmertune offers. I cut that off as I hadn't run a cooler since 2014. I also cut off the fake vacuum connection. I painted it with satin silver to sort of look like the factory EGR. Any trained eye would catch this quickly though. So, my version of the bimmertune "spacer" is very simple now. Throttle body in and out. That is it. |
12-17-2016, 10:57 PM | #37 |
213
Rep 2,210
One side of that delete pipe connects to the egr cooler outlet and serves as the block there, no other blocks are needed. However, you might want to buy the exhaust manifold block off to keep any exhaust gasses out of the egr cooler for peace of mind
12-18-2016, 06:26 AM | #38 | |
614
Rep 2,410
I've had mine before the IAT sensor for >4 years now. Attaching some of the first data comparisons I did when starting to play with the water/methanol injection to show the significant change in behavior. This was data taken on the same day, maybe 5 minutes apart. I'd actually like to move that IAT sensor further up the charge pipe to allow the water/methanol injection more time to evaporate before the sensor reads the temp. But haven't got around to doing that yet. A potential problem with having the injector before the IAT sensor is that it's likely lower than your water/methanol tank. So a leaking injector/check valve/solenoid would be at risk for filling up the intake pipe, and then bad things would happen. I like having the logged IAT reflect the cooling as it makes things like matchbot simulations more accurately reflect what the engine is doing...
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods |
12-18-2016, 10:19 AM | #39 |
277
Rep 1,576
12-18-2016, 10:39 AM | #40 | ||
Warrant Officer
375
Rep 1,341
Maybe next time the 1/4 mi opens up I'll do some logs with and without meth.
12-21-2016, 01:37 PM | #41 |
43
Rep 281
We should be pushing vendors for nozzle upgrades long before hybrid turbos. There's overhead in the air department. The nozzles are limited and that is the low hanging fruit. Kinda frustrating there aren't ANY options. I'm not used to that for diesels, LOL.
02-01-2017, 07:10 PM | #42 |
57
Rep 104
02-01-2017, 07:18 PM | #43 | |
43
Rep 281
I'm not picking on you, but every time I read 'race pipe' I think it's the biggest marketing BS ever. There's nothing racy about them. They do nothing for performance. #offmysoapboxnow
SLOW & SMOKEY. My car loses to every Chevy Malibu unless I mash the throttle.
Mods: *ATM 304SS Turbo-back exhaust, w/ ox-cat *ATM stepped intercooler *ATM silicone tubing kits (hot & cold sides) JR 2.8 tune *Whitbread CP3R90 HPFP *AArod EGR racepipe*Execuhitch hidden hitch *Stage 3 transmission tune |
02-01-2017, 07:19 PM | #44 |
57
Rep 104
I think that they are only labeled "race pipe" to avoid any legal repercussions for deleting emissions equiptment. Kind of like a "Race Use Only" disclaimer. I know it's not going to give me +100whp or anything like that.
Drifter2090909.50 |
