01-05-2024, 09:13 AM | #1 |
Rep 5
Anyone running 245/40/20 and 275/35/20?
I run the standard 245/35 and 275/30 on my 20in wheels on the M550 LCI. I got a decent offer on a set of 20 inch 668m wheels with winter tires, but for some reason the owner has chosen to run 245/40/20 and 275/35/20
Does anyone run this setup? The gain in circumference is 1-1.25 inch. Would there be any problems? |
01-05-2024, 10:10 AM | #2 |
2880
Rep 5,168
The issue that comes to mind is regarding the speedometer
My physics isn’t up to the grade to say whether that means your speed will under or over read in comparison to the existing tyres (Does entering in custom tyre settings in the idrive affect that ??) |
BNV Peter1.50 |
01-05-2024, 10:30 AM | #3 | |
Rep 5
But I am more concerned about the tires rubbing into something. There seems to be about 1.4 inches of a space between the current tires 245/35 and the fender (not sure if the suspension is closer or not, hard to gauge), and this new setup will eat 0.5-0.6 inches of that space. |
02-05-2024, 08:57 PM | #4 |
Rep 3
The 245-40-20 F 275-35-20 R
This is the tire size that I am going with next summer for my new tires setup. Looks much better on the Car, and I prefer the extra load capacity of the tires. This will Help big time with dealing with Potholes in the city of Toronto. Thank you 🙏 |
02-06-2024, 07:13 AM | #5 |
193
Rep 440
With stock size wheels, such as 668m, and stock ride height, I'd bet they should be fine. They're less than 1" larger in diameter, which is only about a half inch closer to the fenders, etc. People lower they're cars much more than that difference all the time, with more aggressive wheel offsets.
02-10-2024, 09:54 AM | #7 |
Just here to learn.
36
Rep 46
Same here, no issues, and I like it. I am running 245/40/20 and 275/35/20 on my winter setup. I might do 255/35/20 and 285/30/20 for the summers which would also increase the sidewall slightly.
02-12-2024, 09:11 AM | #8 |
32
Rep 15
I ran 245/40 and 275/35 on my stock 20's for almost 2 years. Car is lowered on Dinan springs and had 17.5/20mm spacers as well. My speedometer was actually MORE accurate according to GPS comparison with this setup than it is with my current 255/40 and 285/35 setup on 19's
02-19-2024, 02:58 PM | #10 |
4576
Rep 5,409
On the question of size...
Will a 285 tire fit on the (20"X9") 759i wheel? I noticed that a 285/30 is closer in revs per mile (within 2) than a 275/30. It also affords a little more sidewall than the 275. If the tire will fit, I plan on going with the 285. I have looked at tire calculators and other forums. The forums (not necessarily BMW) seem to indicate it will fit. What say the braintrust? |
02-28-2024, 12:15 PM | #11 | |
3950
Rep 4,255
(went to different tire size and speedo was way off at first ride. 2 hrs later rechecked with GPS tool, back to the standard 3.5kph difference it was prior) well i changed back to the previous tires today so will retest. hopefully will self correct again. |
03-03-2024, 11:37 AM | #12 |
24
Rep 9
I too am interested in tire fitment, I'm going to ditch the RFTs for some proper tires & was thinking of keeping the 245/35 front but running a 285/35 rear on a stock setup w/668s on MY20 M550. Curious if anyone can confirm fitment will be ok?
I appreciate any help, I've searched so many times & cannot find a clear answer. |
03-03-2024, 12:06 PM | #13 | |
3950
Rep 4,255
The_Hall_Way24.00 BNV Peter1.50 |
03-23-2024, 12:23 PM | #16 |
140
Rep 82
03-24-2024, 02:08 AM | #17 |
178
Rep 307
I switched to 245/40R20 and 275/35R20 on 648M rims from a 7 series last year. No need for spacers anymore with these rims. Never had issue. In iDrive, I set it to R19 as it’s the same ratio plus air pressure is correct with the R19 in iDrive. Drive is more comfortable but the steering in more numb than it was before since they made these cars with hard runflats tires. The feeling gets lost with none runflats.
Speedo seems to be exact vs before that was always showing higher than it actually was! |
