      08-29-2012, 09:04 AM   #1
KKS
Australia
26
Drives: SO M4
Smile Installed a Dash Cam
So my friend convinced me the other day to get a dash cam for my car. I've seen the videos before on youtube (Russian ones are the best) and thought it might be pretty useful. I settled on the Black Vue DR400G-HD made by a Korean company. Without going to much into it, here's some of the key features:
1080P recording
GPS position recording
3 axis motion sensor to detect large movements such as accidents
Parking mode (turns on to record when it detects movement in front of it)
Continuous recording onto micro sd card.
I also purchased the power controller (black magic) which allows you to leave the camera in parking mode until the car battery voltage falls to a certain state and shuts off so that it doesn't drain the battery.
I followed hardwire guides found on this forum for the V1. This method uses the fuse box hidden behind the glove box. For this install, a constant 12V and a switched 12V line was needed. To connect to the fuse box, you can use mini blade fuse taps (I found some 10A $7 ones from Jaycar). The power controller was installed inside the glove box and the power cable run through the A pillar into the headliner and along the rear view mirror casing into the dashcam.
The HARDEST part would be finding an empty fuse that's the right amperage
Needless to say, I spent the good part of an hour testing every empty fuse slot I could reach through the tiny gap. So here they are:
Constant 12V: No. 2,3,7,64,68,56 I ended up using 64
Switched 12V: 5, 7(this one is not empty so I used 5)
And.... pictures of the install:
Pulling the wire through to the glove box
Make sure you run this AROUND your airbag and hold it down with the included cable holders. You don't want to restrict the movement of the airbag in the event of a deployment.
Behind the glove box, a small hole to work with (esp with big hands like mine)
The constant 12V fuse tap connected
Ground wire connected to this bolt conveniently located in that area
Power controller mounted inside glove box
Wire held down onto the rear view mirror casing for clean look
From inside the car
From the front
I'm quite happy with the image quality and the features are awesome. Now I can have some piece of mind when parking my car. If you are thinking of getting the same one, note there is a version 2 so get that one (didn't do enough research )
      08-29-2012, 09:09 AM   #2
Smiley1175
Smiley1175's Avatar
Australia
283
Drives: M2
Is the quality good enough to read number plates?
      08-29-2012, 09:15 AM   #3
Ninjaoz
Ninjaoz's Avatar
Australia
79
Drives: E39 540i, E90 320d,F15 30d
2011 BMW 320d  [10.00]
Thanks for the write-up, looks neat! It sits nicely just below the rain/light automatic sensor.
I've done a bit of research on the blackvue version II, apparently it overcomes the "heating" problem. Did you have to update the firmware for the English version?
      08-29-2012, 10:15 AM   #4
ippykaye
ippykaye's Avatar
Australia
Drives: 2008 AW 135i
Excellent write-up mate! I've seen a lot that have screens which look bulky- this one looks nice and neat
      08-29-2012, 04:46 PM   #5
Zuzu
Zuzu's Avatar
Australia
2828
Drives: M2C HS 6MT
Neat install and awesome documentation.. Post some vids up..Would love to see the clarity.
      08-29-2012, 04:56 PM   #6
1MOz
1MOz's Avatar
Australia
194
Drives: BMW 1M AW & F15X5 40d & M2C HS
Great job installing this. Looks very professionally done. Nice photos with the write-up as well. I'm sure many of us will find this very useful.
Now you need one for the rear as well!
      08-29-2012, 06:52 PM   #7
sparoz
sparoz's Avatar
Australia
192
Drives: VO 1///M; Macan Turbo
Thanks for the detailed write up!
Macan S Diesel - Carrera White
Macan Turbo - White
1///M - Valencia Orange
      08-29-2012, 07:22 PM   #8
pavo335
pavo335's Avatar
69
Drives: 3.5 wheeler
impressive quality and determination, well done. Don't forget to post up the 'fool' footage.
      08-29-2012, 07:45 PM   #9
BMW86
Australia
398
Drives: RS3 Sedan / Macan S
Great write up. I want one of these.
      08-29-2012, 08:45 PM   #10
KKS
Australia
26
Drives: SO M4
Thanks for your kind words
I don't have any videos uploaded yet as I left my car in Canberra but will definitely put some up.
In the mean time you can youtube blackvue for some sample footage
Daytime:
Night time:
The quality is pretty good and you can see the plates clearly in both day and night.
Some benefits of dash cams:
In an accident, you can prove who is at fault
When parked, it can record anyone in front of your car. (ie if they key it)
Track day camera
Avoid SCAM artists
Here's a vid that was on this forum before featuring a VO 1M at 2:00
      08-29-2012, 08:59 PM   #11
Stuart@BMRAutowerkes
Stuart@BMRAutowerkes's Avatar
814
Drives: a black car
awesome write up.
might look into one
      08-29-2012, 09:13 PM   #12
mcmn
29
Drives: MY10 AW 135i
v nice.
      08-29-2012, 09:48 PM   #13
Knightelf
Australia
87
Drives: M235i
2011 BMW 135i  [0.00]
Neat. Wtf was that VO 1M doing?? Also lol'ed at the lady trying to stop the van at 2:50
      08-29-2012, 09:56 PM   #14
Spikey
Australia
64
Drives: erratically
^ trying to go into the left lane, tyres cross the paint, driver plants foot, spins... etc???
      01-10-2013, 12:57 PM   #15
babubulala
Drives: 2012 F10 535i
@KKS
Can you point me to the hardwire guide (V1) you are talking about? Much appreciated
      01-10-2013, 02:02 PM   #16
BrokenVert
Resident Kerbalnaut
BrokenVert's Avatar
478
Drives: Topless Brute/Hybrid Boogaloo
How secure is It? I normally leave the top down when parked on nice days. Hate to have it stolen.
      01-10-2013, 03:15 PM   #17
1BimmerNut
1BimmerNut's Avatar
Australia
16
Drives: 135i then 130i now F20-125
Oil spill??
WTF? 1M was gone way before he hit the painted lines. Oil? Where was the stability control...weird - kinda scary
      01-10-2013, 03:25 PM   #18
BrokenVert
Resident Kerbalnaut
BrokenVert's Avatar
478
The hivemind decided that he had stability control off and planted his foot not realizing the kick that N54 turbos give.
      01-10-2013, 04:00 PM   #19
Zuzu
Zuzu's Avatar
Australia
2828
Drives: M2C HS 6MT
And the unpredictable M LSD, if you are unprepared..
      01-10-2013, 04:36 PM   #20
3lucidus
Eat Sleep Trance
3lucidus's Avatar
Australia
65
Drives: F80 M3 ZCP
i'm guessing the video is from asia somewhere... hong kong maybe? damn these people cant drive. looks like a solid investment man.
      01-10-2013, 09:07 PM   #21
Jeef Beef
Lord Captain Commander
Jeef Beef's Avatar
Australia
112
Drives: a sleeper
Originally Posted by Ian///M View Post
What are the benefits of this?
Very useful for proving fault in insurance claims and any sort of accident. Concrete video evidence is valued highly by relevant parties.
E82 135i M-sport: SGM/6MT/Black
      01-10-2013, 09:28 PM   #22
Knightelf
Australia
87
Drives: M235i
Also useful for road rage incidents when someone smashes in your windscreen you can send the footage to Today Tonight
Current: 2014 F22 M235i Mineral Grey
Previous: 2011 E82 DCT 135i Space Grey
Build thread: http://www.2addicts.com/forums/showthread.php?t=1149793
Tags
black vue, camera, dash cam, onboard cam
1addicts
