2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum 2016 228i tail light ground issue
      02-28-2024, 04:41 PM   #1
kjazz1958
Drives: 2016 228i
I have the somewhat common tail light "melted ground" issue. I did order a replacement plug kit, but I am wondering if I might be able to simply splice the brown ground wire to the chassis. This would be simpler than having to strip and splice all the wires. The question is: will it work and can I attached the new ground to any metal to achieve an adequate ground?
      02-29-2024, 07:59 AM   #2
MarcoZandrini
449
Drives: 2018 M240i
It will likely work fine.
      03-10-2024, 12:03 PM   #3
kjazz1958
Drives: 2016 228i
Thanks for the reply! I'll give it a try. OK, I did have success that has lasted a few weeks now. As others posted, I took apart the taillight assembly and soldered a single ground wire to the metal "matrix" that runs all around the assembly housing. I spliced this new wire to the brown ground. So now, it has a ground that 1) works and is actually grounded, and 2) there is no plastic connector to melt out from too much current. DO NOT USE THE RECOMMENTED REPLACEMENT PART THAT REPLACES THE ENTIRE CONNECTOR! It will just happen again. Now I know what to do if it happens on the other side. BMW really should have taken care of this design flaw with no time limits on the warranty extension.
      03-11-2024, 01:45 PM   #4
owenscj21
owenscj21's Avatar
53
Drives: 2016 BMW 228i M Sport
Post back when done. I'm curious if this works out for you.
Having the same issue, I recently changed out the bulb holder and replaced with the new harness.
In hindsight, I think it may have been easier to de-pin the old connector and only pin and add the affected ground wire. Would have been much easier than trying to crimp the other 7 pins.
2016 228i M-Sport 6M RWD- CTS Intake, CTS FMIC, VRSF charge pipe, CTS catted downpipe, FTS Stage 2 ECU
      03-21-2024, 02:32 PM   #5
f22liam
f22liam's Avatar
Did this end up working for you?
      04-15-2024, 05:33 PM   #6
kjazz1958
Drives: 2016 228i
Sorry for delay. No, this did not work. I suspect the place where i attempted to screw in the alternate ground did not provide a proper ground. I drilled a hole into the metal housing. Not sure what to try next.
      04-15-2024, 07:39 PM   #7
harma24
404
Drives: 2017 M240i Glacier Silver
2017 BMW M240i  [0.00]
https://www.2addicts.com/forums/show....php?t=1663556
Fun Cars (daily drivers) 2001-2016: 2001 Honda Prelude | 2016 - present: 2017 M240xi Glacier Silver Coupe
Family Cars: 1993-2014: 1993 Honda Accord 10th Anniversary Edition | 2014-Present: 2014 Honda Odyssey
Stable-mate: 2019 - present: 2020 230xi Seaside Blue Convertible
      04-20-2024, 09:45 PM   #8
Uridian
Uridian's Avatar
42
Drives: E36 M3, 228i M Sport
I cut the wire outside the housing, spliced in a split a soldered to the locations in this post.
https://www.2addicts.com/forums/show...67&postcount=6
I did that about a year ago and it's been holding up just fine.
2addicts
