10-15-2012, 12:57 PM | #1 |
Administrator
41320
Rep 21,248
BMW iPhone 5 and iOS 6 Functions, Bluetooth and Y-Cable Overview and FAQ
BIMMERPOST NEWS BMW iPhone 5 and iOS 6 Functions, Bluetooth and Y-Cable Overview and FAQ Apple recently introduced the new iPhone 5. There are three key differences between it and earlier iPhone models that affect its integration in BMW vehicles. First, the physical dimensions of the body of the new phone are thinner and longer compared to the iPhone 4/4S. Second, the iPhone uses a new 8-pin connector in place of the traditional 30-pin connector used on all other iPhone variants as well as iPod touch and iPod nano. The third is the elimination of the analog video signal. Taken together, the result is: 1. iPhone 5 is not compatible with any of the current snap-in adapters available through BMW. 2. The PlugIn feature as a means of accessing one’s music library is not available on the iPhone 5. (Owners are still able to access their music library using a USB cable, see details under “Will I need an adapter to use my iPhone5?”.) 3. Also, watching videos stored on the device, on the car’s screen while parked is no longer possible. FAQ Below is an FAQ regarding the use of iPhone 5 and iOS6, as answered by BMW: Can I connect my phone via Bluetooth to make phones calls, see my contacts and play music? • Yes.Can I still play music from my iPhone 5 in my BMW? • Yes, via the External Devices menu in iDrive.Will I need an adapter to use my iPhone 5? • This depends on the options in the vehicle:Can I use PlugIn and/or play videos from my iPhone 5?◦ No, if you currently use an Apple "white cable" to connect your iPhone to your vehicle. In this case, all you need is the new Apple Lightning cable, included with your iPhone 5. (See our member's DIY guide for creating a cradle and integrating the lightning cable)◦ Yes, if you currently use a Y-Cable to connect your phone. In this case, you will need a "Lightning adapter" to connect your iPhone 5 to the Y-cable. (See "USB vs. Y-cable" on below to determine when a Y-cable is needed for MY 13 vehicles.)◦ The "Lightning adapter" is an adapter available via Apple to convert the old 30-pin plug to the new 8-pin connector or "Lightning cable". It is already on sale by Apple and retails for $29.99 (for the adapter) or $39.99 for the adapter cable. • No, the iPhone 5 Lightning connector does not support analog video, therefore making the PlugIn feature and video playback incompatible. • PlugIn and video playback are still supported when using an iPhone 4/4S with iOS 6.When will the iPhone 5 Snap-In Adapter be available? • BMW's official word on this is that there is currently no timeline set for the release of the iPhone 5 Snap-In Adapter, but as we recently reported, our sources indicate that its currently in developemtn and to expect it sometime around June 2013.Is "BMW apps" compatible with iPhone 5 / iOS 6? • Yes, owners with iOS 6 (incl. iPhone 3GS/4/4S/5) and a "BMW apps" equipped vehicle can continue enjoying the same great app integrations, just as they did with iOS 5.1. This includes Pandora, MOG, Aupeo, Stitcher and BMW Connected. • Pandora is still not compatible with the New Navigation Professional System (SA609) vehicles, but an update is expected from Pandora by November 30, 2012.)Can I use Mobile Office with iPhone 5 / iOS 6? • With the release of iOS 6 (incl. iPhone 3GS/4/4S/5), Mobile Office is now supported for Text Messages and iMessages. This is available in cars with option code 639 / 6NL "BMW Assist with Enhanced Bluetooth". Owners will be able to see their text messages / iMessages on the screen, • Not all of the Text Messages / iMessages on the phone will be displayed in the vehicle. Only new messages received while the phone is connected to the vehicle will be available in the vehicle. • Owners will have to configure their phone as follows to activate this feature: 1. Pair the phone to the vehicle as normal. 2. Under "Settings" and "Bluetooth", press the blue arrow to the right of the paired vehicle: 3. Then turn on "Show Notifications": 4. Also,notifications must be turned on for "Messages" as well: 5. Owners then have to reconnect their phone to the vehicle. This is done by scrolling over the paired phone in the vehicle’s “Bluetooth” menu and pushing the iDrive controller. 6. Returning a phone call via the displayed text message / iMessage is not possible. Owners should either dial the number directly or select a contact from their address book using iDrive. Y-CABLE / BLUETOOTH USB vs. Y-cable: USB is offered standard on all 2013 BMW models, but the available functions differ based on vehicle equipment. Audio playback through the USB port is always included, but may require the Y-cable accessory in combination with an iPhone / iPod. The BMW Apps features are only available in combination with option 6NR "BMW apps". Some of the app features are accessible using the Apple cable, but video playback is only possible with Smartphone Integration (6NF) in combination with the appropriate snap-in adapter. * Plug-In is not currently compatible with the new Navigation Professional system (SA609); a fix is expected later this year. The Y-cable is needed unless the vehicle is equipped with 639 or 6NL "BMW Assist with Enhanced Bluetooth and USB", which is standard equipment on all MY 13 5 Series, 5 Series GT, 6 Series, 7 Series, X5 and X6 models. On most other MY 13 models, 639/6NL is offered in combination with 609 "Navigation system" and/or in the Technology Package and/or as an option. See the chart below for more details about each model’s Y-cable dependency. Bluetooth: Bluetooth comes standard on all 2013 BMW models, but again, the available functions are dependent on vehicle equipment. Please refer to each vehicle’s ordering guide to determine which options are available. |
04-17-2013, 08:46 AM | #3 |
35
Rep 609
My dealer could not find the PN in their system. Do you have any further information?
NB8S Past Garage: Z4, 135i. Present Garage: 2013 X Drive X1 2.8i.
04-17-2013, 09:46 AM | #4 |
123
Rep 1,555
Maybe because you are in the US
2011 E82 1M VO
2013 F84 35i VO |
04-17-2013, 11:47 AM | #5 |
The Only Sane One Here
61
Rep 1,135
I was able to modify my iPhone 3 adapter to work with my iPhone 5. All I had to buy was the Apple lightning adapter ($29.99). It's not pretty, but it's been working fine for several months now. (And it's hidden under the armrest anyway.) Given the outrageous prices BMW charges for these adapters, I'll probably stick with what I have.
Modding an iPhone 3 Adapter for iPhone 5
2011 135i VERT SGM/SB/MOONLIGHT - ED - with every single friggin' option they offered.
05-31-2013, 10:11 AM | #6 |
808
Rep 952
Do you know if this will work if i use it in my '13 135is? Im heading up to Montreal in a few weeks and if it will i may pick one up while im there? If it will can you provide me the local BMW dealership name so i can contact them to see if they will have it in stock.
CURRENT
2017 Boxster S ?718? (07/27/18) 2018 Jeep Wrangler Unlimited Rubicon Recon - (10/28/18) SOLD 2013 BMW 135is #363/586 - AW, Black Boston Leather w/ Exclusive Blue Stitching, Prem., Tech, DCT, Heated Seats, HK |
06-16-2013, 11:46 AM | #7 | |
123
Rep 1,555
2011 E82 1M VO
2013 F84 35i VO |
01-15-2014, 12:39 PM | #8 |
24
Rep 163
Anyone have any idea how to get my iphone 5 to work with a 08 135i.. the lightning to USB that comes with the phone doesn't do anything.. I don't have Idrive and I don't think i have bluetooth either..
02-19-2014, 10:16 PM | #10 | |
Rep 234
PE exhaust, tints...more to come
03-08-2014, 10:19 AM | #11 |
Rep 28
It might be that you need the BMW Y adapter. I believe this is only for the iPhone 4, so you would also need a lightning adapter to connect the 5 to the Y adapter. I've seen this described elsewhere.
03-13-2014, 12:22 PM | #12 |
24
Rep 163
Thanks, the adapter worked perfectly
08 BMW 135i--JB4--DCI--CPE Downpipes--AFE Exhaust--FMIC--ER Charge Pipe W/TiAL BOV--EC-7 Wheels--Rieger Diffuser
06-16-2016, 10:04 PM | #13 |
14
Rep 33
Hey all. Just trying to connect an iPod touch (5th gen) to my 2011 135i for the first time. Looking at the chart in the original post, I do have "639" on my option list which seems to indicate that all I need is a lightning to USB cable. But when I connect it to the car's USB port, nothing happens (other than the iPod starts charging). There is no new selection on the radio's menu, nor can I select USB. What am I doing wrong?
07-22-2016, 12:42 PM | #14 |
verdespider
Rep 20
Radio Help
So I am having an issue with the way my Professional head unit controls the iPhone, specifically the AppleMusic playlists. It will no longer play any AppleMusic radio station based on an artists. So if I have a "Pure Pop" station it will play it, but if you create a station based on Radiohead it will show that station on the head unit but when you select it only the music on your phone appears. You do not get the "iTunes Radio 1 & iTunes Radio 2" option to play the music.
I can't get a straight answer from anyone at BMW because everyone at BMW seems to be clueless. Every thread on here has a different opinion which isn't helpful. I tried to test it on an X1 at the dealer but the elusive Y-Cable was no where to be found. Which brings up another question I have, what is the Y-Cable for? Someone said it was for DRM music but I have a hard time believing this since the iPhone will will play the DRM music. The signal out of the lightning connector isn't amplified so it offers better audio - no? I am looking at the chart above which shows the radio that need the Y-Cable and of course it doesn't jive with what I have, so again I am confused. I do not need or use a Y-Cable. This is what I have: iPhone 6s (any device does it though) running iOS 9.+ 2011 281i Coupe 6FL USB radio interface 6VC Control Combox 663 Professional Radio So, what is the real reason for the Y-Cable? Is anyone else with a Professional having a similar issue with AppleMusic radio stations? Does anyone have a 2011 128i my radio setup? Do you need to use a Y-Cable? I did modify my car a little by having the dealer program the ComBox to activate bluetooth. So even though I do not have the SOS function I do have bluetooth for voice calls. No Audio Bluetooth however. Looking forward to getting some answers! Thanks, Charles |
03-29-2018, 10:49 AM | #15 |
Rep 8
I just got the Bovee WMA3000B for my 2011 135i and it works perfectly. Idiot proof setup. Still have the limitations of a 2011 era vehicle interface - esp with a small screen and having a huge music library - but it's certainly the best solution I've found so far.
07-17-2019, 08:29 AM | #16 |
Rep 3
Pair iPhone Steps
Can someone provide the steps to take to pair an iPhone 7, using BlueTooth to a 2012 135i. I already have connected an Android so I know I have to remove that one first. I did not use any cables when I connected the Android.
07-18-2019, 09:49 AM | #17 |
1274
Rep 173
