10-18-2015, 04:01 PM | #1 |
European Editor
10637
Rep 22,992
DIY: How to figure out which bulb is bad/out on your car?
BMW CCID check control... I have been meaning to post this link on how to check when one of your light bulbs is out or is just about to go out. The system measures the resistance in bulb's filament and sometimes will report a bulb is out even before it burns out. Use this great DIY on how to read the CC-ID code.... http://www.endtuning.com/ccidcodes/ Basically you... Scroll the up/down BC button up or down on the indicator stalk until the word "Check Control" comes up. Press the BC button on the end of the stalk. A fault appears (Light out) Press and hold the bc button for two seconds or so and youŽll get the code. If its a bulb, itŽll be an FRM code Go to http://www.endtuning.com/ccidcodes/ Scroll down to FOOTWELL MODULE and check. Then, change the bulb! DONE!! CC-ID codes: Active Cruise Control ACC 158 Active Cruise Control Disabled, Sensor Error ACC 238 Active Cruise Control Disabled, Hill Descent ACC 441 Cruise Control Deactivated ACC 442 Vehicle may Roll Away ACC 443 Vehicle Rolling Away ACC 483 Active Cruise Control Temporarily Disabled Crash Safety Module ACSM 76 Crash Safety Module ACSM 434 Seat Calibration Required Active Front Steering AFS 70 Servotronic Failed AFS 273 Active Steering Fault AFS 321 Active Steering Deactivated Trailer Module AHM 4 Trailer Parking Light Left AHM 5 Trailer Parking Light Right AHM 6 Trailer Indicator Left AHM 7 Trailer Indicator Right AHM 8 Trailer Brake Lights AHM 9 Trailer Fog Light AHM 75 Trailer Electrics Failed AHM 90 Trailer Reverse Light AHM 403 Trailer Rear Light/Numberplate Light AHM 404 Trailer Left Indicator/Brake Light AHM 405 Trailer Right Indicator/Brake Light AHM 406 Trailer Electric Brake Failed AHM 423 Trailer Coupling Lock AHM 449 Trailer Coupling Electrics Failed Dynamic Drive ARS 10 ARS Roll Malfunction ARS 11 Steering Malfunction ARS 12 Dynamic Drive Failed ARS 204 Dynamic Drive Disabled Car Access System CAS 14 Door Open F/R CAS 15 Door Open F/L CAS 16 Door Open R/L CAS 17 Door Open R/R CAS 18 Bonnet open CAS 19 Boot open CAS 21 Ignition Problem, Depress Brake to Start CAS 22 Starter Problem, Engine cannot Restart CAS 38 Wrong Remote Key CAS 40 Press Brake to Start CAS 65 Change Key, Key Battery Low CAS 66 Remote Control/Key Fault CAS 67 Remote Control/Key Battery Discharged CAS 68 Remote Key Stationary Function Battery Low CAS 186 ELV Steering Lock Fault. Engine cannot be restarted CAS 187 ELV Steering Lock Active. Move Steering Wheel to Restart CAS 205 Remote Key not Present CAS 206 Engine Start on next Press CAS 208 Comfort Access Deactivated CAS 209 Remote Key in Vehicle, Locking not possible CAS 217 No Remote Control CAS 303 Depress Clutch to Start CAS 335 Ignition Switched On CAS 347 Position R/N/D Not Possible CAS 348 Engage Park Before Leaving Vehicle CAS 349 Engage Park Before Switching Ignition Off CAS 413 Steering Column Unlocked Convertible Top Module CTM 267 Rear Window Drive CTM 268 Luggage Compartment Position CTM 270 Convertible Top Not Locked CTM 271 Convertible Top, Vehicle Speed CTM 272 Convertible Top Failure CTM 401 Roof Mechanism Failure CTM 416 Luggage Compartment Partition CTM 432 Roof Drive Overload CTM 445 Vehicle Not Level CTM 516 Roof Operation Cancelled CTM 518 Convertible Top Not Locked CTM 519 Roof Operation Not Possible CTM 558 Roof Position Detection CTM 559 Roof Drive Overheated CTM 560 Roof Operation Not Possible CTM 561 Roof Emergency Operation CTM 562 Roof Unlocked Dual Clutch Gearbox DKG 538 Gearbox Malfunction DKG 539 Gearbox Malfunction 5-7 DKG 540 Gearbox Malfunction P DKG 541 Gearbox Malfunction Manually Release Parking Lock Digital Motor Electronics/Digital Diesel Electronics DME/DDE 25 Preheating, Please Wait DME/DDE 26 Cruise Control Defective DME/DDE 27 Engine Oil Level Low DME/DDE 28 Engine Oil Level Below Minimum DME/DDE 29 Engine Problem, Power Reduced DME/DDE 30 Engine Problem, Stop Engine DME/DDE 31 Engine Problem, Increased Emissions DME/DDE 32 Fuel Cap Open DME/DDE 33 Engine Problem, Reduce Engine Load DME/DDE 39 Engine Overheat, Stop Engine DME/DDE 49 Particulate Filter Malfunction DME/DDE 148 Brake Light Control Failed DME/DDE 182 Oil Level Sensor Malfunction DME/DDE 212 Engine Oil Pressure, Stop Engine DME/DDE 213 Battery Not Charged DME/DDE 220 Battery Discharge Rate High DME/DDE 229 Battery Charge Low DME/DDE 247 Battery Monitoring Failed DME/DDE 257 Engine Temperature Too High, Drive Moderately DME/DDE 304 Check Battery Condition DME/DDE 305 Check Battery Terminals DME/DDE 306 Battery Charge Low DME/DDE 367 Engine Temperature Too High DME/DDE 400 Engine Oil Level High DME/DDE 427 Engine Oil Pressure Low DME/DDE 448 Fuel Filter DME/DDE 450 Automatic Start Deactivated DME/DDE 492 AdBlue Reserve Low DME/DDE 493 AdBlue Reserve Critical DME/DDE 493 AdBlue Reserve Empty DME/DDE 506 AdBlue Fluid Incorrect DME/DDE 584 Transport Mode Active Dynamic Stability Control DSC 24 DBC Dynamic Brake Control Brake Assist Failed DSC 35 DSC Failed DSC 36 DSC/DTC Deactivated DSC 42 DSC Control System/Ride Height adjustment DSC 50 Runflat Indicator Failed DSC 63 Tyre Failure DSC 71 Brake Pads Worn DSC 74 Brake Fluid Low DSC 184 Dynamic Traction Control Active DSC 215 Dynamic Stability Control DSC 236 Brake and Stability Systems Failure DSC 237 Stability Systems Failure DSC 328 Brake Pad Wear Sensor DSC 330 Hill Decent Control not Available DSC 331 Hill Decent Control Active DSC 332 Hill Decent Control Deactivated DSC 333 Hill Decent Control not Possible DSC 334 Run Flat System Requires Standardisation DSC 336 Dynamic Stability Control DSC 352 Brakes Too Hot DSC 353 Brakes Overheated DSC 354 Start Assist Inactive DSC 364 RPA Initialisation DSC 382 DSC Restricted, Brake Pressure Sensor DSC 384 DSC Puncture Detected DSC 431 Brake Loading Too High DSC 608 Tyre Pressure Loss, Front Left DSC 609 Tyre Pressure Loss, Front Right DSC 608 Tyre Pressure Loss, Rear Right DSC 608 Tyre Pressure Loss, Rear Left Corner Brake Control DSC/CBC 42 Brake and Driving Control Failure Tyre Pressure Control DSC/RPA 50 Tyre Monitoring Failure DSC/RPA 63 Tyre Puncture X Drive Control DXC 350 4X4 System Failure DXC 351 4X4 and DSC Failure DXC 369 4X4, DSC and ABS Failure DXC 370 4X4, DSC, ABS and EBV Failure Dynamic Damper Control EDC-K 43 Dynamic Damper Control Failed EDC-K 180 Dynamic Damper Control Fault Electronic Gearbox Control/Sequential Sports Gearbox EGS/SSG 103 Gearbox Overheating- Drive with Care EGS/SSG 104 Gearbox Overheating- Reduced Output EGS/SSG 105 Gearbox Overheated Stop Vehicle EGS/SMG 168 Transmission Malfunction EGS/SMG 169 Transmission Position N EGS/SMG 170 Transmission Malfunction Reset EGS/SSG 171Transmission Failsafe Active EGS/SSG 172 Transmission Malfunction EGS/SMG 173 Transmission Position D Only EGS/SMG 174 Transmission Position P Only EGS/SMG 175 Transmission Malfunction, Position P EGS/SSG 178 Transmission in Neutral, Engage Parking Brake EGS/SSG 179 Transmission Malfunction EGS/SMG 203 Transmission Position in N EGS/SSG 248 Brake Signal Malfunction, Gears May Be Selected Without Brake EGS/SSG 250 Brake Signal Malfunction, Gears May Be Selected Without Brake EGS/SMG 251 Transmission Position P EGS/SMG 252 Transmission Malfunction EGS/SSG 254 Transmission Malfunction Emergency Program EGS/SSG 255 Malfunction R, N, D Only With Engine Running EGS/SSG 287 Clutch Overheated EGS/SSG 288 Transmission Malfunction, Failsafe Activated EGS/SSG 289 Transmission Malfunction, Failsafe Activated EGS/SSG 290 Transmission Malfunction, Journey May Be Continued With Care EGS/SSG 291 Transmission Malfunction, Failsafe Activated EGS/SSG 292 Transmission Malfunction, Re-Select Gear EGS/SSG 293 Press Brake and Select Neutral to Start EGS/SSG 302 Park Not Engaged EGS/SSG 307 Transmission Malfunction, Multiple Failures EGS/SSG 322 Transmission Teach-in Active EGS/SSG 323 Clutch Teach-in Active EGS/SSG 325 Transmission in Neutral EGS/SSG 326 Transmission in Drive EGS/SMG 363 Transmission Overload EGS/SMG 365 Transmission Failsafe EGS/SMG 366 Transmission Fault, Failsafe EGS/SSG 368 Transmission Failsafe Active EGS/SMG 394 Gear Selector Lever EGS/SMG 398 Engine Bay Cover Open EGS/SMG 399 SMG State Undetermined EGS/SSG 419 Drive Malfunction EGS/SSG 420 Transmission Malfunction EGS/SMG 446 Launch Control EGS/SMG 557 Rolling Possible, Secure Vehicle EGS/SMG 565 Gearbox Position P only Available when Stationary Electro Hydraulic Brake EHB 439 Parking Brake Overload EHB 452 Release Autohold Electronic Height Control EHC 45 Level Control System Failure EHC 245 Level Control System Failure Electric Fuel Pump EKP 216 Fuel Pump Fault EKP 309 Fuel Pump Malfunction Parking Brake EMF 48 Parking Brake EMF 51 Parking Brake Overheated EMF 52 Parking Brake Failed EMF 53 Automatic Hold Malfunction EMF 54 Parking Brake Malfunction EMF 55 Parking Brake Release EMF 56 Parking Brake EMF 57 Parking Brake EMF 58 Parking Brake EMF 201 Automatic Hold Disabled EMF 210 Parking Brake Failed EMF 211 Parking Brake Failed EMF 239 Parking Brake Failed EMF 240 Parking Brake Failed EMF 241 Parking Brake Failed EMF 242 Parking Brake Failed EMF 243 Parking Brake Failed EMF 253 Parking Brake Failed EMF 395 Parking Brake Malfunction EMF 402 Apply Foot Brake EMF 410 Parking Brake Malfunction EMF 465 Parking Brake Failure EMF 480 Parking Brake Malfunction EMF 481 Parking Brake Malfunction EMF 482 Parking Brake Failure Electronic Power Steering EPS 73 EPS Inoperative EPS 385 Steering Assistance Failed High Beam Assistant FLA 374 Main Beam Assist Defective FLA 375 Main Beam Assist Not Active FLA 376 Main Beam Assist Not Active FLA 377 Main Beam Assist Sensativity Footwell Module FRM 87 Right Rear Light Failure FRM 88 Dipped Beam Left Failure FRM 89 Dipped Beam Right Failure FRM 111 Number Plate Light Left Failure FRM 113 Sidelights Switched On FRM 114 Rear Fog Light Failure FRM 115 Reverse Light Right Failure FRM 116 Indicator Rear Left Failure FRM 117 Reverse Light Left Failure FRM 118 Rear Light Right Failure FRM 119 Indicator Front Right Failure FRM 120 Dipped Beam Left Failure FRM 121 Dipped Beam Right Failure FRM 122 Indicator Front Right Failure FRM 123 Rear Light Right Failure FRM 124 Indicator Right Failure FRM 125 Indicator Rear Right Failure FRM 126 Fog Light Right Failure FRM 127 Side Indicator Left Failure FRM 128 Left High Beam Failure FRM 129 Rear Fog Light Failure FRM 130 Right High Beam Failure FRM 131 Parking Light Left Front Failure FRM 132 Front Right Side Light Failure FRM 133 Right Rear Light Failure FRM 134 Right Brake Light Failure FRM 135 Centre Brake Light Failure FRM 136 Left Brake Light Failure FRM 137 Number Plate Light Right Failure FRM 138 Fog Light Left Failure FRM 196 Indicator Front Right Failure FRM 197 Indicator Front Left Failure FRM 231 Light System Failure FRM 256 Headlight Leveling System Failure FRM 259 Window Anti-Trap Deactivated FRM 261 Window Anti-Trap Failure FRM 345 Brake/Tail Light Failure Right FRM 346 Brake/Tail Light Failure Left FRM 371 Number Plate Light Failure FRM 372 Brake Force Display Light Failure Left FRM 373 Brake Force Display Light Failure Right FRM 378 Sidelight/Daytime Lights Defective- Left FRM 379 Sidelight/Daytime Lights Defective- Right FRM 380 Turn Signal Lights Defective- Left FRM 381 Turn Signal Lights Defective- Right FRM/ALC 295 Adaptive Cornering Lights Failure FRM 437 Parking Lights On Gear Selector Switch GWS 393 Gear Selector Position GWS 467 Gear Selector Malfunction/Locking Luggage Compartment HKL 422 Luggage Compartment Lower Lid Hybrid HYBRID 569 Drive Malfunction, Stop HYBRID 570 Drive Range Low HYBRID 571 Drive, Only Forward Crawling Speed is Possible HYBRID 572 Drive, Only Forward and Reverse Crawling Speed is Possible HYBRID 573 Gearbox Malfunction HYBRID 574 No Braking Energy Reclamation HYBRID 575 Refueling- Wait HYBRID 576 Refueling Only Possible When Standing HYBRID 577 Refueling Possible HYBRID 578 Fuel Filler Flap Open HYBRID 579 Fuel System Malfunction HYBRID 585 High Voltage System Malfunction HYBRID 586 High Voltage System Malfunction HYBRID 587 High Voltage Battery Low HYBRID 588 High Voltage Battery, Switch Ignition on to Charge HYBRID 589 High Voltage Battery Charging HYBRID 590 Vehicle Ready HYBRID 591 High Voltage Battery Charging Aborted HYBRID 606 High Voltage Battery Output Restricted HYBRID 607 High Voltage Battery Regeneration Required Intergrated Chassis Management ICM 474 Driving Performance Control Failed Instrument Cluster IKE 13 Radio Key in Lock IKE 41 Service Due IKE 55 Parking Brake Active IKE 60 Speedometer Failure IKE 62 Vehicle Speed Limit Exceeded IKE 78 Vehicle Speed Limit Exceeded IKE 79 Low External Temperature IKE 165 Low External Temperature IKE 167 Reset Clock IKE 185 Gear Indicator Failed IKE 275 Low Fuel IKE 279 Driver's Seat Insecure IKE 280 Passenger's Seat Insecure IKE 281 Service Due IKE 282 Instrument Cluster IKE 283 Instrument Cluster IKE 284 Service Overdue IKE 285 Service OK IKE 286 Fuel Low / Range IKE 301 Seatback Monitoring Failed IKE 308 Parking Brake Applied IKE 999 Instrument Cluster Fault Junction Box JB 164 Windscreen Washer Fluid Low JB 166 Engine Coolant Level Low JB 183 Windscreen Wiper Malfunction JB 207 Central Electronics Failure, Stop Vehicle JB 415 Battery Discharge Rate High JB 430 Transport Mode Active Longitudinal Dynamics Management LDM 1 Active Cruise Control Disabled, Poor Conditions LDM 2 Active Cruise Control Disabled, Poor Signal LDM 3 Active Cruise Control Failure LDM 59 Active Cruise Control Disabled, Parking Brake LDM 69 Active Cruise Control Disabled, Speed too Low LDM 85 Active Cruise Control Disabled, Hill Descent LDM 176 Active Cruise Control Disabled, Sensor Error LDM 177 Active Cruise Control Malfunction LDM 199 Cruise Control Failed LDM 246 Active Cruise Control Disabled, Speed too Low LDM 276 Engine Speed Too High LDM 277 Active Cruise Control Disabled, Gear Selection LDM 278 Engine Speed Too Low LDM 337 Dynamic Cruise Control Failure LDM 338 Dynamic Cruise Control Deactivated, Parking Brake LDM 339 Dynamic Cruise Control Deactivated, Excessive Braking LDM 340 Dynamic Cruise Control Deactivated, Poor Conditions LDM 341 Dynamic Cruise Control Deactivated, Gear Selection LDM 342 Dynamic Cruise Control Deactivated, Speed Too Low LDM 453 Cruise Control Short Range Sensors Disabled LDM 454 Cruise Control Short Range Sensors Soiled LDM 469 Cruise Control Deactivated, Sensors Soiled LDM 478 Cruise Control Deactivated, Radio Astronomy Intervention Electric Sunroof MDS 260 Sunroof Anti-Trap Deactivated MDS 262 Sunroof Anti-Trap Failure Multiple Restraint System MRS 46 Fasten Seat Belt MRS 91 Fasten Seat Belt MRS 92 Front Passenger Seat Belt Pretensioner Fault MRS 93 Driver's Seat Belt Pretensioner Fault MRS 94 Rear Left Seat Belt Pretensioner Fault MRS 95 Rear Right Seat Belt Pretensioner Fault MRS 97 Multiple Restraint System Fault MRS 106 Rear Left Side Airbag Fault MRS 107 Rear Right Side Airbag Fault MRS 108 Driver's Airbag Fault MRS 109 Passenger Airbag Fault MRS 181 System Check Failed MRS 266 Rollover Protection Malfunction MRS 389 Fasten Driver's Seat Belt MRS 390 Fasten Passenger's Seat Belt MRS 391 Multiple Restraint System MRS 392 Fasten Seat Belt MRS 612 MRS Acceleration Sensors Night Vision Control NVC 356 Night Vision Failure Park Distance Control PDC 195 Park Distance Control Failure Reversing Camera RFK 424 Reversing Camera Soiled RFK 425 Reversing Camera Failure Tyre Pressure Control RDC 139 Front Left Tyre Pressure RDC 140 Rear Right Tyre Pressure RDC 141 Rear Left Tyre Pressure RDC 142 Check Tyre Pressures RDC 143 Front Right Tyre Pressure RDC 144 Tyre Pressure Monitoring Fault RDC 145 Tyre Pressure Monitoring Deactivated RDC 147 Tyre Puncture Detected RDC 149 Tyre Pressure Monitoring Failure RDC 192 Tyre Pressure Monitoring Deactivated, System Initialising RDC 265 Check Tyre Pressures, Mismatch RDC 327 Tyre Pressure Monitoring Deactivated, System Initialising Sensotronic Braking Actuation SBA 601 Braking System Malfunction SBA 602 Braking System Malfunction SBA 603 Braking System Sensor Malfunction SBA 604 Braking System Failure Seat Module SIMO 436 Seat Position Detection Fault Telecommunications Module TCU 296 SOS Deactivated, Check Phone TCU 297 BMW Assist Deactivated TCU 298 BMW Assist Not Possible TCU 299 SOS Call System Failure TCU 300 BMW Assist Deactivated, Check SIM. Time to Line Crossing TLC 435 Lane Departure Warning Fault Video Switch VSW 428 Side Camera Defective PS: I also found this page helpful with bulbs on our cars... https://wiki.bentleypublishers.com/d...90+E91+E92+E93
10-18-2015, 11:00 PM | #2 |
bimmerphile, technogeek
1000
Rep 3,786
Drives: 2012 E82 6MT Sport
Great info... Thanks!
11-19-2018, 05:06 PM | #4 |
European Editor
10637
Rep 22,992
Glad I could be of assistance.
