05-01-2014, 07:27 AM | #23 |
314
Rep 1,017
Drives: 2010 E92 M3 6MT
The only true fix I have seen for this is to have your crank turned, milled down just a tad. It just to tight stock, would you offer this service? Also can you torque plate down the engine/mill/polish block back to specs? Don't know why they don't do this when they build the engine but its what causes these cars to eat oil.
4.4L LC stroker/ESS VT2-625/Volk te37 sl's/AA exhaust/DSS Carbon Fiber driveshaft/ARH Headers.. etc |
05-20-2014, 11:31 AM | #25 |
BimmerPost Supporting Vendor
8268
Rep 18,855
Drives: BMW
No issues reported with main bearings that we're aware of. The block will need to be split to remove crank, it's easiest with engine removed.
09-12-2014, 12:07 PM | #27 |
8268
Rep 18,855
Drives: BMW
Info
Vehicle: 2008 BMW M3, 6MT Production Date: 12/07 Oil Used: TWS Motorsport 10W-60, 7500mi intervals Mileage: 62,833 mi Fuel: 91 Oct Driving Habits: Street driving, no track use Oil Analysis: None provided Notes: M3 was just purchased on used market, came in with audible ticking. After getting oil analysis performed, it was quickly scheduled in for bearing service. Engine failure imminent if not attended to immediately. Bearings were replaced with WPC Treated Bearing Set & ARP Rod Bolts. Engine and oil cooler/lines flushed to clean out any remaining debris. Images: As seen, bearing #2 suffered the most damage, with all remaining bearings showing considerable wear. Bearing particles were visible in oil filter element, required flushing to make sure all particles were removed from engine, lines and cooler. Blackstone Oil Report: Driver is very lucky to still be driving his M3. Schedule your appointment today!
01-06-2015, 06:09 PM | #29 |
8268
Rep 18,855
Drives: BMW
Appointments available, call or PM/email to schedule your service today.
01-07-2015, 01:38 AM | #30 |
108
Rep 536
Silly question, do you offer the VAC bearings as well? Or just the WPC?
Everyone! I'm not trying to start a flame war over what's better than the other?! Its just a preference thing. |
01-17-2015, 03:06 AM | #31 | |
106
Rep 589
Since I'm a bit far from u...
2008 e92 335 FBO
2011 e92 M3 ZCP DCT 2015 f82 M4 DCT |
03-06-2015, 11:44 AM | #33 | ||
8268
Rep 18,855
Drives: BMW
If you have not been replied to, my apologizes, sometimes the forum does not email notifications on certain threads.
Any other questions, please call, email or PM directly for the quickest reply.
03-06-2015, 04:35 PM | #34 |
829
Rep 3,387
Thanks, Tom, but you PMed me the answer the same day I asked
03-06-2015, 05:05 PM | #35 |
8268
Rep 18,855
Drives: BMW
Just making sure no one got missed!
03-18-2015, 12:14 AM | #36 |
202
Rep 487
Great price. Debating on towing my car down from the Bay Area to have the work complete by Tom.
2004 M3 E46 LSB 6MT
2008 M3 E92 6MT 2024 M4 Competition xDrive |
03-20-2015, 10:31 AM | #37 |
Rep 31
Drives: '11 E90 M3, '14 X11, '06 S2000
Is it safe to assume that none of this would be covered under a factory, CPO or extended warranty? I assume so since either failure needs to occur, or the owner is concerned and having it checked.
I'm picking up an '11 E90 on Monday and planning on having the oil analyzed shortly after to determine if I should have the rod bearings looked at. |
04-10-2015, 10:23 PM | #38 | |
8268
Rep 18,855
Drives: BMW
04-20-2015, 12:00 PM | #40 | |
391
Rep 1,133
Drives: 2008 Jet Black M3 Coupe
04-20-2015, 12:11 PM | #41 |
8268
Rep 18,855
Drives: BMW
We have parts listed on our website, feel free to PM m3 if you are looking for anything specific.
Blackstone has done this in the past, typo on their part. There's 16 bearings (upper/lower) showing.
04-27-2015, 12:23 PM | #42 |
34
Rep 72
Hey Tom, I bought an e92 m3 2012 second hand and currently has 28k. Recently I've noticed a growing ticking noise separate from the ticking generated by the lifters. Its coming from the bottom left of the engine close to the drivers wheel well and the clicking is in unison with the rpm speed. Its not quite a developed rod knock noise but after doing some research I fear it may be a rod bearing issue. Now, I still have a year of original factory warranty but I still plan on getting the rod bearing upgrade from eas however had a few questions.
-since I’m under warranty, I plan on having my engine checked by the dealer. Can anyone suggest the best way to approach the dealer? -if the rod bearings are indeed the issue, will the dealer swap out the bearings with the same OEM bearings potentially causing this to happen again? -these issues were never fixed for the newer M3s? (my 2012) Thanks in advance! |
04-27-2015, 12:50 PM | #43 | |
8268
Rep 18,855
Drives: BMW
Blackstone oil test beforehand is never a bad idea. We can always inspect if you would like, feel free to contact me directly if you have any questions.
05-14-2015, 06:29 PM | #44 |
2944
Rep 21,754
Full service rod bearing replacement available at eas
PM today for details
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
Tags |
bearing, eas, journal, rod bearings |
