      08-29-2020, 08:56 AM   #1
Spyros E81
Spyros E81's Avatar
Greece
240
Drives: BMW X1 U11 Sdrive 18i
Lower with H&R springs
Hi to all community.It needs a little bit more to make the exterior more aggressive.This time i choosed the H&R spring set with 30mm lowering.The difference was so huge with the oem set both on height and in turning.
Enjoy with photos
[IMG]undefined[/IMG]
      08-29-2020, 05:50 PM   #2
BlownLSX
BlownLSX's Avatar
213
Drives: C6Z, X3MC
Wonder if these are compatible with the f44. Would love to go a little lower.
      08-30-2020, 07:44 AM   #3
knali8
knali8's Avatar
429
Drives: 2021 X3M Comp
Very nice ride hight. Also where did you get you front lip from? It looks good!
      08-30-2020, 07:46 AM   #4
knali8
knali8's Avatar
429
I have the eibach pro kit and the car sits a little lower. I would have preferred the h&r spring height.
I would think that the m135i springs would fit the m235i but not certain.
MrFoxy376.50
      08-30-2020, 03:54 PM   #5
Spyros E81
Spyros E81's Avatar
Greece
240
Thanks a lot mate.The front lip came from Maxton Design
      08-31-2020, 03:11 PM   #6
Gregus330i
Gregus330i's Avatar
102
Drives: BMW 330i M Sport
You're lucky, you must live in an area with very few or no speed humps, unfortunately I struggled with lowering springs, just too many undercarriage scrapes on too many speed humps which some are quite high, in London where I live, so took them off 😒
      09-01-2020, 07:39 AM   #7
knali8
knali8's Avatar
429
Jeez you would think by now they would be putting lower and longer humps
      09-10-2020, 02:11 AM   #8
Lambster
Car go brum
Lambster's Avatar
Drives: BMW M135i (F40)
H&R have just released springs for the F44 M235i. However, I asked them about the F40 M135i and they said they currently don't support this model. What springs are you using Spyros E81 ?
Anyone know if the springs specifically need to be made for the XDrive system to cope with extra loads etc or could we use the same springs used for a 118i without issue?
      09-11-2020, 04:45 PM   #9
Spyros E81
Spyros E81's Avatar
Greece
240
Before i place the order i had already ask the H&R what part number of springs can be use to my car (exactly with load kg).Within an email send me the compatible set of springs.
I don't want to make a promotion but from this site you can find your set.https://www.sandtler24.de/#/dfclassi...name=match_and
      09-11-2020, 07:12 PM   #10
knali8
knali8's Avatar
429
That's really good that you can choose the lowering height. I'm guessing you can choose between 35mm to 30mm total drop height?
I only had one option with eibach.. 40mm drop for Australian cars.. only one opinion
      01-04-2021, 04:18 PM   #11
caren22
Drives: M4 2018
H&R have just released springs for the F44 M235i. However, I asked them about the F40 M135i and they said they currently don't support this model. What springs are you using Spyros E81 ? and additional info on https://justdomyhomework.com/ site
Wow that thing looks slick!
cacacaren
      02-12-2021, 02:28 PM   #12
1MFaN
Drives: BMW
Enjoy with photos
What spring set did you go for?
I am needing a set for an F40 M135iX
Springs are 28635-1 OR 28635-2
Also do you know the weight of your front / rear axle?
If you use 28635-1 (max. 1050 kg front axle load).
If you use 28635-2 (1051kg and heavier).
      02-14-2021, 11:25 AM   #13
Spyros E81
Spyros E81's Avatar
Greece
240
Enjoy with photos
First check your car's label on passengers B pillar ( down ) and here you can find your axle load limit.Then check this site ( https://www.sandtler24.de/search?sSearch=bmw%2Bf40&p=1 ) and you can find your right part number.
      03-27-2022, 04:20 AM   #14
kitz79
Drives: BMW F40 116i
Enjoy with photos
Hi. Is there any significant difference in stiffness after changing the springs?
      04-08-2022, 08:24 AM   #15
DEXTER216
Drives: bmw m135i f40
are more lower then Eibach??
      11-07-2022, 10:41 PM   #16
hgalanos
Drives: BMW M235i xDrive
Camber bolts
Hey guys,
I just bought a set of H&R for my F44.
I noticed camber bolts can't be used as the struts are attached from the base.
Did anyone add camber adjustable arms, front and rear?
Is camber an issue? Drop isn't huge, but want to ensure I have all I need before installing the springs.
Any feedback would be great.
Thanks.
      11-10-2022, 03:07 AM   #17
TopperXP
TopperXP's Avatar
27
Drives: BMW F30 320i m sport / BMW F40
Hello was it ok to fit ?
Cheers
      11-29-2022, 09:17 PM   #18
markb50k
markb50k's Avatar
Drives: 2022 F44 M235ix
I just put HR springs on my '22 M235i. Part 28635-2
Ride is not bad but definitely more feel to the road. Love the way the car sits now.
Before/After
1998 E39 528i
2003 E46 M3
2004 E46 328cic
2022 F44 M235ix
      05-26-2023, 01:23 PM   #19
Mitchd10
Mitchd10's Avatar
13
Drives: BMW 128ti
Before/After
Looks good 👍🏻
What is the official drop on these?
