M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      01-11-2024, 03:15 PM   #1
imtyce
imtyce's Avatar
Drives: Bmw M5
Vanos issue S63tu
I just replaced all 4 solenoids and camshaft sensors after i found i had a vanos exhaust code. Car still saying vanos code also in limp mode. I was told the vanos gear needed to be replaced. Is there any other way to find out whats causing vanos issue without replacing the gear?
      01-15-2024, 09:56 AM   #2
anoller
Drives: F10 M5, F10 535i, Duramax, etc
Let me guess. Also getting “cold start uncontrollable” and “lift values 2000%” ?
I’m chasing the same thing. Coils, plugs, solenoids, camshaft position sensors… all nothing.
      01-15-2024, 03:33 PM   #3
imtyce
imtyce's Avatar
Drives: Bmw M5
Yeah man it might be the gear just trying to work my way around it so it doesn’t need replaced heard it’s a big job.
      01-15-2024, 06:58 PM   #4
JayDD007
105
Drives: BMW's
2020 G07 X7  [0.00]
2013 E70 X5  [0.00]
2003 E46 M3  [0.00]
2013 F10 M5  [0.00]
2009 E90 335ix  [0.00]
2009 E90 M3  [0.00]
Vanos is a relatively simple system. If the oil was changed and the solenoids were replaced it’s 90% chance a gear replacement is required.
      01-15-2024, 08:34 PM   #5
imtyce
imtyce's Avatar
Drives: Bmw M5
When i replace the gear does the timing chain have to be replaced?
      01-17-2024, 07:29 PM   #6
anoller
I’m going to do the chain while I’m there, it’s a big/expensive job labor-wise so why not just do some extra parts while you’re there. I’m at 106k, so I’m going to do chain/tensioner and cam gear
      01-20-2024, 07:21 AM   #7
JayDD007
105
Drives: BMW's
2020 G07 X7  [0.00]
2013 E70 X5  [0.00]
2003 E46 M3  [0.00]
2013 F10 M5  [0.00]
2009 E90 M3  [0.00]
No it does not
V8 timing chains are an astronomically larger job than just doing a gear (heads, oil pans both coming off, obviously engine removal)
The gear can be replaced with just removing the valve cover and front drive belt/ crank pulley
M5Rick61854.00
      01-20-2024, 09:10 AM   #8
imtyce
imtyce's Avatar
Drives: Bmw M5
Yeah man let me know how it goes. good luck
      01-26-2024, 07:26 AM   #9
imtyce
imtyce's Avatar
Drives: Bmw M5
The motor doesn’t need to be dropped right?
      02-06-2024, 09:00 AM   #10
imtyce
imtyce's Avatar
Drives: Bmw M5
Did you get it done yet?
      02-20-2024, 09:22 AM   #11
anoller
Not yet, have had some things pop up in life (lost my daughter to a brain tumor, 7yrs old). Car is on a battery tender in the garage. Been trying to keep my household together and figure out the next day as it comes. If you find a solution, please let me know. I’d like the answer or at least know what’s going on before I drop it somewhere for work.
Appreciate 2
M5Rick61854.00
JDMSteven479.00
      02-20-2024, 09:36 PM   #12
imtyce
imtyce's Avatar
Drives: Bmw M5
Ah man sorry about that, hope your doing well. Yeah i’m doing the gear myself this week i’ll let you know asap when i’m all done👍🏼 stay strong man.
      02-24-2024, 04:01 PM   #13
anoller
Thank you. I appreciate it.
Have you found a fix yet?
      04-30-2024, 04:16 PM   #14
imtyce
imtyce's Avatar
Drives: Bmw M5
I just replaced the gear and im still getting the code not sure, Have you done the job yet?
      05-23-2024, 08:01 PM   #15
anoller
So I haven’t done it yet, car has been on a battery tender and I run it every so often. But I did take it to a reputable Indy shop and they said it was the VANOS actuator. The electric motor that turns the VANOS gear in the head.
m5post
