02-02-2018, 10:26 AM | #1 |
362
Rep 1,206
Custom tune vs OTS
Any one have real world experience on going from an OTS map to a custom tune on a FBO car? Are there gains to be had. I am talking about Hp gains. Not driveability gains.
02-03-2018, 03:26 PM | #2 |
82
Rep 305
I believe there has been a few post of people getting a pro tune done on Bootmod3 and gained a decent amount of power. It was an M3 if I recall.
Lawrobuk170.00 Fr3sh29.50 |
02-05-2018, 12:55 PM | #3 | |
BimmerPost Supporting Vendor
4922
Rep 115,999
Mike |
02-05-2018, 01:03 PM | #4 |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
The BM3 OTS Maps has shown across the board to outperform most other Custom Tunes out there.
Not just better Gains but better Powerband as well with less boost. At the end of the day, Custom Tunes will push the car more or can be tuned to your own driving needs. Seek info from your tuner and get before/after dyno to see your delta and power band. A lot of ppl have opt for the OTS map for daily and Custom Tune for weekends / race events PS. Boost is not the only way to make power in these cars and it is known the HPFP will start failing when pushing too much boost and putting stock turbo out of efficiency (hot and not make more power)
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
DragonGate71.50 |
02-06-2018, 04:19 PM | #5 | |
24348
Rep 191,156
Some OTS maps are aggressive off the shelf while others are very conservative making room for their custom tuners to offer their own maps for profit
FSociety3812.50 |
02-06-2018, 05:42 PM | #6 |
362
Rep 1,206
02-06-2018, 09:46 PM | #7 |
82
Rep 305
Maybe, but there is also the amount of time and research they can spend per platform or ecu. You can often find they well get the ECU up and running with decent performance and allow dealers to get the remaining gains out of it. This will allow them to unlock more ECU's in a shorter time frame allowing for more people to take advantage of the product.
02-06-2018, 09:49 PM | #8 | |
24348
Rep 191,156
It would not make any business sense for them to offer the best map off the shelf, no shop/tuner is going to push their products which will dramatically decrease their sales Nothing wrong with it of course, but something to keep in mind for users looking to make max power.
02-06-2018, 10:10 PM | #9 | |
82
Rep 305
Working on the side of a tuning company, nothing for BMW. One thing people people don't know is how OEM companies can have 100's of variations of ECU's in their cars world wide, we call these variations Box Codes. Often this requires having a car present on a dyno first hand to make a file for them. Sure you can tune them via of log tuning but we find this isn't as safe as having the car present to tune them. It really slows the process of tuning for all the cars in the world. So I can see a benefit for tuning a base file for the masses and letting a "Pro Tuner" develop a better file. Just pointing out there is two sides to the story. I can go in to more detail on how world wide tuning makes things very difficult and why both options can be present in that model. However, I think you'll find them both in the works. |
FSociety3812.50 |
02-07-2018, 01:50 AM | #10 |
1086
Rep 2,369
The PTF Stg2 93 OTS (for Pure Stg2 Turbo) will target 17psi flat (the case for Rev3). This is right on the edge of what your fuel system can deliver. I guarantee there is no performance to gain with a custom tune
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
02-07-2018, 04:22 PM | #11 |
102
Rep 316
Harkes are you running the map you referenced as a BEF to the JB4? Or are you running the OTS alone?
02-07-2018, 05:55 PM | #12 |
52
Rep 100
I just dyno'd my car and I got 366 hp and 411 lb-ft with a bm3 OTS 91octane stage two tune. I don't foresee a custom tuning being able to get much more out of the car.
02-07-2018, 06:52 PM | #14 | |
24348
Rep 191,156
You have more room for torque
02-07-2018, 07:43 PM | #15 |
1009
Rep 1,388
02-07-2018, 07:59 PM | #16 |
1009
Rep 1,388
Vehicle: 2014 BMW (F32) 435i 8-Speed Software Level: Stage TWO - ECU Software Additional Mods: VRSF Downpipe | MPerf. Exhaust ------------------------------------------------------ DELTA Gains Peak: 58HP | 116TQ at the wheels. MAX: 87HP @ 4,150 RPM | 124TQ @ 3,100 RPM ------------------------------------------------------ |
02-07-2018, 09:37 PM | #17 |
Father of Frankenfold
299
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
The OTS tunes are great, but they're still fairly general purpose, if on the aggressive side. I think they're fine for FBO with stock turbo at sea level.
I'm running PS2 with BM3 OTS 2H 93 map. It's very rich (12.2 - 11.8) and doesn't hit boost target of 17 psi well at my 5,500 foot altitude. More like 2-4 psi under. I'm sure I'd pick up good power with a custom tune. I've just started stacking JB4 to hit the flash boost target of 17 psi. Huuuuge difference. Picked up 7 mph in trap speed (12.75 @ 116 mph stacked vs. 12.56 @ 109 mph flash only) on a super rough first attempt, still under flash target and with a 1 second slower 0-60 (5.21 stacked vs 4.14 flash, 1.92 60 foot stacked vs. 1.86 flash). Hopefully once I've got everything sorted I can go back for a retune with enough detail to let the tuner match what I've been able to produce in terms of boost curve and targeting and ditch the JB4 for that flash smoothness again. BTW, does anybody know any details of high altitude tuning on the N55. I didn't recognize any barometric compensation tables in the BM3 tables. Not that I really know exactly what to look for if it didn't jump out at me.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
02-08-2018, 02:23 AM | #18 | |
1086
Rep 2,369
At the moment boost control is better with JB4; BUT the car has a more "natural" feel running flash only and spool feels faster
(A Dane in China) |
hardparker299.00 |
02-08-2018, 08:56 AM | #19 |
967
Rep 2,658
Pardon my ignorance but I'm just getting into BM3 and learning all I can. I'm currently running a 2014 335i XDRIVE w/EWG, MPE and a drop-in K&N air filter, everything else is stock. If I decided to flash BM3 which MAP should I be using for best performance/reliability?
02-08-2018, 11:37 AM | #20 | |
362
Rep 1,206
02-08-2018, 01:01 PM | #21 |
967
Rep 2,658
Cool thank you. I see BM3 throws in the "GTS Transmission Flash". Does this flash pertain only to M3, M4 and M2 DCT equipped vehicles, or can this be flashed to other platforms as well?
Also, do they include a Stage 1 OTS map when you purchase a license or is that a separate purchase? |
02-08-2018, 10:03 PM | #22 | |
1086
Rep 2,369
(A Dane in China) |
