11-11-2021, 07:06 AM | #1 |
219
Rep 210
Coding out airbags
I recently removed my side curtain airbags and seatbelts in my track car. I tried to disable all the airbag features in ProTools but I am still getting an airbag light and a ton of related codes. Has anyone successfully done this and removed the codes? I feel like there is maybe an order I had to do it? Like keep them plugged in, code them then remove them? Or unplug them then code it out?
Any help would be appreciated, here are the codes I' getting now. MRS [MRS5] | 93C8: Airbag front sensor, left MRS [MRS5] | 93B2: Safety battery terminal MRS [MRS5] | 93B0: Head airbag, left MRS [MRS5] | 93B1: Head airbag, right MRS [MRS5] | 9416: Retractor tensioner, left MRS [MRS5] | 93C9: Airbag front sensor, right MRS [MRS5] | 941A: Belt-force limiter, right MRS [MRS5] | 9417: Retractor tensioner, right MRS [MRS5] | 9419: Belt-force limiter, left MRS [MRS5] | 93D2: Telltale lamp for front passenger airbag deactivation |
11-11-2021, 11:23 AM | #3 |
453
Rep 277
Can you post the resolution for this?
2009 Widebody 135i ///Build Thread
Instagram: ///TheAxisGarage If you ride like lightning, you're gonna crash like thunder. |
11-11-2021, 11:51 AM | #5 |
505
Rep 649
Unplug the ABG module completely then code the KOMBI:
SFY_ALIVE_ZAEHLER nicht_aktiv SFY_ID_MONITOR nicht_aktiv Then reset all errors in all modules. If this doesn't work you may need to plug everything back into the ABG, then code the KOMBI then remove the ABG. |
AndyW674.50 |
11-11-2021, 12:52 PM | #6 |
219
Rep 210
Is the ABG module the one in the center console?
11-11-2021, 01:35 PM | #8 |
219
Rep 210
One more error I am hoping you can help with. I THINK its from pulling the headunit or the SoS module in the headliner. Google also seems to think the code could be a speed sensor though.
KOMBI [KOMB87] | A56F: Message incorrect (status emergency request, 0x2C3), KOMBI receiver, CBX-ECALL transmitter |
11-11-2021, 01:35 PM | #9 |
505
Rep 649
Cool. Two things of note: your DME will have a code on because it can't see the battery disconnect and if you have an auto/DCT it will have a code because it can't see the seat belt buckle. Neither of these have any impact on anything.
AndyW674.50 |
11-11-2021, 01:38 PM | #10 | |
505
Rep 649
COMBOX_ALIVE_MONITOR night_aktiv COMBOX_ID_MONITOR nicht_aktiv |
11-11-2021, 01:54 PM | #11 | |
219
Rep 210
KLIMA [IHKA87_2] | E723: Message error (status condensation window glass front, 0x2D1), receiver integrated automatic heating / air conditioning system, transmitter roof function centre |
11-11-2021, 02:48 PM | #12 | |
14
Rep 101
I want to retain steering wheel, passenger front and passenger side airbags with a race seat in the driver side. |
11-15-2021, 07:54 AM | #13 | ||
505
Rep 649
You just need to code the airbag module. You can find the options to code around here somewhere. |
04-16-2024, 11:36 PM | #14 |
Supreme Galactic Commander (one galaxy over...)
675
Rep 1,778
Is this where it is? I am about 3 years behind you and amg6975 in getting my car to a "track only" state so expect a lot of questions...
Best,
Andy '12 E82-PS2,Stoptechs,Clubsports+M3 bits,Accusump,Wagner DP+EVO III FMIC,ERCP,BMS Intake,Mason Strut Bar,Wedge Tune |
04-17-2024, 01:17 AM | #15 |
35
Rep 51
Drives: e82 135i / e36 M3
Subbed to the thread, just deleted my sunroof and side airbags myself. Will be doing bucket seats and a rollbar soon as well so I'll wait until then to code everything out. Thanks for the info 😎
04-17-2024, 09:28 AM | #16 | |
593
Rep 728
My car is fully stripped down to the wiring harness. It's really great when you don't have a single warning light thanks to ProTool. |
