BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > Regional Forums > Canada
BPM
      06-21-2009, 03:34 PM   #1
Fanta
C
Fanta's Avatar
51
Drives: 740iL, M3, Carrera
Need tires advice for track
I would like to gain some track experience.
I only have a set of stock 18" wheel and tires, don't want to mess around it.
I consider between two options to get a set of slick tires:
1) a set of slick tires for stock 18" wheel; OR
2) a set of BMW winter tires package, keep winter tires for winter and put slick tires for track driving, 245/40ZR18 for 4 wheel (18X8 stock offset).
Can anyone give me some adivce?
      06-21-2009, 05:56 PM   #2
ching
ching's Avatar
11
Drives: e90 m3
Use the stock tires and rims.
      06-21-2009, 08:22 PM   #3
Gearhead999s
Gearhead999s's Avatar
817
Drives: RR Velar R=Dynamic M2C R1200GS
You can use your stock 18's with the the stock tires,but this is the least cost effective way to run on the track.The stock PS2's are expensive to replace and are not very nice as a street tire after being on the track as they will be quite noisy and will not have as much grip after being heat cycled on track.
The best bet is too have a dedicated track setup.I run Toyo R888 in 255/35 18 & 265/35 18 on a set of Beyron Mesh 8.5 18 & 9.5 18.This setup is a little smaller in height than the stock rubber but seems to be an OK setup.If I had known how large the wheelwells were when I got this setup before my car arrived,I would have opted for an 18 x 10 25P all around with either a 265/35 18 or 275 35 18.The 275 is a common size and there are lots of track friendly available for this fitment.The R compound are available for much less than the equivilent normal Z rated tire.I think I paid around $350/tire last year.
http://www.teamtoyo.ca/Tires/R888_EN.asp
http://www.tirerack.com/tires/tires....del=g-Force+R1
https://www.hoosiertire.com/rrtire.htm
      06-22-2009, 12:42 AM   #4
Jimmer
Jimmer's Avatar
Drives: 2014 M235i with MPE
Totally correct! I run stock PS2 on my stock 18 rims and have already had to replace all four tires. You go through them quick and they aren't cheap.
Certified High Performance Driving Instructor - BMW of North America, Porsche Club of America / Chief In-Vehicle Instructor - Fleet Safety International
Gone but not forgotten: 2008 E92 M3; Eisenmann Race Exhaust / Dinan 3.62 Limited Slip Differential / Dinan Software / Dinan High-Flow Intake / Dinan Camber Plates / Dinan Lowering Springs / Dinan Sway-Bars
m3post
