12-02-2023, 06:35 PM | #1 |
11
Rep 19
Hello, I did a led projector and angle eye retrofit to the stock halogen headlights
I coded everything so the car is fine with all the LEDs. I have one small problem though, when I was building the headlight I connected the halo lights to parking lights only, the come on with parking lights, and headlights naturaly. I planed to code car so parking lights come on with DRL lights, so I will have the halo lights during day time as well( essentially the parking lights to be on always). Only problem is I can't find the code for it, I am searching for weeks. Dose anyone know how to do this.? |
12-04-2023, 09:17 AM | #4 |
295
Rep 486
You have wired the halos to parking lights, but which bulb in your car's headlight assembly is responsible for parking light function? I can only see the low beam projector and halos on... The selection of US side markers "turn signals" will activate the turn signal yellow bulb but at half of brightness. Try if that works first.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
12-04-2023, 09:36 AM | #5 | |
11
Rep 19
I will put an example of the bulb and mapping output for it I found below, I just don't what value to put there to have them always on. |
12-04-2023, 09:39 AM | #6 |
11
Rep 19
12-04-2023, 09:49 AM | #7 |
295
Rep 486
1. In original configuration was there a DRL light? Which bulb was responsible for it? If there was one, why didn't you wire the halos to that circuit?
2. Why the LOWER LED bulb in your car's high beam housing is off in the picture? Isn't that the parking light bulb? Is that normal for it to turn off when the low beams are on?
12-04-2023, 09:53 AM | #8 | |
11
Rep 19
12-04-2023, 10:07 AM | #10 |
295
Rep 486
So the DRL bulb (#5) turns off with low beams, which is similar to halos being dimmer with low beams in US (at least that is on both of my cars, adaptive Xenon and adaptive LED). I remember reading somewhere about coding the parking lights to be always on. I think that is what your are looking for. This way you will have your new angel eyes constantly on as well, since you have wired them to parking lights. I'll see if I can find that info...
12-17-2023, 10:04 PM | #12 | |
295
Rep 486
However, this post: https://f30.bimmerpost.com/forums/sh...5&postcount=70 could be helpful to you as it has a great attachment - list of mappings for FEM and REM. I believe this could help you with what you are trying to do...
Manof10.50 |
12-18-2023, 06:43 AM | #13 | ||
11
Rep 19
